Rose Anne Belliveau
A nice build, fantastic to see the build progress as per the real deal.
Astonished as always!
What Elisei said.
Plus, wow! -
Wow, this looks very promissing!
Very impressed! Also like the subtility of blue shadows.
Waiting for progress. -
Impressive detail
Thanks for sharing Marius. Looking forward to seeing the model progress
Thanks guys, and Updates you will get!
Ribs Added and Platforms Removed, Keel is also complete, Temporary Main Deck Planks can be seen but these will be removed when framework is built.
I have an interesting issue that I cant seem to find a solution for, the Hull Planking is done in 1 group, to show in the rendering however each plank needs to be modeled and grouped seperatly, the method Ive attempted was to use the follow me tool starting from the top line with a circle and intersecting it with the hull face, this works for the first 4 planks but after a while the amount of intersections become to much and it becomes a mess.
Im sure a plugin for this must exist, this task can be achived manually but it will take hours if not days, and it will not be used in the final model at all as its just for rendering purposes.... Ideas?
Nice update!
Do you have a picture for explaining the issue? -
Excellent work! I like how you are detailing this and not just glossing over those little things like the stopwater and the deadwood pieces. Are you glad you don't have to search the countryside for grown crooks?
Have you tried 1001 Tools? you're essentially trying to extrude a flat profile along a complex curve... I've used this plugin for complex walkways on bridges with curves a spiral... same thing basically. http://www.1001bit.com
Thanks Chaps, Ewie the Extrusion is already made, it was actually that tool (Create Loft Junctions) that allowed me to draw so many ribs since ship drawings only have a few usually showing.
Here is a small Update, I have not modeled the deck framing showing the Horizontal knees as this is quite a task and will again not be used in the final model, Knees seen below will be in the final, keel still needs some Pieces added on top of ribs to finish off.
Looking Aft
Looking Forward
In the next Update I will explain my previous issue in detail.
It would be great to see an animation of this.
Hull is fully Planked ( Each Plank can not be shown unfortunatly ) , Work on the Accomodations have begun, Decks are in place and a few other bits and pieces added.
Amazing!
Have you a site where we can see your other works? -
Had the same problem with my Viking boat. Made a .png side view with planks drawn in and then projected onto the hull. Not too bad from a distance.
Bob, that's a nice Viking boat. Is it modeled after a specific historical example? Did you shape the hull with the hollows near the stern?
look's great!
Wow.
Incredible work.
Does that answer your question? Not sure what you mean. Based on the Oseberg ship. Looks cool, but not for the ocean. A replica sank twice in moderate weather.
