    Latest Sketchup release doesn't support extension rbz files
    35 Posts 13 Posters 8.5k Views 13 Watching
    • O Offline
      Orrehunter
      Thanks alot, and I am really sorry but I didn't get that much of what you tried to explain there. I'm no computer genius. Do you know a easier explanation?
      Thanks in advance!
      /William
        Read through my steps again...
        Ask again at the very first one you have trouble with...
        πŸ˜•
        • O Offline
          Orrehunter
          Alright, I just did the whole first step and changed all the files and stuff to "Read & Write". Still doesnt work. So, I was on my way to your second idea but didnt understand how to find anything that's in the text.
          So, my computer confident is at rock bottom. Thanks alot for the help!
          /William
            William, look under the Window menu for the Ruby Console. That's where you need to type in the things TIG shows in red.
            • O Offline
              Orrehunter
              Oh you! Thank you so much! It is finally working! If I knew you I would give you one big hug and kiss! Finally!
              Don't judge me, but I'm so relieved right now! Many thanks!
              (It was the second option that worked for me!)
              Endless thanks,
              William 😍
                babamunu
                i faced this problem also
                  And? πŸ˜’
                  Did you get it sorted out?
                  • daleD Offline
                    dale
                    No problem here on Mountain Lion with .rbz, but I have noticed that I have to run permissions quite often with it. It is the first thing I do if things get glitchy.
                    I use a program called Onyx, it's free, and has always worked flawlessly. This site http://www.macupdate.com/app/mac/11582/onyx is good for downloads as there is a different version of Onyx for each Mac OS. Onyx is a manual system, so you have to run it for these scripts, but if you are leaving your computer on the Mac OS should be running scripts automatically.
                      garystan
                      designingcrime :
                                 I've got Sketchup 8, and it WILL NOT accept .rbz format plugins. Everyone here is outright lying, stating that it WILL.   I can provide the proof, unless these chickenshits  don't have the balls to step up to the plate and admit they're wrong !!!!!!!
        garystan
                        garystan
                        designingcrime :
                                          I just did a little research on this.  Apparently, you (and I) have to have Sketchup MR version in order to install .rbz plugins.  Now....if I've got my information correct, Sketchup MR version is for Mac-based computers, not windows-based computers.
        garystan
                          garystan
                          Dave R. :
                                   According to the latest information, you need Sketchup MR in order to install .rbz format plugins into Sketchup.
        garystan
                            As I told you elsewhere, install the latest maintenance release. Despite your faulty assertion, the maintenance releases weren't just for Mac. I even gave you the link. πŸ˜’
                              @garystan said:
                              designingcrime :
        garystan
                              You haven't got your information correct at all. πŸ˜’
                                garystan
                                Dave R :
                                          I tried that link.  Sketchup 8 "Free" doesn't accept .rbz format plugins.
        garystan
                                  Good grief! You need to fix the permissions for the Plugins folder. I've told you that several times already and you've ignored it. πŸ˜’ Do it and let's get past this once and for all.
                                  The first message you show is normal. The second one is proof that you didn't bother to correct the permissions for the Plugins folder.
                                    garystan
                                    Dave R. :
                                                 Okay......working along this line of thinking...how do I correct the
                                                 Plugin Permissions ?
        garystan
                                      That's been posted all over the forum but try this and scroll down to Now to fix your Plugins folder permissions...
                                      • BoxB Offline
                                        Utter utter Nonsense!
                                        **@garystan said:
                                        designingcrime :
        garystan**
                                        • 2 / 2
