    Plugin not plugged in
    23 Posts 3 Posters 1.8k Views 3 Watching
    • Al HartA
      Al Hart
      Open the SketchUp Ruby console, and type in:
      load 'polygonmaker.rb' and hit enter, and see if it can find it, or if you get any error messages.
      If the Ruby Console responds 'true', then load the SketchUp Preferences extension menu to make sure it is enabled.
      Al Hart
      IRender nXt from Render Plus
        jalsina
        Al,
        That command produces this error message:
        Error: #<LoadError: (eval):0:in `load': no such file to load -- polygonmaker.rb>
        (eval)
        (eval):0
          jalsina
          Dave R,
          Sorry, my post was unclear. I don't have any other sdmitch plugins loaded. I have other non-sdmitch plugins loaded that work normally. Is there a "master" sdmitch plugin that produces the SDMtools menus? I'm not seeing it in the list of plugins, but maybe I'm missing it.
            Concentrate on getting polygonmaker.rb installed correctly first.
            Have you got the permissions for the Plugins folder set to Full for your username?
              jalsina
              Yes, I have full permissions for the Plugin folder.
                And the plugin is installed in the folder? Can you post a screen shot of the Plugins folder?
                  jalsina
                  Sorry to be dense, but how do I post a screenshot? I've got the screenshot; I just don't know how to post it here.
                    There's an 'Upload attachment' tab below the text window.
                      jalsina
                      here's the shot, I think.
                        Have you closed and restarted SketchUp? You don't see the SDM Tools menu in Plugins?
                          jalsina
                          Honest, there's not a trace of it. I've closed and restarted Sketchup multiple times, and I've also shut down and restarted Windows.
                            jalsina
                            Dave,
                            Is it possible that Sketchup 2014 isn't looking for plugins where we think it's looking? I have Sketchup 2013 on my machine, too.
                            John
                              Maybe it's not looking at the folder yet. Try this: go to Window>Preferences>Extensions and tick the little box for Dynamic Components. Click OK, close SketchUp and reopen it. Check the Plugins menu.
                              Al alluded to it in his post but I was too groggy last night to pick up on it.
                                jalsina
                                Al, Dave,
                                Sketchup.find_support_file('Plugins') returns:
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins
                                Aha! Now, how do I change the path?
                                • Al HartA
                                  Al Hart
                                  Can you run SketchUp again and load the about dialog to make sure you are running the proper version?
                                  Al Hart
                                  • Al HartA
                                    Al Hart
                                    Open the ruby console, and type in:
                                    Sketchup.find_support_file('Plugins') [and tap enter]
                                    I suspect it may not point where we expect.
                                    We expect it to return:
                                    C:/Users/John Alsina/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/
                                    Then try
                                    Sketchup.find_support_file('Plugins/polygonmaker.rb')
                                    If it does not return a fill path, then polygonmaker.rb is not in your plugins folder.
                                    Al Hart
                                      jalsina
                                      Well, my face is red! I can invoke SK from the start menu, the taskbar, and from a desktop shortcut. One of them - the taskbar - pointed to SK2013. The icons for SK14 and SK13 are identical, so I didn't notice.
                                      That fixes the mysterious SK14 plugin "problem." Thanks.
                                      BTW, is there an easy way to import all my old SK13 stuff - styles, preferences, etc. - into SK14, or do I have to re-create?
                                        So it was there all along? Excellent! 😉
                                        As for importing your "old SK13 stuff", you can copy styles and materials--those folders will be in Programs X86/SketchUp/SketchUp 2014/... so make sure you set permissions to Allow before copying them. Shortcuts should automatically be picked up. If you made a custom template, the easiest way to get it is to open SU2013 and immediately save the file to somewhere like your desktop. Then open SU2014, open that file and immediately do a File>save as template.
                                        DO NOT copy plugins from the 2013 Plugins folder to SU2014. Download fresh copies.
                                        • Al HartA
                                          Al Hart
                                          We have to keep lots of old versions of SketchUp around to test our plugins.
                                          I really wish they would return to the old habit of changing the icon with each new version.
                                          Al Hart
                                            jalsina
                                            Al,
                                            I see you are a Plugin Store author. I get the impression that the new Extension Warehouse doesn't have many plugins in it. Is that right, or am I missing something? Thx. JA
