    [Plugin] Elev45Shadows.rb
    43 Posts 14 Posters 31.2k Views 14 Watching
      Not even if you reload the model?
        arjunmax09
        yes the problem persists even if i reload the model...have you ever experienced it i mean with boulder, colorado??
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
          martinez001
          TIG,
          I am trying to flip my shadows. I have the Ruby Console open and type in the values that you state and run the plug-in and nothing happens. Am I not running the ruby console properly?
          • TIGT Online
            @martinez001 said:
            TIG,
            Open the Ruby Console and type $e45s=0 then press <enter> this changes the angle.
            And using $e45s=1 changes it back... 😕
            • pbacotP Offline
              @martinez001 said:
              TIG,
              You can also flip shadows with the "enter North angle" tool under the Solar North tool palette--after using this EXCELLENT plugin. We always fudge on the north elevations (northern hemisphere) for presentations sake but I assume if the west elevation is wrong I'll hear from my clients!
                CGulland
                Anyone know if Elev45Shadows.rb will work in SU 2013? Or can direct me to an alternative plugin for creating 45 degree shadows for architectural elevations?
                Many thanks
                • TIGT Online
                  It should work 😕 , but NOT with geolocation set, AND also you'll now need a separate SKP set up for each elevation - in earlier SketchUps you could have different locations in different Scenes...
                  This tool has to set the location, time etc for each elevation in turn to achieve a proper 45 degree shadow []which obviously can't be done in a fixed geolocation - so it's not possible with just one fixed [geo]location...
                  • demD Offline
                    dem
                    dont work in su 2014(
                    • TIGT Online
                      Set sun for shading ?
                      Set UTC to 0 and it then works...
                      I'm looking at why it differs from earlier versions.
                      It is ~8 years old !
                      The default template has UTC-7 ?
                      The shadowinfo "TZOffset" should be forced to 0 ?
                      There's a typo in the ancient code - it says "TZoffset" NOT "TZOffset", so you currently still have to manually change the UTC = 0 😒
                      At least you can force it to work, I'll look at how it might be auto-run right...
                      • demD Offline
                        dem
                        Thanks, UTC was whong in template))) default was 7 or 8
                        • TIGT Online
                          BUT I am working on an improvement fix to auto-set UTC=0...
                          • TIGT Online
                            Version v1.4 is now available at the PluginStore http://sketchucation.com/pluginstore?pln=Elev45shadows
                            Please read the guidance accessed via 'More Info'
                              Cubcrafter
                              Is there an easy way to change the shadow angle from 45 to some other angle with this plugin?
                              Larry
                              • TIGT Online
                                No.
                                Not unless you do some mind-numbing trig/geometry/maths...
                                I couldn't do it !
                                  putnik
                                  TIG, we quite often set correct Geo location for our models. It would be great if there was an option in this amazingly useful script to revert back to the previously set Geo location.
                                  I find it's easy enough to apply Elev45 temporarily to a select scene, and then revert the model back to the proper geo location, rather than fiddle with the importing files into a new SKP file etc. At the moment I manually type in the Geo location after letting Elev45 have its way with my model. A 'revert to previous geo location' button would be better. Is this possible to do?
                                  http://keshas.info
                                    johndoe1982
                                    I can't get this plugin working on my mac/SU 2015....I thought I just needed to put the .rbz file in my plugins folder
                                    • KrisidiousK Offline
                                      Krisidious
                                      Just a reminder... I love this plugin. it's great having an architecturally astute plugin developer like TIG making these gems for us. Thanks TIG.
                                      By: Kristoff Rand
                                      • TIGT Online
                                        You thought wrong !
                                        It's Extension/Plugin RBZ installation 101...
                                        Use the SketchUp > Preferences > Extensions > Install... button
                                        The contents of the selected RBZ are automatically extracted into the correct folder locations for you, and loaded...
                                        There after when SketchUp restarts an installed tool will also load...
                                        If you are computerly-challenged... then perhaps get the SketchUcation PluginStore Toolset from the link in Resources menu above [installed from the RBZ you can download] - thereafter you can use that to AutoInstall any of the Plugins listed in the PluginStore from within SketchUp via a simple to use dialog, without even worrying about getting their RBZ etc... It also gives you loads of other goodies too...
                                          Krisidious
                                          Take TIG's advice and get the Plugin Store Installer http://sketchucation.com/resources/plugin-store-download
                                          You'll get easy installs and uninstalls, sets, updates, plugin backups... and lots more.
                                          By: Kristoff Rand
                                          • atelierpaarA Offline
                                            atelierpaar
                                            Hi Tig thanks for your efforts to build this plugin.
                                            I am wondering if it is possible to store the 45 degree shadows with each Scene?
                                            Jim wrote a plugin called "North Angle Animator"
                                            Now here is what i have in mind:
                                            1. set the shadow using Elev45Shadows plugin
                                            2. aktivate North Angle Animator plugin and store the northangel setting to the scene
                                            Do you think that would be possible?
                                            thanks for looking into this matter
                                            Uli
                                            • 2 / 3
