    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 316.6k Views 110 Watching
    • SolarwiseLLCS Offline
      SolarwiseLLC
      @jiminy-billy-bob said:
      • Install Aerilius' AttributeInspector
      • Open it
      • Click on "jbb_layerspanel"
      • Delete all the " group[22]=null&group[23]=22&layer...." stuff (Just select and delete)
      • Reopen Layers Panel, you should loose all the sorting and groups, but it should work fine.
      Thanks. I will try this. Will I be able to regroup afterwards?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Of course, LP should behave normally after this. It's a fresh start.
        • sadyoS Offline
          sadyo
          Hi mr.Bob
          Seem like the LP 1.0.3 have problems when I updated TT_Lib 2.9.9 ❓
          http://s30.postimg.org/mgwf0y5fl/hh2.jpg
          I'm using Sketchup 2014 pro_Win8.1-64bit
            jiminy-billy-bob
            sadyo > Please see:
            @tt_su said:
            @vremennyi said:
            Or is this SU bug and about this should think SU developers?
            Yes - it's our fault. 😞 We're working on a fix.
            • tt_suT Offline
              tt_su
              That's a co-incidence. When you launch SketchUp via a SKP file that is located on a drive different from where SketchUp is installed something gets messed up in SketchUp Ruby. Launch SketchUp first, then open your file - that's the workaround until we release a fix.
                SolarwiseLLC
                After resetting the folders as you outlined. I was able to regroup and work in the file successfully. After closing SU and restarting my computer, the layers panel stop being responsive in that file. After working in the same file, using just the layers window, the layers panel reset the folders/grouping by itself. Once it reset itself, the layers panel worked, but the folders/grouping were deleted. Wondering if it's the plugin or my file.
                  jiminy-billy-bob
                  I'm investigating with the file you gave me. This is weird.
                  Do you actively use Didier's Layers Manager, or is it just installed?
                  To you import geometry, or copy/paste between instances?
                    SolarwiseLLC
                    I do actively use the Didler's Layer Manager. When transferring geometry, I usually copy and paste.
                      amis
                      Hi, Jiminy! There's a problem when I use cyrillic font to rename new layer - some codes appear instead of cyrillic letters. Although it didn't happen before (win XP, SU 2013) Got any ideas?
                        amis
                        amis > You're not the first to tell me this. I forgot, thanks to remind me, I'll take a loot at it.
                        So if I understand right, it works fine on winXP with SU2014, what is yout windows version now, and SU version?
                        we didn't understand each other properly) Win XP, SU 2013 that's for now
                          jiminy-billy-bob
                          New version 1.0.4 !
                          Changelog :
                          • Added better feedback when sorting multiple layers/groups at once
                          • Added support for Podium V2+
                          • Fixed support for Indigo
                          Download in the plugin store !
                          • kenK Offline
                            ken
                            I open Sketchup files on my travel USB HD from XnView all the time. So are you telling me, the safest way to open Sketchup files is from Sketchup and not a viewer?
                            IF so, this could explain a lot.
                            Thanks for your reply.
                            Ken
                            • tt_suT Offline
                              tt_su
                              Yes, if you use plugins then until we get the fix released you're better of starting SketchUp first, then open the files from SketchUp. Apologies for the inconvenience.
                                jiminy-billy-bob
                                Do you have an ETA for the fixed release?
                                • tt_suT Offline
                                  tt_su
                                  Afraid not. WIP.
                                    jiminy-billy-bob
                                    Layers Panel reached 300 unique daily users
                                    (as far as I can see, there are probably more if there are multiple users on a single IP adress)
                                    A big thanks to all of you to motivate me pushing this plugin further and further! πŸ˜„
                                    It wouldn't be what it is today if not thanks to all your feedback and ideas.
                                    http://i.imgur.com/55yXgRP.png
                                    • Bob JamesB Offline
                                      Bob James
                                      I still cannot undo without this appearing keeping the undo from happening:
                                      Undo Layers Panel ID
                                        jiminy-billy-bob
                                        Every time you undo?
                                          SolarwiseLLC
                                          I installed v1.0.4. and I am getting the same results of unresponsiveness. I went through and organised everything and after saving, closing the file and restarting it, it became unresponsive. I have reorganized my layers so many times without them staying active and/or organised that I am about to give up on your layers panel for this drawing.
                                            Bob James
                                            Ctrl-z or Alt-backspace
                                            Have to repeat many times before undo happens: most times undo never happens.
                                            What's more, sometimes undo does work. πŸ˜’
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 33
                                            • 34
                                            • 24 / 34
