    [Plugin] Lattice Maker
    149 Posts 69 Posters 374.9k Views 68 Watching
    • T
      tobias3d
      thanks¡¡¡¡ thomthom
        askmo
        help me please.
        I dwnl Lattice Maker v1.3 20130528 has ".lingvo" file extension, but in the plugin folder it don't work because is not file .rb.
        I wonder, how I can do to work it?
          @Morris
          Since you have not supplied your OS or SUp version I must guess...
          How did you download this exactly ?
          Did you get it as a .RBZ file ?
          Did you then install it using the v8 [latest version] Preferences > Extensions > Install... button
          OR did you auto-install it using the SketchUcation Plugin Store dialog from within SketchUp?
          OR did you rename it .ZIP and extract its file/subfolder of files and put these into the Plugins folder, respecting the same relative relationships of files?
          This has been covered endlessly on the forums...
          Thomthom linked to a relevant post a few items back...
          If you do not keep the same relative locations tools just won't work! So for example if you put the tool's lingvo files directly into the Plugins folder you are screwed!
          Look in the .ZIP/.RBZ and you will see the tool's main 'loader' .rb and a subfolder of the same name containing a few other files - in the case of this tool there are some .lingvo files used for translations; in this tool's archive there is also a 'deBabelizer.rb' file used for the translations...
          The 'automated installation' methods are by far the safest for users such as yourself who are somewhat challenged in this regard... I commend them to you.
          If you have mis-installed files you MUST remove everything and start again - in the case of this tools having some duplicated lingvo files in the wrong location won't do any harm BUT for other tools that ship with rb files inside their subfolder moving those out into Plugins will break SketchUp BIG TIME!!
          So please don't do it, and if you do tidy up !
            archdeacon
            Tig many thanks for this great tool. I have a request and question. I am trying to make gridshells (and am trying to avoid using rhino in order to do so hehem) and i am trying to make diagonals drawn accross a surface generated from your extrude tools, then mirrored and reapplied to produce a net of diagonals to then produce a lattice. i have attached what i mean.this is the sort of net i need to latticize
            any ideas how i would do such a think. Ideally the diagonal rails would not be coplanar. they need to be placed on top of eachother. How do i take them though, apply a thickness to them, then extrude them to make the curved consequtive elements i require...
            I would be very, very grateful for any help.
            • BoxB
              Have you tried Tigs, Extrude Edges by Rails to Lattice which you will find in his Extrusion tools.
                As Box says...
                My Extrusion Tools EEbyRailsToLattice offers several options:
                There are 3d 'box-extrusions'
                Just rail lines
                Just profile lines
                Just diagonal lines [this is probably what you want... run it twice, picking rails alternately so the two groups of diagonals run oppositely then explode/merge the groups and rails/profiles into one container]
                  archdeacon
                  TIG many thanks for this reply. I did exactly as you mentioned previously in order to make the mesh i showed above. I want to make a lattice out of it though. Can the code for your latticizer be modified in order to be able to form lattices in three dimensions in the way that the latticizer works (axially on the line without splitting the lattice along that axis)? thank you for your help in advance.
                    Here's a future-proofed update.
                    http://sketchucation.com/forums/viewtopic.php?p=244981#p244981
                    • ppoublanP
                      ppoublan
                      Dear all,
                      I'm in the process re-installing my plugins for SU 2014.
                      Just downloaded from plugins store lattice maker.
                      got an error
                      Erreur de chargement du fichier latticeMaker.rb
                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                      I think this is linked to language files not encoded in UTF-8.
                      Is there newer version somewhere ? or plans to update.
                      Yours
                      Pascal
                        Thanks for the report...
                        It should already be compatible with v2014... 😕
                        If not I'll be able to fix it very easily !
                        • ppoublanP
                          ppoublan
                          I had a similar problem with my plugin.
                          Seems it only appears when extended caracters are read from non UTF-8 language string files.
                          Just re-encoded text files to solve this.
                          Problem did not occur with US-en version.
                          Yours
                          Pascal
                            LatticeMaker IS already compatible with v2014.
