    2014 Make edit material MAC
    36 Posts 8 Posters 5.0k Views 8 Watching
      mwm5053
      Ok works now must have been a permission thing like Dave said but thanks Dave and John 😄
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • H
        Hendrik_G
        I'm having the same "Failure to Save File" issue when I tried to edit any of my textures in SU2015 running Mac Yosemite. I've read this discussion, and I'm still unable to resolve my issue. I'm hoping someone can help me or let me know what I'm missing. I've tried the following:
        When, as suggested above, I entered this into SU's Ruby Console:
        = ENV["TMPDIR" + "com.sketchup.SketchUp 2014." + ENV["USER"]
        UI.openpanel(path, path)]
        I received the following error: %(#FF0000)[Error: #<SyntaxError: <main>: syntax error, unexpected '='
        = ENV["TMPDIR"] + "com.sketchup.SketchUp 2014." + ENV["USER"]
        SketchUp:1:in `eval']
        I searched and found "com.sketchup/SketchUp 2015/" in this location:
        Library/Caches/com.sketchup.SketchUp.2015/
        I've attached a screenshot of the contents of this folder.
        I confirmed in the Get Info window that my user had Read/Write access to that entire folder path and the contents within.
        I'm still having issues. Any help would be greatly appreciated.
        • jeff hammondJ
          what application are you trying to use for your external editor?
          i haven't read through the thread but i did see pixelmator mentioned and in its case, the default setting is to open any file in its .pxm format instead of .jpg/.png/etc..
          so, if your external editor is opening/converting the file, it won't save back into sketchup properly..
          in other words, i don't think this is a permissions issue. (not ruling it out.. just check some other stuff first)
          • H
            Hendrik_G
            I didn't have an application specified. I just tried specifying Photoshop CC, and then Preview - no change.
            I think the problem your describing would potentially be an issue if I could even get the image to open. The problem is that I right click a texture, select "Edit Texture" and receive the error message "Failed to Save File" and nothing opens.
            • jeff hammondJ
              for clarity.. you do have an editor assigned at SketchUp-> Preferences-> Applications ,right?
              • H
                Hendrik_G
                Yes, I have tried assigning both Photoshop and Preview
                  slbaumgartner
                  Not sure about the root cause of your issue, but the problems with the code above are that you missed part of it and need to alter it for 2015:
                  <code>
                  path=ENV["TMPDIR"] + "com.sketchup.SketchUp.2015." + ENV["USER"]
                  File.writeable?(path)
                  </code>
                    driven
                    check if SU agrees with you about which editor to use...
                    %x(defaults  read  com.sketchup.SketchUp.20#{Sketchup.version.to_i} "Preferences").match(/"Image.+$/)
                    mine defaults to 'Preview' if none is set...
                    post your result, and we can go on from there...
                      driven
                      There is definitely a 'trick' to to using with 'Preview'...
                      the catch 22 is I can't save or navigate to where SU places the file for copying because 'Preview' considers it a 'no go' area...
                      however, if I put that folder in my sidebar, I can navigate to it from 'Preview', 'click' on the same name image [to fix the name], then save...
                      to get the folder into your 'Sidebar', run this and 'drag' the 'com.sketchup...' folder to the sidebar...
                       path = ENV["TMPDIR"] + "com.sketchup.SketchUp.20#{Sketchup.version.to_i}." + ENV["USER"]
                      %x(open -R "#{path}")
                      not sure what happens with photoshop...
                        driven
                        on a mac copy paste this into 'Rudy Console'
                        and keystroke enter/return
                        UPDATED: should now work for any 20+ version of SU...
                          driven
                          @dave r said:
                          the folder that is being created is a temporary one but I wonder if the problem, Walt, is that one of the container folders needs Read and Write permission granted.
                          @Dave && @walt
                          that folder is ok, but you can confirm with
                          #UI.openpanel(path, path)
                          File.writable?(path)
                          @Walt, have you re-added an editor to 'Preferences' , mine is failing with 'Graphics Convertor' and 'Preview', but works with 'Image Tricks'
                          • H
                            Hendrik_G
                            SU agrees. I have Preview assigned in Preferences and this was returned in Ruby Console:
                            "Image Editor" = "/Applications/Preview.app"
                            • H
                              Hendrik_G
                              This allowed me to navigate to the folder, however there no images in there for me to open (see attached screenshot).
                              • H
                                Hendrik_G
                                @MWM - what did you do exactly that fixed your issue? I think I have the same issue that you were experiencing.
                                  driven
                                  something you could try...
                                  your screenshot shows a 'doc thumbnail.png' in the temp folder...
                                  double click it and see if 'Preview' asks for permission...
                                    slbaumgartner
                                    I noticed that SketchUp reports ENV["TMPDIR"] as starting with /var. That path is actually a link to /private/var. I wonder if you have a permissions tangle involving that link? Try ls -l /var in a Terminal and see what permissions it has. I get
                                    lrwxr-xr-x@ 1 root wheel 11 Nov 26 16:26 /var -> private/var
                                    Steve
                                      driven
                                      considering that SU is having no issues writing other stuff to that folder, and that is the fail point in this case, the permissions issue may be with the actual 'material' path...
                                      what is the path to the material your trying to edit?
                                      do any from your User material folder work?
                                      or SU Materials folder?
                                      I remember having to change permissions on downloaded materials in the past as they have a 'downloaded flag' on them...
                                      thinking out load..
                                      • romboutR
                                        rombout
                                        Im seeing this problem on a model in su2015. Ive added permission, a second admin "read&write", didnt help. I also set "everybody" as a test to "read&write", also didnt help.
                                        Are there any options left? Ive used this item before with issues.
                                        using osx 10.11.2
                                        • romboutR
                                          rombout
                                          My work around for now is using UV tool on a simple plane and export this as OBJ. The tex file will be set aside of the OBJ... Voila! Eat this SU!
                                          id did add this URL as file name, some windows path of the original builder. Perhaps this causes issues. I think those forward and backward slash at the beginning cause problems on mac
                                          "C/\Users\Adam\Documents\Adam Models\SpringLeafBoxwood01.png"
                                          • 2 / 2
