    [Plugin] Component Array (Updated 27-Mar-2014)
    32 Posts 13 Posters 51.3k Views 13 Watching
    • majidM
      majid
      would you give us a visual tut?
      • W
        wyatt
        I love this. I know I will use it a lot. Is there any reason the component selection window includes groups? Lots of components include sub-groups and that makes the list quite lengthy. Would it make more sense to only include components? Maybe you have a reason including groups that I'm missing.
        • sdmitchS
          sdmitch
          No your not missing anything. The API model.definitions is suppose to only return components but apparently not. So far I haven't figured out how to filter the groups out.
          I doubt if there is a way to distinguish between a sub-component and the component containing it. The best I can do for now is suggest you know the name of the component you want and type the first letter. That will allow you to step through the list to find it.
          Oh no it isn't, I've just figured it out. Thanks for the question.
          http://sdmitch.blogspot.com/
          • W
            wyatt
            Thank you for updating the script. It works better...groups and sub-components no longer show up. The list now shows each instance as a unique component. Is there a way to filter it so component names only appear once?
              The model.definitions returns ALL definitions - which includes components, groups and images [the last two are just special kinds of component if you think about it].
              To make a list of just components loaded into the model use this...
              defs=model.definitions comp_names=[] defs.each{|d|comp_names << d.name if not d.group? and not d.image?}
              You then have a list of all "component" definitions in the model 'by name'...
              Use joined_names=comp_names.join("|") for the dialog dropdown...
              Later after the user has selected a component by name and pressed OK, to get a reference to that definition from the selected 'comp_name' use...
              def_to_use=defs[comp_name]
              much as you have done before... πŸ˜‰
              • EarthMoverE
                EarthMover
                Thanks Sam! You came through as always. πŸ‘ πŸ‘ It would be great to see this developed even further. Perhaps adding functionality for choosing up to three different components and randomly distributing them in the array. Perhaps also an option to randomize scale. Being that this started as a vegetation plugin, those things would make it great for mass plantings. It's a nice simplified version of component spray.
                Content Creator at Skapeup
                • sdmitchS
                  sdmitch
                  TIG, thanks for the tip. I had worked it out a different way but I think I like your method better.
                  • sdmitchS
                    sdmitch
                    I already did that, at least partially, it's called RandomComponentReplacement.
                    • EarthMoverE
                      EarthMover
                      Great thanks Sam, I'll check it out. Maybe you can make a unified component tools plugin with one toolbar. I'm just being selfish and trying to make my life easier with no regard for your time. πŸ’š I just finished a project with 60 different kinds of plants spec'd in and it was a nightmare. No worries though, I have a few more keyboard shortcuts left. πŸ˜‰
                        Justo
                        Thanks again Sam.
                        I'm not sure if anyone else would like this to evolve anymore than it has, but I'll ask anyway! πŸ˜’
                        Is it possible to have:
                        The result be grouped or made a component with the [quantity] x [component name] as the new group/component name.
                        The option of having the face and lines surrounding the selection to be removed after component array is run. Although delete key usually does a good job of this if i remember to do so after running plugin...
                        I could easily get carried away a few requests! Feel free to say bugger off! πŸ˜‰
                        I have played around with the script for use with paved areas (takes me forever... hence the requests)
                        Cheers
                        Justin
                        • brookefoxB
                          brookefox
                          Thanks for sharing... I guess experimentation may reveal how to best cope with tidiness (arraying strictly within, and even better, trimming to fit within bounds).
                          On second thought, I guess a situation where that that kind of tidiness is desired is not what this is for.
                          Joel is working on a remotely similar hatch plugin which is targeted to accomplish these things, but the poor guy has some kind of other life going on.
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=38637
                          ~ Brooke
                            raineysky
                            Sam,
                            I need to make a chain and sproket for a piece of machinery similar to a bicycle chain and sproket assembly. Which one of your plugins is most suitable for this? I have a chain link made into a component. Thank You
                            • EarthMoverE
                              EarthMover
                              Paul, try either Component Stringer or Shape Bender, both by Chris Fulmer.
                                raineysky
                                Thanks Earthmover. I do have Shape Bender, which is a wonderful plugin. It's just that I'm a little thick and have to re-learn how to make it work each time. Was hoping Sam had something because his plugins are always very easy to use. I am testing his Comp String plugin right now.
                                • sdmitchS
                                  sdmitch
                                  Comp String is the only thing like that that I have but don't think it will work very well since the components will need to overlap precisely.
                                    raineysky
                                    Thanks Sam. Working nights now but will give Comp String another shot on my next day off.
                                    • sdmitchS
                                      sdmitch
                                      Made SU2014 compatible.
                                        I have added it to the PluginStore.
                                        http://sketchucation.com/pluginstore?pln=Component_Array
                                        • N
                                          Neeko
                                          Thank you.
                                          I was looking for a plugin that would help me "spray" a grass instance regularly on a selected surface to "fill" it up. Now I just have to randomize the rotation of the components with "scale and rotate multiple" and that would make a perfect grass πŸ˜„
                                          • T
                                            tolifiers
                                            Hello from Theo
                                            This plugin is just about what i am looking for
                                            we are laying steel decking for a flooring company on autocad
                                            sketchup seems to be able to do a better job than most of the 3d cad programs about
                                            revit the office is not interested in vector works is to bulky in its menu structure
                                            to make you productive, and sketchup has some great add ons for detailing etc
                                            How do i get around that fact of having to lay steel decking onto shapes that are not always rectangular on sketchup, ie taking a profile or a component made from this profile and making it fill a sketchup face of any shape.
                                            lets know if your tool can do this or can be modified or if you know of a tool that can do this, these steel profiles are 600 wide of any length that suits its purpose,
                                            concrete floors are poured over this once laid.
                                            many thanks regards Theo e-mail theoolifiers@gmail.com
