    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 375.1k Views 57 Watching
    • fredo6F Offline
      NEW RELEASE: Curvizard v1.7a - 15 Feb 14
      Curvizard 1.7a fixes a major bugwhich was present in v1.6a, whereby the vertex marks and tooltip for number of segments were no longer displayed. It is advised to upgrade to v1.7a.
      See main post of this thread for Download of Curvizard.
      • fredo6F Offline
        NEW RELEASE: Curvizard v1.7b - 16 Feb 14
        Curvizard 1.7b fixes a major bugwhich was present in v1.6a, whereby the vertex marks and tooltip for number of segments were no longer displayed. Then, a bug was introduced in v1.7a So, it is strongly advised to upgrade to v1.7b.
        • jeff hammondJ Offline
          i did notice another peculiar behavior which occurs once lines have been welded but it's going to take me a bit of time to get the appropriate screenshots/description together.. and i don't have that much time right now.. if i don't get to it tonight, i'll post tomorrow
          thanks
          i'm not sure if you changed something in 1.7 but for the most part, the problem i was seeing almost went away.. it had to do with me welding multiple curves at once.. for example, using the partial sphere i uploaded a couple of weeks ago, i'll often need to weld all three perimeter curves.. the way i was using curvizard at that time was-
          • start curvizard Make Curves
          • click on each of the three curves
          • click on the green check box (or elsewhere to validate)
          • exit tool
          which would result in all edges being welded as one.. i'd then use lines from each corner to break the single curve into the 3 individual curves.. this is where the problem arose.. upon breaking the curve at the corners, some of the vertices along the desired curves broke up as well.. this doesn't happen as often anymore.
          h o w e v e r
          i realized yesterday i was using the tool wrong 😳 ..there's actually a much easier way to get the final results i was looking for with curvizard.
          • start Make Curves
          • click on one of the three curves
          • validate it
          • click on another curve
          • validate
          etc until i've selected all the individual curves i'd like to weld then exit the tool..
          validating each curve as i go will keep them separate once i exit the tool.. eliminating the need to break the single curve into smaller pieces afterwards.
          (so you, fredo, i'm sure already know this since you designed the plugin.. i'm just outlaying the issue i had in case someone else has the same problem)
          • fredo6F Offline
            Jeff,
            You're right. This should be highlighted.
            You must use the separator when you have to weld adjacent contours. This separator is the blue arrow in the small button palette near the cursor (alternatively you can just click in the empty space). Then you can make the curves by clicking on the green checkmark. This is more or less the same behavior as Curviloft when you select contours.
            Note also that you can preselect a curve, and then invoke Curvizard > Make Curve via the contextual menu. In which case, it will weld the selected contours and exit (this behavior can be configured)
              @fredo6 said:
              Jeff,
              i'd almost say it'd be better if it defaulted to splitting at adjacent contours then require the user to do something if they want the adjacent curves welded as one.. simply because a user (or, me at least) will more likely want each curve which fits within their specified follow mode angle to be its own curve.. as is now, the follow mode angle controls the selection but it doesn't control the separation unless a user manually tells it to separate.. (fwiw, i personally do have uses for welding the adjacent curves as one.. it's just that those situations happen much less often)
              regardless, it doesn't matter to me anymore because i've figured out how to separate the curves.. it's just that it wasn't intuitive to get to that point.
              (but, i admit, i never read the user manual in which i imagine this is outlined.. i rarely do 😳 )
              oh.. right. i have W for 'make curves' shortcut.. if i have the edges preselected and push W then the selected lines weld.. if i don't have a pre-selection then the HUD comes up and i have access to follow mode etc..
              i use both
              • fredo6F Offline
                For the invokation via contextual menu, I dicover a small bug, whihc is harmless but produces error logging in the Ruby console.
                I have fixed and will republish.
                For the automatic splitting of contours, that's a diffcult question because you may well want to weld a contour presenting sharp angles. This is why the interactive mode exists.
                  yeah, i was trying to think of a UI way which would allow the curves to be split at the follow mode angle while giving the user an option to weld adjacent curves..
                  it seems like thing would start getting confusing and/or too many options.. it's good how it is.. i'm just happy i figured it out now 😄
                  • fredo6F Offline
                    NEW RELEASE: Curvizard v1.7c - 16 Feb 14
                    Curvizard 1.7b fixes a major bugwhich was present in v1.6a, whereby the vertex marks and tooltip for number of segments were no longer displayed. Then, a bug was introduced in v1.7a and then another one 1.7b. So, it is strongly advised to upgrade to v1.7c.
                    • fredo6F Offline
                      NEW RELEASE: Curvizard v1.8a - 04 Mar 14
                      Curvizard 1.8a introduces an Auto-extension feature for Make Curve, as illustrated in the video below. This was requested by a few users.
