    SketchUp 2014
    205 Posts 79 Posters 78.1k Views 79 Watching
    • jo-keJ
      jo-ke
      where is the plugin folder?
      I like to install manually some plugins, that comes as a .rb file like the 1001bit- tools
      http://www.zz7.de
      • jo-keJ
        jo-ke
        Found it!
        Its located at the userdatas.
        http://www.zz7.de
        • cottyC
          cotty
          This can help you next time...
          my SketchUp gallery
          • neetsN
            neets
            Thanks Andrew!!! πŸ˜„
            Anita
            Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
              arklandesign
              Note of thanks to all the authors hard work in updating their plugins for 2014.
              That must be a lot of hard work to do, so thanks you.
              Also, thank you sketchucation for making the plugin download pretty much an effortless experience. The plugin store is my preference over the extension warehouse. Faster and easier to use with even more control.
              I am having problems on only a few plugins. Artisan (Ext,W download)has a grayed out register, so I can not enter in my licence. What should I do?
              I have tried to follow the instruction over at Vali Architects for Chuck's instant wall and fence scripts. Inside SketchUp > Windows > Preferences > extensions > install extension and navigate to where I have the newly downloaded 2014 zip files located, but it will not open them.
              Do I have to unpack these (extract)? Or, what exactly.
              A little lost here as to how to do this.
                If you add a .rbz onto the end of the .zip file name you can then Auto Install it via the Preferences > Extensions > Install... button πŸ˜•
                  arklandesign
                  Thank you TIG I had read that before but had forgotten it in the whirlwind of getting all my plugins to work.
                  Worked like a charm. Thank you Sketchucation....
                  I just became a premium member.
                  A small and worthy price to pay for all the help received over the years.
                  • T
                    tomot
                    @charly2008 said:
                    I have now installed Sketchup 2014. I must say that it is a difficult and time-consuming business to find all the beloved plugins again. Many are not yet available for 2014. That means you have to look always in the Extension warehouse or in the Plugin store if there is a matching plugin available.Some will perhaps not at all updated. I think It will certainly take months until the most Plugins are up to date. Until then I will continue to maintain my beloved Sketchup 8. Until now I can still see no advantage over Sketchup 8. Maybe I will recognize the benefits later.
                    I'm in total agreement with you. Consider for a moment all the users that were happy, could potentially become unhappy users. Just because they thought the next version was going to improve their SU experience. I'm a part-time plugin developer. I write plugins not for financial gain. The $5.00/plugin is there just to avoid FREE leeching. I'm also staying with 8 πŸ˜„
                    my plugins
                    tomot
                    • N
                      numerobis
                      ok... now we know it:
                      jbacus via twitter
                      SU isn't a quad modeler. Nor is it more likely to become one in the future than it is to become an aardvark. Why must it?
                      SU isn't a sub-d modeler. Nor is it more likely to become one in the future than it is to become an aardvark. Why must it?
                      SU isn't a parametric modeler, though it can behave in parametric ways. No modifier stack. Isn't 'direct' better?
                      πŸ˜’
                      When was the last time a feature that made you catch your breath was added to Photoshop? Or Microsoft Word?
                      http://www.ronenbekerman.com/sketchup-2014-released/#respond
                      • ken28875K
                        ken28875
                        @tig said:
                        @ken28875
                        In the last day or so there have been lots of posts about v2014 - read those - for example...
                        http://sketchucation.com/forums/viewtopic.php?p=512951#p512951
                        You must NOT blindly copy plugins across from older versions.
                        Some will work, but some might not.
                        Thanks, TIG.
                        So I uninstalled SketchUp Pro 2014 and reinstalled it without adding any plugins...and it crashed everytime I clicked on it. 😲 ❓
                        I also have SketchUp Pro 2013 active. I am wondering if there is a conflict between having both on the same machine.
                        Does anyone experience a similar issue?
                        Thanks,
                        _KN
                        Follow Your Dreams.
                        • AndrewSA
                          AndrewS
                          SketchUp's uninstaller will only remove files it was responsible for installing in the first place. Therefore, if you copied other items into the plugins folder, then uninstalled and reinstalled SketchUp, those plugins will still be there, along with any problems related to those plugins. You'd want to uninstall 2014, then manually ensure you've removed all plugins, before reinstalling.
                          SketchUp 2014 was designed to install alongside 2013. It's probably the very first installation scenario we test and something nearly everyone on the SketchUp team does. I do not know of any reason why you would not be able to have both programs installed.
                          Andrew
                          Andrew S.
                          SketchUp Release Engineer
                          • ken28875K
                            ken28875
                            Andrew
                            Thanks for yuor reply, Andrew.
                            So I tried to uninstall and reinstall once more and still got the Bug Splat πŸ‘Š
                            even by manually deleting all plugins and folders in SketchUp 2014.
                            _KN
                            Follow Your Dreams.
                            • T
                              tomot
                              @tig said:
                              Sketchup v2014 uses a newer [better] version of Ruby.
