    Face View
    25 Posts 6 Posters 1.5k Views 6 Watching
      Mikehd70
      hi
      Need some help is there a way to lets call it snap to different faces of the item you are drawing,reason i ask is i seem to think i am busy with the red view but when i rotate the view my dimensions are floating in the air,and that is another problem i have,only way i can place dimensions is if i first use the tape measure to place line.EG can lock to edge of circle but will not lock to side of board even though the distance is what i used to place circle.
      So any help on either problem
      using ver 8 at the moment
      i use it for woodwork so no fancy drawing
      • cottyC Offline
        cotty
        Do you have a screenshot of your problem?
        my SketchUp gallery
        • BoxB Offline
          Yes an image of your problem would certainly help as it's not quite clear.
          But at a guess it sounds like you are trying to place dimensions on faces but the tool needs an edge to work from. The tape tool is placing a guide for you to measure from, in other words it is creating an edge that the dimension tool can use.
          • mitcorbM Offline
            mitcorb
            And my guess is that you need to work with established Scenes, or the standard Views. The dimension tool as well as the plain text tool will float all over the place when you orbit.
            Do you work in Parallel Projection or in Perspective?
            • BoxB Offline
              You need to use the Inferencing system of Sketchup to get it to work properly.
              The tool will click to certain points, edges or guides. By hovering on the semicircle you should get the center inference point. Click the center point then the corner of the rectangle. This lets you place the dimension in either direction.
              Here is a quick video, I was describing what I was doing but didn't record sound so it seems to jump around a bit for no reason.
              [screenr:2qtz0w9l]1EBN[/screenr:2qtz0w9l]
                Mikehd70
                Thanks will try that but i think i did when i used the tape,but cant remember right now
                  Mikehd70
                  Ok
                  so now i got the upload thing to work
                    Mikehd70
                    OK found how to view the faces "Standard Views"
                    what i find strange is with dimensions it happy with one or the other but soon as i use the tape then it will work with both.and give me the size.
                      Mikehd70
                      Thanks for reply
                      i work in Perspective
                      established Scenes, or the standard Views ?? need some info on this
                      https://www.dropbox.com/sh/c0frwbigg3btpmy/xI6MlKg-nN#lh;null-sketchup.jpg
                      hope this works did prt scr then copied to public folder in dropbox
                      where you see the 37 is where it wont work you can do the half circle (goes blue) but edge no joy but works with tape as i said.
                      • BoxB Offline
                        I don't understand what your issue is.
                          Mikehd70
                          With dimensions i cant "just" use the tool in some places i need to use the tape first to give it something to connect to and others it is fine
                          • cottyC Offline
                            cotty
                            As Box wrote make sure you use one of the many inferences...
                            my SketchUp gallery
                              I wonder if you've got an exploded arc at one end so inferencing doesn't have a center point to snap to. If you posted the SKP file it would be easier to sort out the problem you're having.
                                Mikehd70
                                will find the file
                                i now have another problem unless i am not seen the right thing but i cant see
                                (Menu) Window → Settings → (Option)
                                as asked for this is one that i have a problem with try lower slot
                                • cottyC Offline
                                  cotty
                                  @mikehd70 said:
                                  ... but i cant see
                                  Are you searching for "Preferences"?
                                  my SketchUp gallery
                                  • TIGT Online
                                    I don't understand what you are trying to do 😕
                                    But anyway...
                                    On a PC it's under SketchUp's menu: Window > Preferences...
                                    On a MAC it's under the menu item SketchUp > Preferences...
                                    Then go to whatever sub-panel you want in the Preferences dialog - like 'Extensions'...
                                      I found two issues that would make dimensioning the slot difficult. First, the guide point you placed isn't at the center of the arc at the bottom of the slot. The vertical dimension ends more closely to it but it's still not on center.
                                      There are two options. The easiest and most straightforward would be to use SketchUp's inferencing to locate the center of the arc. To do that, hover over a vertex on the edge of the arc for two seconds before dragging the cursor toward the center. When you get close the cursor will snap to the center and you should get a pop up message indicating that. Click there to set the point. You can do that for either the first end of the dimension or the second.
                                      One thing that will help is to make sure you're using Zoom and pan as needed to be able to get at what you're dimensioning. For the length of the slot, zoom in to one end to start the dimension and then the other to finish it. Use the CMB and mouse wheel for navigating so you don't wind up dropping the dimension tool inadvertently.
                                      An alternative would be to use Point at Center from the Ruby Script Examples plugin (see the Extension Warehouse) to place a guide point at the center of the arc.
                                      The other problem I found is that the curve at the top end of the slot is not recognized as an arc. I replaced it with a proper arc and used inferencing on both arcs to get their centers and correctly dimension the length of the slot.
                                        Mikehd70
                                        Thanks for the info i installed the plugin works ok with circles,arc so now what do i use to get the edge to be found wit the dia. tool zoom in that i can see the arrow going round the edge and it still wont lock on. replaced the arc,s measure from center to center no problem but to edge no joy
                                        • BoxB Offline
                                          Did you watch the video I made.
                                          The dimension tool wont lock on to the edge, but it will to the corner.
                                          Click one end on the centre point then the other end on the corner of the rectangle then slide the dimension up or across to where you want it.
                                            Mikehd70
                                            Thanks again for the help went and watched again now it makes more sense,still strange why it wont use an edge like all cad programs do need to just change how my brain works in SU.
