    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.2k Views 175 Watching
      This is most strange. πŸ˜•
      I have just repeated all of your steps...
      It reinstalls and works fine after a restart [just in case something was adrift]...
      That RBZ's version of deBabelizer.rb IS the newest, and therefore compatible - I converted it a few months ago...
      BUT your file says 02/12/2013 AND that IS the current file ?
      Try this known-to-work version [install from the attached RBZ]...
      Restart SketchUp to retest...
      If this fixes, then it the mystery deepens...
      BUT at least you'll have a working version...
      deBabelizer.rbz
        PS:
        Can you attached your version of deBabelizer.rb that is raising the issue on your system, so I can compare it with the 'real' [working] one that you should have...
        Can you also check that you have FULL security permissions to the Plugins folder...
        It should be set automatically...
        • chriC Offline
          chri
          @tig said:
          PS:
          deBabelizer.rb
          • chriC Offline
            chri
            @tig said:
            PS:
            i dont know how to do this πŸ˜•
              That IS the correct file.
              It should NOT raise a UTF8 error...
              It is correctly encoded...
              It works for me.
              It works for others...
              Weird...
              Incidentally, don't confuse the subfolders containing some files that are shipped with SketchUp v2014, with the main Plugins folder that is now located in your Users account...
              Security... http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
              • chriC Offline
                chri
                I have seen this and make an announcement on the french forum
                here :
                http://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=56469
                chri
                • jiminy-billy-bobJ Offline
                  jiminy-billy-bob
                  here :
                  There's a french forum?!
                  I don't have access to it, how can I?
                  • BoxB Offline
                    In your user control panel go to the usergroups tab and select Francias.
                      @Chri et al
                      The ' Application Data' Plugins folder-path is NOT the folder-path into which YOUR Plugins should normally 'go'. πŸ˜•
                      You will not be able to install or manage these files, unless they have FULL security permissions to that folder-path [which is unlikely, as it's very limited by default, and also difficult to reset too]. 😲
                      C:/Documents and Settings/USERNAME/Application Data/SketchUp/SketchUp 2014/SketchUp/Plugins
                      There is a also a similar path, which is actually pointing to the same folder...
                      C:/Documents and Settings/USERNAME/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                      This path could also have restricted permissions... πŸ˜’
                      BUT every user gets their own fully accessible Plugins folder-path. πŸ˜„
                      Where you can install and manage your plugins files - you will automatically have FULL security permissions using that folder-path.
                      That ' Users' Plugins folder is the default one...
                      To find your very own Plugins folder use this in the Ruby Console:
                      Sketchup.find_support_file('Plugins')
                      It will return something like this:
                      C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins
                      Although it is effectively the same folder as the Application Data || /Documents and Settings/../AppData ones again - using this path you automatically get proper FULL permissions...
                      If you have tried to install Plugins into an alternative Plugins folder-path [even if in reality it is pointing at the same Plugins folder], in all likelihood you probably do not have FULL security permissions when approaching it down that folder-path... 😞
                      So the chances are you have once again started the specter of the 'VirtualStore' / 'Compatibility Files' fiasco, which was meant to be avoided by the improved Users Plugins folder introduced in v2014... πŸ˜’
                      So please use to the usual C:/Users/../Plugins path... πŸ€“
                        Here's an update http://sketchucation.com/pluginstore?pln=ExtrudeTools
                        v2.4 now includes ALL lingvo files in a v2014 compatible encoding.
                        • chriC Offline
                          chri
                          Hi TIG
                          Now , it works for me πŸ‘
                          Thanks a lot
                          Chri
                            Yes it was an odd one. πŸ˜’
                            SketchUp v2014's Ruby2.0 demands that scripts are in UTF8-without-BOM encoding.
                            I had previously updated all of my files and reissued them - or so I thought...
                            Somehow a few rogue lingvo translation files got through the net - they were in the now unacceptable ANSI format - particularly the FR ones - so I assume the person translating them for me must have used a new empty Notepad file and copy+pasted into it, rather that a straight copy of the EN-US version which was already correctly encoded. πŸ˜•
                            These files caused no issues, unless your locale was FR - in which case there was the loading error because the file could not be read into v2014.
                            I have now been through all of my scripts that have lingvo files and corrected the encodings and republished, so hopefully this little glitch is behind us... πŸ˜„
                              DCorral
                              This is the first plugin i download here and its amazing, i'm just a little bit lost since i seem to not be able to find the toolbars... can i get some help with this please πŸ˜„ (sorry if i reposted btw)
                                DCorral
                                @rich o brien said:
                                Try this: Enable the toolbar in View>Toolbars. Pull all of the toolbars off the top rows. Does the Extrude Tool toolbar show up in the upper left corner? If so, you have now found it and can place it where you need but you really ought to install the current version of SU2013. there was a bug in the first release that caused new toolbars to appear under the existing ones. It was fixed though.
                                Dave earlier mentioned this...
                                To me it looks like this is related to the bug Dave flagged.
                                What happens when you check for update under the Help menu?
                                Seriously best easy way to solve it thanks πŸ˜„
                                • OxerO Offline
                                  Oxer
                                  I have installed ExtrudeTools in SU 2013 & 2014 on Mac and the plugin works fine but there is a problem with spanish translation, all lingvo files are in UTF-8, I haven't modified them, the translation works ok in Menu, tooltips of the toolbar and Extrude Edges By Offset tool, the rest no.
                                  This is very strange, do other users with the same problem?
                                  Mac OSX 10.9.2, SU 2013 & SU 2014, no messages in Ruby Console.
                                    @Oxer do you have the very latest set ? v2.4.
                                    I had to do an update because some of the lingvo files were encoded incorrectly...
                                    If I understand you correctly...
                                    The translations works in Menus, Toolbars' tooltips and all text for the 'Extrude Edges By Offset' tool.
                                    But nowhere else in any of the other 'EEby' tools πŸ˜•
                                    To double-check I swapped all of my EN-US lingvo names for ES...
                                    I confirm that oddly the translations work as you set out.
                                    For some reason I can't see the dialogs etc in all but the Offets tool remain in English, although checking for the strings in the rb and lingvo files shows a proper match...
                                    BUT I HAVE NOW found the errors in the coding... πŸ˜•
                                    I'll issue an update to fix this asap... πŸ˜’
                                      Here is an updated version in the PluginStore, v2.5.
                                      It fixes various longstanding, but previously unreported, glitches with some of the lingvo files...
                                      • OxerO Offline
                                        Oxer
                                        Thank you very much TIG!! πŸ‘
                                        Now the translations work fine again.
                                          mishgan
                                          hi,
                                          how can i download this plugin??? i don't see the zip file...
                                          • massimoM Offline
                                            massimo Moderator
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 31
                                            • 32
                                            • 22 / 32
