    Fishing net modeling
    131 Posts 12 Posters 24.1k Views 12 Watching
      Using my EEbyLattice the 'spacing' is set by the segmentation of the 4 curves.
      Draw those edges the distances apart you require and 'weld' them into the curves...
      Then the 'net will have segments the distances you want - at least when it starts off - of course they must be adjusted as the mesh surface is formed πŸ˜’
      • W Offline
        willipop
        Oli I like your caves very much, well done πŸ˜‰
        • olisheaO Offline
          olishea
          I know my example is too uniform, but this is how I'd personally go about it. You can change the distances between the nets too, make them bigger, smaller etc.
          Now you just need to reduce the amount of poles where the nets meet.
          The bottom variation ,I just used artisan sculpt tool; however it creates many triangles.
          And thanks willipop! πŸ‘
          oli
          • W Offline
            willipop
            It's what I tried previously πŸ˜„ Also I used the artisan's selection tool to select the faces with less vertex and I applied the subdivide tool too add some more vertex.
            • olisheaO Offline
              olishea
              Here is another. Possibilities are endless really. I intersected the large cones too much though, they don't need to be made up into quads like that, I just wasn't thinking and it causes a more square-like shape than the smaller cones. All rectifiable though.
              I didn't attempt to convert the second mesh (with 2 artisan iterations) to tubes because my xbox isn't going to play itself tonight! πŸ˜†
              oli
              • olisheaO Offline
                olishea
                This is what I meant about the larger cones....the mesh on the right performs better than the mesh on the left which had unnecessary vertices. The larger cones are now rounded as opposed to slightly squared.
                oli
                • W Offline
                  willipop
                  Very cool πŸ˜„
                  • olisheaO Offline
                    olishea
                    ....and if you want to use less poly than tubes; try using Multi Face Offset plugin to the mesh and then TIG's JointPushPull to the new offset faces.
                    I suggest using softened edges to this quad-sectioned profile to give the illusion of rounded thread. If the thread is very small it won't even be noticeable that you are using a quad to make the profile.
                    [EDIT] although it seems to cause some other unwanted faces here and there, may be best off sticking to tubes after all. 😳 πŸ˜†
                    oli
                    • pyrolunaP Offline
                      pyroluna
                      Guys if you're making those tubes merely to create accurate shadows on the ground... you know you can switch on 'from edges' in the shadow window, right?
                      • BoxB Offline
                        Don't know about the others but my tubes are for the look of the net, not to create the shadows.
                        • olisheaO Offline
                          olishea
                          haha I didn't even know you could do that! πŸ˜†
                          oli
                          • BoxB Offline
                            One thing to note on that Oli is that the shadows produced by those edges won't show in all renders.
                            • olisheaO Offline
                              olishea
                              Oh I know, but sounds like the OP wants to keep things in sketchup anyway. Either way, I'd still use the tubes, they just look better.
                              Some render engines can render lines where and you can change their thickness, Twilight for one can do it. But they won't look tubular, just flat lines with no texture. And it still won't render the lines' shadows.
                              So yeah, model the tubes! πŸ˜†
                              I forgot to mention....if you delete the topmost face of the net proxies, it won't produce any triangles in the mesh. You see how my mesh has triangles towards the top of the cones? Shouldn't be like that; I just forgot to delete the top face (which is barely apparent because it's so small). Hope that makes sense, just trying to keep the mesh as tidy and as low poly as possible.
                              oli
                              • W Offline
                                willipop
                                I'm getting it ! πŸ˜„
                                • olisheaO Offline
                                  olishea
                                  Looking GREAT!!
                                  Couple of tips....see attachment.
                                  I know it doesn't matter so much for this project, as you only need the lines....but you see how your mesh is mixed up with front faces and reversed faces? If you right click any front face and click Orient Faces, it will make every face the same. You can do this while it's still in the proxy stage or even after you have subdivided, but I would recommend doing it at the proxy stage for speed. It's just good practice.
                                  You see the cone on the bottom left of your image? How it has a strange base? This is because you have a face within the cone before you subdivided.
                                  Look underneath your model and delete any internal faces within the cone. Also delete the topmost face of the cone if there is a face there; your nets may converge to a point though, I can't quite tell from the image. If they converge to a point then forget what I've said regarding this. πŸ˜†
                                  There is also a very helpful plugin called RemoveInnerFaces.rb that I use ALL the time before a subdivision. It's always good practice to manually inspect your proxy before a subdivision though, as it's easy to miss a hidden face inside your geometry. πŸ˜‰
                                  Great progression in your work! πŸ‘
                                  oli
                                  • W Offline
                                    willipop
                                    Thx you Oli ! I did realize about the reverse faces... It's my first test ! I really like artisan it's soo fun to play with it πŸ˜„πŸ™‚
                                    About the innerfaces... I hide the faces and then I select the edges and run lines to tube so I can delete the faces after.. Is it what you mean ?
                                      Seems Protrude can make easily this! πŸ˜‰
                                      Just draw the planar form ! πŸ’š
                                      http://sketchucation.com/forums/download/file.php?id=14939&t=1
                                      • olisheaO Offline
                                        olishea
                                        No.
                                        You see the base of the cone? How it looks distorted, unlike the other cones? It's because there is a face inside the cone. It causes the subdivided mesh to act strange.
                                        See this as an example:
                                        Above The Mesh
                                        Under The Mesh
                                        oli
                                        • W Offline
                                          willipop
                                          Got it πŸ˜„ I actually deleted these innerfaces πŸ˜‰
                                          • W Offline
                                            willipop
                                            @ Pilou : What is this exactly ? πŸ˜„
                                            • 3 / 7