                      1. You can configure the Auto-Exit in the Default Parameters dialog box for:
                        • contextual menu
                        • when Curvizard is launched on a pre-selection
                      2. When you pre-select one or a few edges, Curvizard MakeCurve will try to extend the edge(s) by continuity, then make the curve(s) and Exit.
                      [flash=425,344:u7pfpgu4]http://www.youtube.com/v/ZJrSoyhnK6E&hl[/flash:u7pfpgu4]
                      • BoxB Offline
                        Fredo, you are a God!
                        • cottyC Offline
                          cotty
                          Great and very helpful update. Thank you!
                          my SketchUp gallery
                            rilian
                            I recently updated to the latest version (Sketchup 😎 and I'm having difficulties. The previous version (honestly not sure which one I had) allowed me to pre-select any edge or edges, launch the tool from the toolbar, exit the tool and they would be immediately converted to a curve. VERY handy, quick and intuitive.
                            Since I upgraded to 1.8a (w/ libFredo6 6.0b), things seem to not work as expected. Take the attached pic as an example.
                            It shows a simple object that is 3 edges created w/ the rectangle tool. The 4th edge was erased and replaced w/ an arc pointing in the Blue direction. It may be tough to see in the screenshot but 2 of the edges are on the green and red axis respectively.
                            In any event, If I select one of the straight edges and launch curvizard's weld function from the GUI or the context menu, it welds all 3 edges + the curve into one big curve rather than turning the pre-selected edge only into a curve.
                            If I use the GUI to manually select that edge after launching (even though it was pre-selected), it will convert it but the arc gets exploded into it's component parts even though the arc wasn't pre-selected. If I then weld the arc back to together, the previously converted edge reverts from a curve back to an edge. None of this happened w/ the previous version I was using. It's very frustrating.
                            The only way I have managed to get around this problem is to copy any edge I want to transform away from the other geometry then run curvizard's weld function, then delete the original edge and replace it w/ the one now made into a curve.
                            What happened in between? What has changed? Am I doing something wrong with the new version? This seems far more cumbersome than it was before...
                            I'd appreciate any advice...
                            Thanks,
                            Rilian
                            <Edit> I should note that I just discovered that if I launch the plugin Without any preselected edges, then select only one of the straight edges seen in the attached pic, it transforms correctly w/o breaking the arc into segments. Why doesn't preselection do the same?
                              SketchUp 8 isn't even close to the latest version. Before going on, why don't you really install the latest version which is SketchUp 2014?
                              • fredo6F Offline
                                @rilian,
                                The latest release includes an auto-detect mechanism on the pre-selection for MakeCurve. Curvizard prolongs the edge until it reaches a crossing or a sharp angle.
                                This feature was requested by many users.
                                I'll check the détails and republish a version where these options are more explicit and can be activated / deactivated.
                                  rilian
                                  @Dave
                                  Apparently I wasn't clear. I updated to the latest version of Curvizard. I know sketchup 8 isn't the latest sketchup.
                                  @Fredo - Thanks for the reply...
                                  • fredo6F Offline
                                    NEW RELEASE: Curvizard v1.9a - 19 Oct 14
                                    Curvizard 1.9a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                      Penelope
                                      Help! I just used the SCF Plugin tool to install both Curvizard and LibFredo06 (in SU 2015 Pro).
                                      Get the following error: Curvizard 1.9a: Error starting up plugin (creating menus and icons) undefined method 'declare_topmenu' for #<Traductor::Plugin: etc. etc.
                                      Please help. I need to use this plugin for a project I'm doing this weekend.
                                      Thanks very much in advance!
                                        Penelope
                                        Please ignore my post of a few minutes ago. I finally got this plugin to work by restarting SU another time!
                                        • LucideL Offline
                                          Lucide
                                          Thanks Fredo for all your hard work.
                                          I want to ask you about a problem that i have with Curvizard 2.0a on sketchup 2016.
                                          Both Curvizard and Libfredo are updated. (i checked with the sketchucation store v3 and with your tool)
                                          Every time i clic on any button, sketchup acts as i clicked on "undo" (like ctrl+z).
                                          This hissue happens only on Curvizard, but with almost any button.
                                          Do you know what could be the problem? 😮
                                          Thanks,
                                          Lucide.
                                          ps. i don't speak english very fluently 😳
                                          • LucideL Offline
                                            Lucide
                                            **Update:**i reinstalled sketchup (actually, i reinstalled completely windows) and i replaced it with the 2017 edition, but this problem is still occurring! Help, it makes the entire tool unusable, and i was used to work so much with it...
                                            • 7 / 10
