    Strange dark areas on final render
    renderpluginsextensions
    4 Posts 3 Posters 399 Views 3 Watching
      RP Images
      Hi Everyone,
      I have just started getting these weird darker areas on my final renders.
      I have attached a photo for reference, currently using Sketchup 8 Pro & Vray 2.0.
      If I do a render of the left half of the view and then the right half it works but if it does the whole scene I get this as the final. In the top right corner shows what I can get if render at 600px but anything above 1000px gets this result.
      Any help would be greatly appreciated.
      Thanks,
      Results
      • dkendigD Offline
        dkendig
        looks like the texture being used for the environment/dome light is not transferring to the dr node for some reason.
        Devin Kendig
        Developer
        • V Offline
          valerostudio
          I did see this issue once with VR for MAX not transferring the HDRI to the environment on DR. I will test this in VR4SU and report back.
          • V Offline
            valerostudio
            Just tested a DR render with a dome light and another with an HDRI in the GI slot too and now issues here. Make sure to update all of your spawners when you install a new version / release.
