    [Plugin] Component Array (Updated 27-Mar-2014)
    32 Posts 13 Posters 51.8k Views 13 Watching
    • EarthMoverE
      EarthMover
      Great thanks Sam, I'll check it out. Maybe you can make a unified component tools plugin with one toolbar. I'm just being selfish and trying to make my life easier with no regard for your time. πŸ’š I just finished a project with 60 different kinds of plants spec'd in and it was a nightmare. No worries though, I have a few more keyboard shortcuts left. πŸ˜‰
      Content Creator at Skapeup
        Justo
        Thanks again Sam.
        I'm not sure if anyone else would like this to evolve anymore than it has, but I'll ask anyway! πŸ˜’
        Is it possible to have:
        The result be grouped or made a component with the [quantity] x [component name] as the new group/component name.
        The option of having the face and lines surrounding the selection to be removed after component array is run. Although delete key usually does a good job of this if i remember to do so after running plugin...
        I could easily get carried away a few requests! Feel free to say bugger off! πŸ˜‰
        I have played around with the script for use with paved areas (takes me forever... hence the requests)
        Cheers
        Justin
        • brookefoxB
          brookefox
          Thanks for sharing... I guess experimentation may reveal how to best cope with tidiness (arraying strictly within, and even better, trimming to fit within bounds).
          On second thought, I guess a situation where that that kind of tidiness is desired is not what this is for.
          Joel is working on a remotely similar hatch plugin which is targeted to accomplish these things, but the poor guy has some kind of other life going on.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=38637
          ~ Brooke
            raineysky
            Sam,
            I need to make a chain and sproket for a piece of machinery similar to a bicycle chain and sproket assembly. Which one of your plugins is most suitable for this? I have a chain link made into a component. Thank You
            • EarthMoverE
              EarthMover
              Paul, try either Component Stringer or Shape Bender, both by Chris Fulmer.
                raineysky
                Thanks Earthmover. I do have Shape Bender, which is a wonderful plugin. It's just that I'm a little thick and have to re-learn how to make it work each time. Was hoping Sam had something because his plugins are always very easy to use. I am testing his Comp String plugin right now.
                • sdmitchS
                  sdmitch
                  Comp String is the only thing like that that I have but don't think it will work very well since the components will need to overlap precisely.
                  http://sdmitch.blogspot.com/
                    raineysky
                    Thanks Sam. Working nights now but will give Comp String another shot on my next day off.
                    • sdmitchS
                      sdmitch
                      Made SU2014 compatible.
                        I have added it to the PluginStore.
                        http://sketchucation.com/pluginstore?pln=Component_Array
                        • N
                          Neeko
                          Thank you.
                          I was looking for a plugin that would help me "spray" a grass instance regularly on a selected surface to "fill" it up. Now I just have to randomize the rotation of the components with "scale and rotate multiple" and that would make a perfect grass πŸ˜„
                          • T
                            tolifiers
                            Hello from Theo
                            This plugin is just about what i am looking for
                            we are laying steel decking for a flooring company on autocad
                            sketchup seems to be able to do a better job than most of the 3d cad programs about
                            revit the office is not interested in vector works is to bulky in its menu structure
                            to make you productive, and sketchup has some great add ons for detailing etc
                            How do i get around that fact of having to lay steel decking onto shapes that are not always rectangular on sketchup, ie taking a profile or a component made from this profile and making it fill a sketchup face of any shape.
                            lets know if your tool can do this or can be modified or if you know of a tool that can do this, these steel profiles are 600 wide of any length that suits its purpose,
                            concrete floors are poured over this once laid.
                            many thanks regards Theo e-mail theoolifiers@gmail.com
                            • sdmitchS
                              sdmitch
                              @tolifiers said:
                              Hello from Theo
                              No, Component Array was not designed to do anything like that. My FloorGenerator, which accepts a width and maximum length would be the closest match. If possible, post a sample model that demonstrates what you are trying to do. I have other unpublished plugins that might be adaptable to your needs.
                              • T
                                tolifiers
                                Hello from Theo
                                Many thanks for your reply.
                                Please find attached a detail and sample of steel decking
                                i am trying to fill an area with the steel decking shape not sure
                                how to go about it.
                                I am trying to figure out the best program to make doing these drawings
                                easier for install and detailing, autocad has been good till now
                                but as always every thing is wanted faster, and i am not sure that 3d
                                is the answer , but so far sketchup is looking the better option
                                to lay decking quickly in 3d, time will tell, vectorworks is a pain to use
                                revit is ok, but laying decking and trying to trim it is or will be
                                too time consuming.
                                sketchup may be the best option if the shape can fill an area quickly ?
                                there are examples of 3 different shapes as we might find on a building
                                area where we have to lay different styles of metal decking.
                                its not easy to do in revit or any cad 3d program with out a lot of hassle
                                trimming off excess deck manually.
                                Easy in autocad, just use trim.
                                3D is another story and i think sketchup will be the easiest program to do this
                                These steel decking sheet come in any length some span over
                                2 beams others 3 beams max length for handling is about 10m
                                i am just trying to find an easy way to fill an area with the sheets
                                and have it automatically trim off to a defined shape.
                                the sheets lap at 600mm length ways.
                                see 3d detail of some sample sheet styles and bolts to hold slab in place.
                                Thanks Regards Theo
                                flooring-profile-sample.skp
                                • T
                                  tolifiers
                                  Hello from Theo
                                  screen image attached from autocad so you can see what this office
                                  is doing with steel decking
                                  we are flat out.
                                  Regards Theo
                                  • sdmitchS
                                    sdmitch
                                    Theo
                                    Doh!!!!! I forgot to mention I'm stuck on SU2014 so I am unable to open the model posted.
                                    The screen shot at least gives me some idea of the problem.
                                    • T
                                      tolifiers
                                      Hi from Theo opps sorry here is a version 8
                                      thanks for that
                                      Regards from NZ as attached
                                      • T
                                        tolifiers
                                        From Theo PS that screen shot is one i am working on right now
                                        One of the worst sites its all sorts of angles
                                        more often they are rectangular in shape with stairs cut out
                                        or offset corners, but this one is all over the place
                                        Autocad is a good option to edit easily
                                        but the office has thoughts on going 3D mmmmm good and bad idea.
                                        it slows things down. So am thinging sketchup is a better option than vector works and revit, and seeing some architects do great detailing using sketchup
                                        no harm in doing the same, so will keep at it.
                                        Thanks Theo
                                        • P
                                          pcmoor
                                          I suggest that " profile builder 2 " would best suited to this layout and take off, the profiles can be trimmed or extended to the angles
                                          • T
                                            tolifiers
                                            Hi from Theo
                                            many thanks i will give it a go.
                                            have a busy week.