                              This has meant that in anticipation of the release, over the past weeks authors have been doing a lot of reworking of Plugins, discreetly in the background.
                              Your older Plugins will probably cause issues with v2014.
                              Do not copy them across.
                              It's highly recommended that you install fresh versions from the PluginStore etc.
                              Many of these are already updated to work with v2014 [as well as earlier versions].
                              There may of course be issues with some older plugins that haven't been updated [yet]...
                              Please report these in each Plugin's thread, so that the author is made aware of an issue and hopefully a v2014 friendly update will be forthcoming: sometimes there is major recoding needed, but often the .rb file just needs its "encoding" changing to "UTF-8 without BOM" rather than "ANSI", which can be easily done in Notepad++...
                              Trimble seems to think authors have nothing else to do. Was it not more important to create a 64bit version? Instead we have the entire Ruby add on Industry checking code for errant spaces, degree vs ΒΊ etc.
                              I dumped one of my Plugin folder for SU 8 into SU2014 The list of error was 4 pages long. Most errors were from major add on makers, I wont name names, other were mine some of which were derived from copying ruby code from other code writers. If I was a Trimbler now! I would not be so proud. πŸ˜„
                              I'm telling customers not to buy my scripts if they intend to use them in SU2014. I simply don't have time with an 8 hour eval copy of SU2014, to see if my Rubies are API compliant. Also I would starve if I had to survive on $5.00 scripts.
                              my plugins
                              tomot
                              • AndrewSA
                                AndrewS
                                So I tried to uninstall and reinstall once more and still got the Bug Splat even by manually deleting all plugins and folders in SketchUp 2014.
                                FYI for the thread...
                                We received the BugSplat and looked at it. Sure enough, the crash was due to the presence of incompatible Ruby scripts in the user's plugins folder and a failure to delete those plugins before re-launching SketchUp.
                                As has been indicated elsewhere, you must not copy the plugins folder. Reinstall the scripts via the extension warehouse to get the latest versions that are 2014-compatible.
                                Andrew
                                Andrew S.
                                  daniel266
                                  Su team is (i hope9 recieving a lot of feedback, ronen bekerman has a discussion on it involving bertrand also, and here Trimble have Tomot, this guys have a level of importance inside archvis but trimble dont see it that way, Sorry guys but you really need to listen to the customer, Its your software but your customers are asking for something else.
                                  Dont guard your selves behind the well know excuses
                                  Please rethink your plan on this and listen to the ones that pays the bills, maybe JUST maybe your vision on it its blured or what you think is not that accuarate.
                                  • ken28875K
                                    ken28875
                                    Andrew
                                    Thanks Andrew for the help. SketchUp 2014 is working fine now.
                                    For those of you having the same problem, you should delete the plugin folder in this directory:
                                    C:\Users(your name)\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins.
                                    I was not aware of that folder. What I did was just deleting the one from the (C:)-> Program Files (x86), that's why I still got the Bug Splat.
                                    Have a good day!
                                    _KN
                                    Follow Your Dreams.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      It is in the SketchUp Ruby API Release Notes !
                                      The Trimble Team took the time (spent the money,) to author and release this information. It is the user's responsilbility to read the Release Notes for each new version.
                                      πŸ˜’
                                      I'm not here much anymore.
                                      • T
                                        tomot
                                        I don't have a MAC. One of my Customers wants to know where the plugins directory is located on a MAC, for SU 2014 ?
                                        my plugins
                                        tomot
                                        • bmikeB
                                          bmike
                                          Did they move it on the Mac? Otherwise its in Application Support...
                                          • AndrewSA
                                            AndrewS
                                            Your intended clarification may be confusing, as there are multiple application support directories.
                                            The location of the plugin folder for SU8 and before was buried inside the root-level app support folder:
                                            [pre:3fpbb2ln]/Library/Application Support/Google SketchUp 8/SketchUp/plugins[/pre:3fpbb2ln]This is a system controlled (i.e. machine-wide) location that requires root privileges to modify, and is therefore a very unfriendly way of doing things.
                                            For the 2013 release, we moved the preferred plugins location inside the user's personal app support folder. It remains the same for 2014. In that sense, as of the 2014 release, Windows and Mac are now both the same in preferring to have plugins within each user's personal Plugins folder instead of in a shared location.
                                            The full pathname for Mac plugins in 2013 and 2014 is:
                                            [pre:3fpbb2ln]/Users/<username>/Library/Application Support/SketchUp xxxx/SketchUp/Plugins/
                                            aka
                                            ~/Library/Application Support/SketchUp xxxx/SketchUp/Plugins/[/pre:3fpbb2ln] Where of course, "xxxx" is 2013 or 2014.
                                            I believe the code still looks for plugins in /Library as a secondary location, but as is the case with Windows, you really should use the user-specific location instead of the system-wide location unless you have a really good reason to do otherwise.
                                            Andrew
                                            Andrew S.
                                            • 11
                                            • 8 / 11
