    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
    • F Offline
      factopedia
      Thanks so much.
        pgarmyn
        @floffy1983
        What system (mac/windows) ? what version ?
        Please complete your profile. This can help me to find a solution for you?
          pgarmyn
          @factopedia said:
          Thanks so much.
          Glad you like it 😄
          • F Offline
            floffy1983
            Sorry, you are perfectly right.
            I am working on a windows xp machine, pentium 4, 2gb.
            I weep daily for its lack of power, but alas, my place of work will not let me bring my own laptop.
              cilemomax
              Can you help me with something? how do I uninstall it. I deleted it but every time I start up the program it gets an error saying it's trying loading the file. Thanks in advance
                bimbachi
                @pgarmyn said:
                @Bimbach
                Done as advised? What did you do : Uninstalled plugins, other file installed, or both?
                RichSection only creats sectionfaces for groups that produce a closed section.
                Did you activate the extension in 'preferences' ?
                Is there a menu in plugins/RichSection?
                Open the ruby panel : what is printed in the ruby-panel?
                ok (following on mac issue)
                1./ as adviced I replaced only the file you forwarded "PiGa_RichSection.rb"
                2./ then no more loading error on startup
                3./ than RichSection is in the palet and plugins menu
                4./ than when clicking or choosing from menu - "create richsection" in rubby panel there is:
                "Error: #<TypeError: can't convert nil into String>
                (eval):917:in +' (eval):917:in l_ctrl'
                (eval):1466:in createRichSectionTool' (eval):4353:in require'
                (eval):917:in `call'
                (eval):917"
                  lcarlin247
                  It just does not work to me, i create the section but the paremeters do not appear, not even by using the paremeters icon
                  any advice? i use skp 2013
                    pgarmyn
                    @Bimbachi
                    Great, this wil perhaps help me to resolve my Mac-problem.
                    I will work on in now....
                      pgarmyn
                      How did you install. I know there are problems with Mac, but it should work with windows.
                      The best way is to use de Sketchucation Plugin manager, Witch can install, disable and uninstall plugins.
                      If you didn't used the Sketchucation plugin manager : delete the file PiGa_RichSection.rb in the Sketchup/plugins directory (optional but not necessary the directory with the same name).
                        pgarmyn
                        MAC ore Windows, apparently, ther is a compatibility problem with MAC
                        If Windows :
                        Did you creates the section with the most left icon ?
                        Open the ruby panel. Are ther any error messages ?
                        If your PC is slow, wait for the creation of the views (do not use the mousebuttons until done).
                        • romboutR Offline
                          rombout
                          Tried the solution for the mac verion with a direct copy of the plugin to the folder. i get this error
                           RS;licensefile found  ; /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLicense.rb
                          (eval); warning >> is not an error but a "normal" ruby message
                          RS;1 ; # RichSection License File for DEMO ; Time limited ; works until 1 june 2014
                          RS;2 ; # Do not change this file
                          RS;3 ; @@rsLic[;RScomp]='any'
                          RS;4 ; @@rsLic[;RSmacAdr]='any'
                          RS;5 ; @@rsLic[;RSsoftlicV]='any'
                          RS;6 ; @@rsLic[;RSsoftlicDate]='1401580800'#Time.gm(2014,06,1).to_i.to_s#1396310400#
                          RS;7 ; @@rsLic[;RSsoftlicType]='DEMO, valid until 2014-06-01'
                          RS;8 ; @@rsLic[;RSsoftlicToName]='any'
                          RS;9 ; @@rsLic[;RSsoftlicToMail]='any'
                          RS;10 ; @@rsLic[;RSsoftlicKey1]='Key1ForDemoLicenseUntil-2014-06-01'
                          RS;11 ; @@rsLic[;RSsoftlicKey2]='2n0xikomxzl8lnh357rruykadaq0q0c3g1b5e9k4i987ji42lbru3'
                          RS;12 ; # Do not change this fil
                          Error; #<TypeError; can't convert nil into String>
                          (eval);917;in `+'
                          (eval);917;in `l_ctrl'
                          (eval);1466;in `createRichSectionTool'
                          (eval);4353;in `require'
                          • soloS Offline
                            @jeff hammond said:
                            @pgarmyn said:
                            YES 😄
                            Parameters for "cut color the same as the object" :
                            • Set 'RichSection material name' to "prefix+materialname, default"
                            • Set 'RichSection materials, prefix' to "" (empty)
                            neat.
                            i tried a quick one in indigo with glass, metal, and wood..
