    Fishing net modeling
    131 Posts 12 Posters 13.5k Views 12 Watching
    • olisheaO Offline
      olishea
      nice
      oli
        DOD3R
        you should check Ferrari sketch plugin
        its actually special program fro tensile structures
        D.
        • BoxB Offline
          Ferrari is a good tool for tensile, but you can spend a lot of time getting it to the shape you want and then you need to separate out the profiles to make your ropes.
          This was done with 3 beziers curves on a square, then tig's Extrude edges to lattice to produce the web, then lines to tubes.
          All in all it almost took longer to write this than to make it.
          • W Offline
            willipop
            Very nice ! The shape of it looks more square than round. It will play with this method tonight to see what I can do. Many thanks !
            • BoxB Offline
              Anything is possible, use curves, use diagonals, stretch the mesh, bend the mesh etc etc
              • olisheaO Offline
                olishea
                that's really cool box. πŸ‘ Can I ask why you are using lines to tubes? Is there not a TIG lattice tool that makes square sections, or are you just setting the amount of edges to 4? ❓
                oli
                • BoxB Offline
                  No credit to me Oli, it's Tig's plugin that does all the work.
                  No, I set it to 5 just to give it more of a rounded effect.
                  And I was simply using tig's lattice for the lines so you can easily reshape them then make them tubes after.
                  • W Offline
                    willipop
                    Is it possible to set the parameters for the distance between the lines ?
                    • olisheaO Offline
                      olishea
                      I have found a better way of doing this using my "cave technique"....start off with a grid and ONLY use quads. I'll post a screenshot very shortly. It looks sweet.
                      oli
                        Using my EEbyLattice the 'spacing' is set by the segmentation of the 4 curves.
                        Draw those edges the distances apart you require and 'weld' them into the curves...
                        Then the 'net will have segments the distances you want - at least when it starts off - of course they must be adjusted as the mesh surface is formed πŸ˜’
                        • W Offline
                          willipop
                          Oli I like your caves very much, well done πŸ˜‰
                          • olisheaO Offline
                            olishea
                            I know my example is too uniform, but this is how I'd personally go about it. You can change the distances between the nets too, make them bigger, smaller etc.
                            Now you just need to reduce the amount of poles where the nets meet.
                            The bottom variation ,I just used artisan sculpt tool; however it creates many triangles.
                            And thanks willipop! πŸ‘
                            oli
                            • W Offline
                              willipop
                              It's what I tried previously πŸ˜„ Also I used the artisan's selection tool to select the faces with less vertex and I applied the subdivide tool too add some more vertex.
                              • olisheaO Offline
                                olishea
                                Here is another. Possibilities are endless really. I intersected the large cones too much though, they don't need to be made up into quads like that, I just wasn't thinking and it causes a more square-like shape than the smaller cones. All rectifiable though.
                                I didn't attempt to convert the second mesh (with 2 artisan iterations) to tubes because my xbox isn't going to play itself tonight! πŸ˜†
                                oli
                                • olisheaO Offline
                                  olishea
                                  This is what I meant about the larger cones....the mesh on the right performs better than the mesh on the left which had unnecessary vertices. The larger cones are now rounded as opposed to slightly squared.
                                  oli
                                  • W Offline
                                    willipop
                                    Very cool πŸ˜„
                                    • olisheaO Offline
                                      olishea
                                      ....and if you want to use less poly than tubes; try using Multi Face Offset plugin to the mesh and then TIG's JointPushPull to the new offset faces.
                                      I suggest using softened edges to this quad-sectioned profile to give the illusion of rounded thread. If the thread is very small it won't even be noticeable that you are using a quad to make the profile.
                                      [EDIT] although it seems to cause some other unwanted faces here and there, may be best off sticking to tubes after all. 😳 πŸ˜†
                                      oli
                                      • pyrolunaP Offline
                                        pyroluna
                                        Guys if you're making those tubes merely to create accurate shadows on the ground... you know you can switch on 'from edges' in the shadow window, right?
                                        • BoxB Offline
                                          Don't know about the others but my tubes are for the look of the net, not to create the shadows.
                                          • olisheaO Offline
                                            olishea
                                            haha I didn't even know you could do that! πŸ˜†
                                            oli
                                            • 2 / 7
