    Automated Excel 2 SketchUp PLUGIN
    35 Posts 28 Posters 147.2k Views 28 Watching
      danielrohde
      Hi Faraz,
      Great plugin, thanks a lot for sharing!
      This could be really useful for me if the multiple component option works, what is the status on that? Looking forward to the next version...
      Daniel
        Lasagne = hedgehog ? 😉
        I guess you could have hedgehog lasagne. I wonder how many it would take to feed a family of four 😄
        Interesting plugin idea. Hmmmm....
        • mitcorbM
          mitcorb
          Just asking:
          Should the title of this thread follow the format for other plugins? Like [Plugin], beta or not, numerical revision, date?
            skillz
            farazforoozan,
            Thank you for developing this script! There's a lot of potential here, specially if you get pretty savy with the excel formulas. I am personally hoping to use this as a space planning tool.
            It would be awesome if by simply imputting an area (M2, geometries can automatically be created. Also if the boxes can automatically be color coded according to a type or name.
            great job! do you plan to continue its development?
            Would you be open to collaboration on this particular script? I am not all that savy with code, but have very specific ideas on what I hope it can do. Please let me know if you can share your script and collaborate.
            • F
              farazforoozan
              Added a new rar file because the loader script is messing up a little bit. Soon I will be adding new options to the plugin if you have any good improvement advice I'll gladly hear it and consider it.
              • F
                farazforoozan
                New tutorial video on my youtube channel.
                • K
                  Karljohan62
                  @farazforoozan said:
                  Update: now the input rotations also work. The file is now downloadable as an extension package. You install the package via Sketchup.
                  Hi and thanks for sharing this plugin with us.
                  I am new to Sketchup and I just wonder how the extention cab install via the Sketchup since the script has a .rbs ending and the only extention files Sketchup 2013 accepts are .rbz.
                  Is there something I have misunderstood here.
                  Cheers!~jmk
                  • massimoM
                    massimo Moderator
                    .rbs is a "scrambled" version of .rb, so you can just unzip the folder and put the content in SU's plugins folder like you do with a "normal" .rb file.
                    Also .rbz is a zipped .rb, so if you want you can rename it as .zip and then unzip it and put the content in plugins folder.
                      I wonder where this notion comes from. You aren't the first person who has written that here on the SCF forms. It isn't true, though. As Massimo wrote, you can drop the .rb file directly into the Plugins folder and restart SketchUp and it'll work.
                      In order to install the plugin via the Install Extension button, you do need a .rbz file.
                      You could rename the zip file to .rbz and use Install Extension, too.
                        richyeah
                        Does anyone know how to get this working for SketchUp 2014?
                          Jim
                          Because the source is scrambled, so no one can fix it except the author.
                          I've sent a message to the author about upgrading the extension, and hopefully he will reply here
                          In its current form, there is no reason to install this in 2014 because it will never work.
                          • duanekempD
                            duanekemp
                            Can this be used to select/deselect layers on scenes?
                            For example: Keyframe animation of 400 frames at 25 fps. Animation is perfect. I want to add a blinking light on/off every half second. Can this be used to add that light component on/off to a group of 14 frames and off for 14 frames via this type of programming?
                            Duane Kemp
                            Kemp Productions
                            Puidoux, Switzerland
                            Gallery:
                            https://duanekemp.artstation.com/
                              danxx
                              I would like to see this in action on 2015. Can I contact the author. please email me on mr.dpg[at]virgin.net
                              • aadbuildA
                                aadbuild
                                Hi guys this is cool. We just added excel export to Plusspec. There is a webinar on tomorrow at http://www.plusspec.com of you'd like to check it out.
                                Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                https://www.plusspec.com
                                • U
                                  unearthed
                                  Great work Faraz, Can't wait to see how it runs
                                  Growplan - People ∩ Plants ∩ Place
                                  windows 7 64b, 4GB RAM, SU 8.0.16846
                                  Gimp, QGIS, Vectorworks 12, Bricscad 11
                                    mgsvinc
                                    Hello, i would like to use your plugin to control the positioning of my models.
                                    The objects remain the same (there is no change of dimensions within those objects), the only values which I want to pilot from Excel are the positioning of these objects.
                                    Could your plugin help me do this ?
                                    If not, do you know a way to do this with your plugin (maybe by modifying the code)?
                                    Or even better, do you know a plugin that can do it ?
                                    Thank you for your time and for your work.
                                      Sekar24
                                      Hi, I am unable to use, as there was no menu in su 2017
                                        jackmartian Newcomers
                                        gb whatsapp
                                        May be I think you can adjust keyframe little bit more instead of 25 fps.
                                          seosambad Newcomers
                                          There are many state sponsored game in India like Kolkata Fatafat and Lottery Sambad .These games are legal in 13 states of India and conducted by state governments. Lottery Sambad is the biggest one of these games.
                                          • V
                                            vcbhfg Newcomers
                                            GB WhatsApp Download is one of the most popular WhatsApp mods for your device. This WhatsApp mod is a multi-account-friendly mod and much more.
                                            GB Whatsapp Apk allows users to share their current location with friends. To begin with, you can use the option of automatic reply whenever you wish to respond to friends.
                                            One of the most exciting features of GB Whatsapp Latest Version is the ability to purchase and use company-created themes.