                            [attachment=0:1ylc6qf1]<!-- ia0 -->section3.jpg<!-- ia0 -->[/attachment:1ylc6qf1]
                            i didn't let it render as long as it would need but it shows that it would work in an actual render..
                            glass- one solid sphere (rendered as a solid piece of glass)
                            metal- sphere inside a sphere (rendered as if it were a bowl)
                            wood- i resized the texture on the facing side.. the cut shows the original size.. probably not good to use this technique on renders requiring high quality texturing/mapping (as in- that block would require end grain etc.)
                            Good news for Thea users, Tomasz has been made aware of this and will support this in an upcoming release.
                              driven
                              @Piet
                              ` > Sketchup.version_number < 8000999
                              false
                              8000999`
                              your excluding v8 on mac...
                              • tt_suT Offline
                                tt_su
                                @driven said:
                                @Piet
                                false
                                8000999`
                                Sketchup.version_number doesn't work that well with the recent version number scheme of SketchUp. It's better to parse Sketchup.version.
                                  pgarmyn
                                  @tt_su
                                  Thanks x 1000, i will correct that this evening, to get it working for Mac.
                                  But it's not the only conflict in my code.
                                  My Mac experience is quite limited, actually zero.
                                  Maybee we must start a Post listing all restrictions and problems in relation to Mac, Windows, ....?
                                    pgarmyn
                                    @rombout said:
                                    Tried the solution ....
                                    Dank U, meneer Rombout.
                                    I know, I will work on it as soon as i can.
                                    Sorry for the inconveniance....
                                      pgarmyn
                                        davecoopstl
                                        pgarmyn -
                                        I was using RichSection all week, and then it suddenly stopped working. I think I MAY have updated it recently, though.
                                        By stop working, I mean it totally stopped working, as others have described above: I couldn't Add a RichSection, Edit Parameters, Edit Settings, nothing...
                                        In any case, I discovered what was wrong, by looking at the Ruby Console when running the plugging.
                                        It seems that your PlugIn suddenly needs Full Read/Write permissions to the C:\Program Files (x86)\SketchUp\SketchUp 2013\Materials folder.
                                        I did not have this, and I had to navigate to this folder in Windows Explorer, and give myself Full Read/Write Permissions to the Materials folder. Much the same way I had to give myself Full Read/Write Permissions to the Plugins Folder after I installed SU2013, so the Sketchucation Store could install PlugIns.
                                        Once I gave myself Full Read/Write Permissions to the SketchUp 2013/Materials folder, RichSection started working again!
                                        It's a fantastic PlugIn, with an amazing array of options, and a huge time-saver.
                                        If you changed something in the last update, you might want to look at it closer.
                                        Hope this helps you, and anyone else who updated and stopped being able to run RichSection.
                                        Thanks.
                                        Dave.
                                          davecoopstl
                                          pgarmyn -
                                          After getting RichSection working again (SEE ABOVE POST), I now only have the #Default Material available to use.
                                          I do NOThave any of the other great section hatch materials that you provide with the PlugIn.
                                          I'm guessing the new path to the ...SketchUp 2013\Materials folder has something to do with this.
                                          Hopefully this helps you troubleshoot the issues.
                                          Thanks.
                                          Dave.
                                            pgarmyn
                                            @davecoopstl said:
                                            pgarmyn -
                                            After getting RichSection working again (SEE ABOVE POST), I now only have the #Default Material available to use ….
                                            At creation of the first RichSection, the code will load the default Library in your drawing, wich is by default (if not changed in RichSection/Settings) : materials/RichSection/RS_V0/#default.mat.skp, containing only one material : #default,
                                            The other materials (17 files with skm extension) are copied to the same directory and can be selected in the Materials Window (/RichSection/RS_V0). The ruby code needs write permissions for these directorys. I will have to put some warning message if this is not the case.
                                            For the previous version there were people complaining they didn't asked for all those materials. If you want to load all materials at first RS creation, then replace the value Settings >> RichSection materials to load... : “materials/RichSection/RS_V0/#default.mat.skp” by “materials/RichSection/RS_V0/RS_V0_14.mat.skp”. Do not misspell, the value isn't changed if path/file don't exist. The materials are only loaded if the default material doesn't exist in your model (Settings >> Proposed default RS material). You can rename the default material in your model to reload the material(s) at the next RichSection creation or update. You can always go back to the default values (Plugins>>RichSection>>Reset Settings)
                                            THERE ARE MANY PROBLEMS WITH MAC
                                            MAC USERS, PLEASE WAIT :
                                            IS THERE SOME MAC-VOLUNTEER TO HELP WITH SOME TESTING ❓
                                            • 19
                                            • 20
                                            • 8 / 20
