    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • U Offline
      unclex
      my problem is still there
      perhaps because this:
      My system is Win7X64Chinese, but I installed su2014en
        So you finally tell us something that might be useful. 😒 You're right. It could be that's the cause.
        • F Offline
          fantoosh420
          Did you tried the technique i discribed? Please follow exact process and after installing each rbz, restart sketchup 2014. this would help us nail exact reason. It would be good not only for your case but also for larger cause. Sketchup is going through a lot of changes these days and its plugins too has to cope up. Figuring out exact cause would help people who are not so good with these frequently changing folder structure and nomenclaure of sketchup and/or its plugins and hence are making mistakes.
          Sketchup 14.0.4900
          Core i5 760 @ 3.00 Ghz. 8 GB RAM windows 7 SP1 X64
          • U Offline
            unclex
            I Tried
            Even only One Libfredo6 Plugins.....
            • fredo6F Offline
              @guanjin said:
              @guanjin said:
              Check the update click to view is invalid
              [attachment=0:1vizsrck]<!-- ia0 -->QQ图片20140226194556.jpg<!-- ia0 -->[/attachment:1vizsrck]
              Selection boxes have become such a big,sketchup8 and 2013 are so。
              5.6 and 5.7 are like this, 5.4 no problem 。
              guanjin,
              You probably checked the box "Retina screen" in the default parameters of LibFredo6. This is why.
              • U Offline
                unclex
                OK
                I Fix it
                In This File: Lib6PluginDialogs.rb
                I replaced all the left or right ‘’ to “
                • guanjinG Offline
                  guanjin
                  guanjin,
                  Thank you, understand 😍
                  • tt_suT Offline
                    tt_su
                    @dave r said:
                    Unc, I think you still haven't got the current version or is it possible you have some strange characters in your user name? There are some characters that aren't allowed.
                    non-english characters should not be a problem any more as Ruby 2.0 should be able to handle that.
                      macguru63
                      Hello. I can't seem to get some of fredo plugins to work in Sketchup 2014. I am able to load LibFredo6 v5.7a from sketchucation but as soon as I try to load any of the plugins I get errors like the attached photo: And then the following:
                      Error Loading File /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale/loader.rb
                      Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
                      !LibFredo6/Lib6Core.rb:594:in effective_load_part2' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:541:in effective_load'
                      /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_FredoScale/loader.rb:1:in <top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                      /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:435:in register_extension'
                      !LibFredo6/Lib6Core.rb:435:in load_from_config' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:726:in block in load_all_plugins'
                      !LibFredo6/Lib6Core.rb:726:in each' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:726:in load_all_plugins'
                      !LibFredo6/Lib6Core.rb:438:in load_from_config' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:181:in startup'
                      /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:299:in <module:LibFredo6>' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in <top (required)>'
                      Error Loading File Fredo6_!LibFredo6.rb
                      /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:776:in signal_error_in_loading' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:226:in after_startup'
                      /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:184:in startup' /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:299:in module:LibFredo6'
                      /Users/geekdad/Library/Application Support/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6.rb:31:in `<top (required)>'
                      What can I do?
                      John
                        tranvananh88
                        thank you
                        • Bob JamesB Offline
                          Bob James
                          Loaded latest version of Fredo6_!LibFredo6, but still get error messages for two plugins.
                          It makes no difference if I load it into my default directory
                          C:\Users\jamesb\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                          or my 'additional folder'
                          D:\Dropbox\Plugins
                          The plugins themselves are all loaded into
                          D:\Dropbox\Plugins
                          • fredo6F Offline
                            Bob,
                            Could you check the About box of LibFredo6.
                            Looks like you did not succeed to install LibFredo6 5.7. Did you try to do it via the Plugin Store Tool?
                              pcc0128
                              Hiya,
                              I have same problem of loading Libfredo6 5.7a on skp 2014 too,
                              But i found when i open file,which saved in non-system partition or NAS disk,
                              the problem will show up.
                              I've tried copy file and put it on desktop or anywhere in system partition,
                              it won't show any errors, any ideas?
                              • tt_suT Offline
                                tt_su
                                There's a but in SU2014 where when you launch SketchUp via clicking on SKP file on a drive SketchUp isn't installed to some paths are not set correctly and part of Ruby isn't initialized properly. Though so far I've only seen plugins using the Standard Library fail due to this... Fredo, are you using the StdLib?
                                We are working on a fix, but won't have a good workaround at the moment - other than launching SketchUp via it's main desktop shortcut instead of via SKP files.
                                  pcc0128
                                  Thanks tt_su, launching Sketchup and open file in application,
                                  everything works fine.
                                  I think it should be a temporary solution to avoid the error.
                                  thanks again
                                  • fredo6F Offline
                                    None of my plugins use stdlib.
                                    And I don't get an error with SU14 when I open a Skp file from the desktop.
                                    • tt_suT Offline
                                      tt_su
                                      If the file is on the same drive as where SketchUp is installed everything will work fine. It's when the SKP is located on a drive other than where you installed SketchUp the error occur.
                                      • fredo6F Offline
                                        That's the case
                                        Sketchup is installed on 😄
                                        The skp file is on 😧
                                        I am on Win7 64bits
                                          c65m3zxt
                                          Error: #<ArgumentError: invalid byte sequence in UTF-8>
                                          C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6PluginDialogs.rb:689:in `[]'
                                          I just fixed a similar UTF-8 encoding issue with the v5.7 version on a 64bit Windows 7 machine. It seems that the "copyright" symbol in the file comments is not correctly encoded and Ruby trips over this. I fixed it by replacing
                                          IO.foreach(file) do |line|
                                          with
                                          IO.foreach(file, ;encoding => 'iso-8859-1') do |line|
                                          in line 201 in Fredo6_!LibFredo6.rb and again in line 366 in Lib6Core.rb. Not sure if this is the right way to do it but it works for me right now.
                                          Cheers,
                                          tbleicher
                                          • tt_suT Offline
                                            tt_su
                                            with
                                            Cheers,
                                            tbleicher
                                            Yea, many of the encoding errors with migrating plugins is that files have been saved in ANSI (ISO-8859-1 or similar) which will make any of the characters in the 128-255 range raise an error as it leads to invalid UTF-8 which Ruby 2.0 expects by default in SketchUp.
                                            changing the encoding of the file operation is one solution, but the best one is to re-encode all the files into UTF-8 (where the copyright will be multi-byte). Then you'll only have to deal with one encoding. Juggling different encoding is all too prone to creeping errors.
                                            • 87
                                            • 88
                                            • 89
                                            • 90
                                            • 91
                                            • 109
                                            • 110
                                            • 89 / 110
