    Isolate Unique parts
    3 Posts 2 Posters 355 Views 2 Watching
    • E
      ericschimel
      Hey all, I have a large model that is made up of a ton of components:
      https://www.dropbox.com/s/qsj8ci6zwmjkyih/Alex%20Shed%204.skp
      There are anywhere from 2-hundreds of copies of each component in the model. What I would like to do is isolate one instance of each component so that I can save them out and mill them on a CNC machine.
      I could do this manually, but it would be a pretty long process, even on this small model. Does anyone know if there is a way to do this? I poked around for a plugin but I didn't find anything....
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Find my Components to Grid in the PluginStore.
        Work on a copy !
        This Tool lays out all components in the model to a preset grid...
        For this set, say 3x3m ?
        You then need to delete the original instances.. and edit the new 'gridded' set to delete unwanted nested parts, cats [!!!] etc.
        Then perhaps rotate the object's geometry so it's flat for the CNC axes etc...
        OR change these component's axes with the context-menu option so they are 'flat' as far as CNC would know...
        Purge unused to clear the dross.
        Then export the model's components as a collection into their own folder, so you have a separate SKP for each part.
        Then use a batch exporter to make them individually as DXF/DWGs etc ?
        • E
          ericschimel
          I think that may just work.... Thank you sir!
          -Eric
          Custom Models
