    Latest Sketchup release doesn't support extension rbz files
    35 Posts 13 Posters 8.7k Views 13 Watching
    • daleD
      dale
      No problem here on Mountain Lion with .rbz, but I have noticed that I have to run permissions quite often with it. It is the first thing I do if things get glitchy.
      I use a program called Onyx, it's free, and has always worked flawlessly. This site http://www.macupdate.com/app/mac/11582/onyx is good for downloads as there is a different version of Onyx for each Mac OS. Onyx is a manual system, so you have to run it for these scripts, but if you are leaving your computer on the Mac OS should be running scripts automatically.
      • G
        garystan
        designingcrime :
                   I've got Sketchup 8, and it WILL NOT accept .rbz format plugins. Everyone here is outright lying, stating that it WILL.   I can provide the proof, unless these chickenshits  don't have the balls to step up to the plate and admit they're wrong !!!!!!!
        garystan
        • G
          garystan
          designingcrime :
                            I just did a little research on this.  Apparently, you (and I) have to have Sketchup MR version in order to install .rbz plugins.  Now....if I've got my information correct, Sketchup MR version is for Mac-based computers, not windows-based computers.
        garystan
          • G
            garystan
            Dave R. :
                     According to the latest information, you need Sketchup MR in order to install .rbz format plugins into Sketchup.
        garystan
              As I told you elsewhere, install the latest maintenance release. Despite your faulty assertion, the maintenance releases weren't just for Mac. I even gave you the link. πŸ˜’
                @garystan said:
                designingcrime :
        garystan
                You haven't got your information correct at all. πŸ˜’
                • G
                  garystan
                  Dave R :
                            I tried that link.  Sketchup 8 "Free" doesn't accept .rbz format plugins.
        garystan
                    Good grief! You need to fix the permissions for the Plugins folder. I've told you that several times already and you've ignored it. πŸ˜’ Do it and let's get past this once and for all.
                    The first message you show is normal. The second one is proof that you didn't bother to correct the permissions for the Plugins folder.
                    • G
                      garystan
                      Dave R. :
                                   Okay......working along this line of thinking...how do I correct the
                                   Plugin Permissions ?
        garystan
                        That's been posted all over the forum but try this and scroll down to Now to fix your Plugins folder permissions...
                        • BoxB
                          Utter utter Nonsense!
                          **@garystan said:
                          designingcrime :
        garystan**
                          • 2 / 2