                            I just reinstalled it to convince myself ! 😒
                            Please get NEW versions of ALL of your Plugins installed into v2014.
                            Do NOT copy older versions over - often they may be incompatible...
                            I do not understand your report regarding the UTF8 error 😕
                            Did you perhaps copy files, instead of the necessary reinstall from the newest RBZ source ??
                            • ppoublanP
                              ppoublan
                              Just reinstalled on a virgin setup of SU2014 the version downloaded from Pluginstore (installed with plugin store).
                              Here is the error I got
                              I'm using french version of SU on Windows.
                              I was able to correct it myself :
                              • opened latticemakerfr.lingvo in notepad++
                              • converted to UTF-8
                              • saved the file
                                and then it works.
                                But I think it should be done at the source within your package.
                                Do not know the details, but UTF-8 encoding for non ascii files is a change in Ruby 2.0 vs Ruby 1.0
                                Yours
                                Pascal
                                Thanks - at last we discover that there's a rogue lingvo file...
                                I thought I had made all of them compatible !
                                The EN-US one is OK, but the FR one isn't !
                                I'll issue an update asap - sorry about that 😒
                                  Here's version v1.5
                                  http://sketchucation.com/pluginstore?pln=latticeMaker
                                  Its FR lingvo file is now encoded so it's compatible with v2014 😒
                                  • F
                                    fyr
                                    hey i pasted the plugin file in plug in folder but it doesn't show in the plugin menu... please help ?what to do?
                                      @fyr
                                      When you say you, "Pasted the Plugin File in folder [Plugins?] but it doesn't work..." what do you mean exactly??
                                      When you get an RBZ archive you must install it using Preferences > Extensions > Install... button OR using the AutoInstall feature of the SketchUcation PluginStore within SketchUp itself...
                                      If you simply put the RBZ archive into the Plugins folder it does nothing !
                                      Use the proper installer provided with all SketchUp versions >=v8MR2...
                                      If you have tried extracting the contents of the RBZ [renamed as .ZIP etc] and putting those into the Plugins folder there's a myriad of potential trip-hazards... like not keeping the extracted files in their correct subfolders, or having insufficient permissions to really add files into the Plugins folder [VirtualStore issue etc...]
                                      When it is properly installed this tool adds an item to the Plugins menu named 'Lattice Maker' which processes a premade and preselected mesh into a lattice... 😕
                                        mistereight
                                        Hi! Thanks for your plugin, is very useful! I think i use it almost every day!
                                        Anyway i'm in a little difficult whit my new model, i need to create a curtain wall whit a triangle shape windows, and the roof of the building is not plane.
                                        The problem is when the facades of the building are not connect in 90° degree and the lattice don't have a square shape but rectangle shape...
                                        i attach some picture i hope can explain my problem...
                                        thanks!
                                        the entire shape of the building
                                        the kind of curtain wall
                                        the problem in the corner
                                          In the 'real world' you would always have a 'corner post' and then the 'square' window-frame mullions would abut that, so make/process the separate façades that way and it'll work as you hope...
                                          Corner-post.PNG My example keeps a 'sharp' post but as the designer you can give it whatever cross-section you want... but remember that the outermost mullions of the glazing façades will need something to support them and tie them into their neighbor...
                                          Incidentally, please get the latest version of this tool [v1.6 which is now available] - its dialog had some compatibility issues with SUp>v2013, but is not fully compatible... http://sketchucation.com/pluginstore?pln=latticeMaker
                                            mistereight
                                            HI TIG,
                                            Thanks for your answer! usually i also work in the way that you explain, but in this specific case i need to try to make a structure like the one i attach on the post.
                                            Anyway if there was a possibility to choose how the 2 facade can connect it will be very interesting....
                                            Also I discover a plugin for help with the curtain wall http://pingpinkstudio.weebly.com but they not sell and also is impossible to find to download some demo o freeware, it's a kind of experiment. You think is possible to improve the lattice maker with the function of choose how the facade connect?
                                            Thanks a lot for your help.
                                            • 6 / 8
