    Pipe-along-path
    64 Posts 9 Posters 11.5k Views 9 Watching
      Why not just opt for no C points when you make the pipe?
      I can see that some folks could use those C points as data points for locating the pipe in space. You could export their coordinates to a spreadsheet, for example, and manipulate them.
      Why are you using guidelines as "permanent" features in your model? They weren't intended for that.
        The Cpoints are optional.
        Answer 'No' to stop them being added during that session.
        Their function is to allow snapping at nodes etc.
        If you want to edit the script with Notepad++, so the default is 'No' find the line reading:
        @cpoints = "Yes"
        and change it to
        @cpoints = "No"
        You can also change other defaults - for example if you always want 12 segments...
        • P
          pipingguy
          I thought I had the latest version which I downloaded from the rhin.crai.archi site. (if said site is obsolete, why does it still exist?) Then I accessed TIG via the the author pull-down menu in sketchucation's plugin store and did not see 'pipe-along-path' listed. (I was not provided with the option to scroll to a next page). Then I used the plugin store's search feature and found it. So now that I am up to date, I would suggest giving the users a way to change the input box default to suit their typical work habits. With me, it's always inches and the inside diameter is always zero.
            You didn't read TIG's last post? He gave you a way to change the default settings.
            If you're always going to want a zero inside diameter and no C points, you could use Tube Along Path instead.
            • BoxB
              Or Didier's Lines2Tubes which is available from the plugin store.
              http://sketchucation.com/forums/viewtopic.php?p=88592#p88592
              • cottyC
                cotty
                You have to change from "recent" to "full list" to see all the plugins from one author...
                my SketchUp gallery
                • P
                  pipingguy
                  column lines - xlines - guides.skp
                  As to Dave R's question, "Why are you using guidelines as "permanent" features in your model? They weren't intended for that." In AutoCAD I create XLINEs and place them in a locked and faded layer and assign them a specific color. This now establishes a secure column line grid upon which the rest of the model is measured and coordinated from. I suppose I could create a grid using intersecting lines in sketchup, erase the resulting faces, and put them in a locked group. But they would blend into the remaining myriad of lines. At least with construction lines, they are dashed so they don't stand out to much, yet are quickly recognizable. (see attached SU partial model) Perhaps you can tell me of a popular plugin that generates dashed lines? BTW - what does 'place inline' mean in the reply editor regarding the attachment of a file?
                  • P
                    pipingguy
                    Sorry. OK - I will look at the script with notepad. But I literally have not dealt with any kind of of computer code since an introductory course into Fortran or whatever it was back in the early seventies. something about flowcharts / if yes, then / if false then....blah blah. And then we put the code into an IBM punchcard machine. (junior high school) LOL!!!!
                    • P
                      pipingguy
                      so after two hours purging malware/bloatware/spyware and every other ware that came along for the ride when I downloaded the fusion installer required to install notepad++, I think I will stay away from fiddling with codes and the like.
                        Notepad++ is a respectable product and if installed from their site it should not have other hidden baddies... http://notepad-plus-plus.org/download/v6.5.4.html
                        I'll be reissuing PipeAlongPath shortly [edited entirely in Notepad++ !]
                        I will be adding some optimistation tools...
                        • P
                          pipingguy
                          yeah - that's where I got the infection from (http://notepad-plus-plus.org/download/v6.5.4.html) ๐Ÿ˜ž
                            So I guess my suggestion of Tube Along Path didn't work for you?
                              I use the latest version of Notepad++ everyday.
                              I have never had problems with it.
                              All downloaded files are auto-virus-checked.
                              My whole system is regularly virus-checked/scanned.
                              Very rarely is anything found untoward - out of millions of files...
                              To double-check your assertion, I just re-downloaded the latest exe installer version [6.5.4].
                              I virus-scanned it...
                              Nothing was found.
                              I reinstalled it...
                              Nothing was found.
                              It works fine.
                              Strange... ๐Ÿ˜•
                              What is this 'fusion installer' you speak of ?
                              The downloaded .exe received direct from Notepad++ is in its own installer - just run it as an admin...
                              Why did you think that you need another application to install it ?
                              You seem to be making the proverbial rod for your own back ๐Ÿ˜’
                              • P
                                pipingguy
                                I THINK I clicked the incorrect download button on the attached printscreen. And so, I probably did not look at the fineprint to opt out of certain choices in the fusion installer because I was in a hurry to try out the notepad++. I would like to re-trace those steps - but obviously I'm too spooked. So even though Norton allowed it,I ended up with trash like perk prize, security protect, password box, optimizer pro, movie mode, my pc backup, enhance tronic and conduit search. Full scans with Norton and Kaspersky fail to remove the last one which plants itself into the search box when I launch Firefox. And I'm sure there are other fragments of un-purgeable garbage I have yet to discover. But that's my problem. I would like to examine the properties of the installer, but I shift-deleted it. [attachment=0]notepad++ site.
                                  You should click on the download button for Notepad++... NOT the download button for one of its site's advertisers !
                                  So you downloaded a quite unnecessary unconnected third-party application, which the Notepad++ author derives some income from through them advertising...
                                  So that's where all of the guff came from...
                                  Nothing to do with Notepad++...
                                  All to do with you installing something else ๐Ÿ˜’
                                  • BoxB
                                    Correct me if I wrong Tig, but isn't it possible to make small edits to .rb files just using normal notepad. I've certainly done it in the past but now I'm second guessing myself.
                                      It probably is OK for a simple edit.
                                      BUT remember that Notepad makes its new files as ANSI, which then mess up v2014.
                                      Whereas Notepad++ can reset any file's encoding to the required UTF8-without-BOM.
                                      Plain Notepad can be used to edit a UTF-without-BOM file and then 'save' keeping the original encoding: even 'save_as' keeps that encoding too... ๐Ÿ˜„
                                      BUT any new files from Notepad are unlikely to work ๐Ÿ˜•
                                      Notepad++ is must better as it can display colored syntax and show line-numbers etc making it easy to say find line ~#567 and edit between "" ... ๐Ÿ˜„
                                      • BoxB
                                        Thanks, that makes sense as I have only ever had to edit something simple like number of segments or a yes to a no and then just saved.
                                        • mitcorbM
                                          mitcorb
                                          @pipingguy:
                                          Absolutely get rid of Conduit Search, unless, perhaps, you enjoy it. ๐Ÿ˜’
                                            An updated version [v1.9] of PipeAlongPath is now available http://sketchucation.com/forums/viewtopic.php?p=513484#p513484
                                            • 2 / 4
