A Style Experiment
Here's an example of a new marker style I created this morning. I've been playing with ideas for making drawings look looser and more like hand drawn. I'd see this sort of style being used for massing studies and early proposal drawings.
Nice. Must see you do these in person.
Thanks Rich. I don't know if it would be that interesting to watch but I could show you.
Pilou, why did you post that? What does it add to this thread?
Looks great, Dave...!
Is it going to be available in the SCF store at some point...? -
Thanks, Kim,
It may be available. We'll see. It needs some sort of packaging because it isn't just the lines that makes it.
Dear David,
I think your style reminded Pilou of drawings done with charcoal, hence the image of various line widths.
He is also quite, quite mad.
Kind regards,
Bob -
Like this style a lot Dave... really looks hand-drawn. Very cool.
Thanks Doug.
Here's another example. I chose this one for the small arcs and circles to see how the style handles them.
I'll have to write a short instruction sheet and package it up.
This looks great Dave, love the loose style.
That looks great.
I'd like to know how you made it work so well with these tiny arcs? -
Thank you, gentlemen.
Jan, there are two tricks to get the arcs and curves to display as I show them. First, the style needs to have the shortest line segments available. The other is to make sure all curves are welded. The arm rests on the Adirondack chairs and a number of separate curves. I made sure to weld them before applying the style. If the curves aren't welded, each short line segment gets treated independently of its neighbors. And if the segments are shorter than the shortest line in the style, it doesn't get displayed at all.
When I create my sketchy styles now I make 10 lines of each of the 7 different lengths available so there's a lot of variability in the lines. 16 is the shortest available length but I would like to have the option for 8. I'd also like to have a couple of even longer lengths available as well as the ability to include more than 10 of each length.
Thanks for the info. Didnt know about weld.
Would love to know how you create a style like this / how much work it is.
I'm sure I'm not the only one that will appreciate your instruction. -
It really isn't much work to get the images as I show them. I'll make up an instruction sheet and put the package together this evening.
Looks VERY nice!
It's now available in the Shop.
I really enjoy seeing all your new styles.
