    Trouble intersecting
    14 Posts 5 Posters 1.6k Views 5 Watching
      GailyD
      Thanks Remus, I can see the millions of tiny lines on the instersecting shape but I don't know how to delete them without losing the surfaces... newbie 😳 ...
      And I take on your point re poly count, I am modelling a new product and maybe should let go of the fact it will not be smooth as the real thing, although we do need a certain amount of accuracy to work out the size of the parts - I will keep it in mind as I evolve.
        Hi GailyD,
        Remus is right about high poly (my machine just stopped responding when I tried to intersect - with a 3.8 Gz processor 😲 surely it was working but still...)
        Anyway, as the (little bit outdated) SU Guide says about it: "Edges created by the Intersect With Model Tool are drawn in the current context."
        This means that you cannot intersect two groups or components at the same time being outside of their editing context.More exactly the lines appear but not within the group/component.
        Intersect with context would make an intersection within that group/component editing context (while editing it) if you want to change something in it (regardless of external geometry) so that you won't end up with a lot of junk because your group was also affected with something outside of it.
        Intersect selected will disregard any geometry that is not selected for the same reason.
        But always remember - the lines always appear in the context you are in. when outside the group/component, then outside so they won't be affected at all.
          GailyD
          Ok this is all good, I am assuming those rockin looking models come from the final rendering not from making really round smooth models which take hours to think about... that is a big help.
          What I understand you are saying relates to the grouping question and in short to get both items to intersect at once they should be in the same group or all exploded?
            remus
            Looking at it again, i think it would be faster to remodel the whole thing, as sorting out the tiny discrepancies in the model could be pretty time consuming.
            I had a quick go at it, although youll probably want to check the pieces to be intersected for accuracy.
            Intersect_eg.skp
              GailyD
              That looks great, I would love to know how you did the quarter sphere as that is a shape I am using quite a bit...
              Gail
                I bet he did a follow me operation.
                Select the edge I have painted blue then click on the red surface with the follow me tool. (Or just click on the face with the tool and drag it around the bend).
                FollowMe.skp
                  GailyD
                  Yes! I have been having a lot of trouble with follow me but i didn't have two rails to follow so that is probably the issue. Thanks, I can apply this in a few places too.
                    remus
                    Spot on Gai, thats exactly what i did. Its not entirely accurate though, as the inner section of the 'sphere' is slightly rounded. If you want to get it accurate, you could quite easily draw a sphere and then cut it in to quarters using the intersect method (or just turning on hidden geometry and deleting the stuff you dont need.
                      txusic
                      IΒ΄m having a similar problem with much simpler forms..
                      24 sided tubes that ive perform intersection in diferent archives and suddenly have difficulty to to make good closed lines...
                      one archive came perfectly.. and another jagged and unclose... when both tubes were exactly the same, placed in the exact same place just different archives...
                      https://lh5.googleusercontent.com/-o_ZHHOVGYtg/Uy4MKVIAJ8I/AAAAAAAAAXU/ZUMExX86W5E/w741-h730-no/Imagen+352.png
                        @Txusic
                        View the forms with Hidden Geometry ON.
                        You will probably find that the 'good' intersection results from the segmented edges of the two cylinders aligning correctly.
                        If the segmented edges don't align you'll get jagged edges when they intersect - as you might logically expect πŸ˜’
