    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 181.4k Views 85 Watching
      bimbachi
      @pgarmyn said:
      @bimbachi @diegob
      It must be a MAC related problem, you are both running on MAC ?
      Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
      I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
      Can you test the following : disable all the other plugins ❓
      If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
      Thanks in advance.
      @pgarmyn
      done what you adviced
      & no more error on app startup
      but ...
      at short test looks like that it is not working (add new section result nothing)
        pgarmyn
        @Bimbach
        Done as advised? What did you do : Uninstalled plugins, other file installed, or both?
        RichSection only creats sectionfaces for groups that produce a closed section.
        Did you activate the extension in 'preferences' ?
        Is there a menu in plugins/RichSection?
        Open the ruby panel : what is printed in the ruby-panel?
        • F Offline
          floffy1983
          It looks like my wish-list plugin, but i cannot get it to load.
          If it helps, i am stuck with the Italian SU8 on a partially locked down office pc, partially as i can install plugins but can't update.
          • F Offline
            factopedia
            Thanks so much.
              pgarmyn
              @floffy1983
              What system (mac/windows) ? what version ?
              Please complete your profile. This can help me to find a solution for you?
                pgarmyn
                @factopedia said:
                Thanks so much.
                Glad you like it 😄
                • F Offline
                  floffy1983
                  Sorry, you are perfectly right.
                  I am working on a windows xp machine, pentium 4, 2gb.
                  I weep daily for its lack of power, but alas, my place of work will not let me bring my own laptop.
                    cilemomax
                    Can you help me with something? how do I uninstall it. I deleted it but every time I start up the program it gets an error saying it's trying loading the file. Thanks in advance
                      bimbachi
                      @pgarmyn said:
                      @Bimbach
                      ok (following on mac issue)
                      1./ as adviced I replaced only the file you forwarded "PiGa_RichSection.rb"
                      2./ then no more loading error on startup
                      3./ than RichSection is in the palet and plugins menu
                      4./ than when clicking or choosing from menu - "create richsection" in rubby panel there is:
                      "Error: #<TypeError: can't convert nil into String>
                      (eval):917:in +' (eval):917:in l_ctrl'
                      (eval):1466:in createRichSectionTool' (eval):4353:in require'
                      (eval):917:in `call'
                      (eval):917"
                        lcarlin247
                        It just does not work to me, i create the section but the paremeters do not appear, not even by using the paremeters icon
                        any advice? i use skp 2013
                          pgarmyn
                          @Bimbachi
                          Great, this wil perhaps help me to resolve my Mac-problem.
                          I will work on in now....
                            pgarmyn
                            How did you install. I know there are problems with Mac, but it should work with windows.
                            The best way is to use de Sketchucation Plugin manager, Witch can install, disable and uninstall plugins.
                            If you didn't used the Sketchucation plugin manager : delete the file PiGa_RichSection.rb in the Sketchup/plugins directory (optional but not necessary the directory with the same name).
                              pgarmyn
                              MAC ore Windows, apparently, ther is a compatibility problem with MAC
                              If Windows :
                              Did you creates the section with the most left icon ?
                              Open the ruby panel. Are ther any error messages ?
                              If your PC is slow, wait for the creation of the views (do not use the mousebuttons until done).
                              • romboutR Offline
                                rombout
                                Tried the solution for the mac verion with a direct copy of the plugin to the folder. i get this error
                                 RS;licensefile found  ; /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLicense.rb
                                (eval); warning >> is not an error but a "normal" ruby message
                                RS;1 ; # RichSection License File for DEMO ; Time limited ; works until 1 june 2014
                                RS;2 ; # Do not change this file
                                RS;3 ; @@rsLic[;RScomp]='any'
                                RS;4 ; @@rsLic[;RSmacAdr]='any'
                                RS;5 ; @@rsLic[;RSsoftlicV]='any'
                                RS;6 ; @@rsLic[;RSsoftlicDate]='1401580800'#Time.gm(2014,06,1).to_i.to_s#1396310400#
                                RS;7 ; @@rsLic[;RSsoftlicType]='DEMO, valid until 2014-06-01'
                                RS;8 ; @@rsLic[;RSsoftlicToName]='any'
                                RS;9 ; @@rsLic[;RSsoftlicToMail]='any'
                                RS;10 ; @@rsLic[;RSsoftlicKey1]='Key1ForDemoLicenseUntil-2014-06-01'
                                RS;11 ; @@rsLic[;RSsoftlicKey2]='2n0xikomxzl8lnh357rruykadaq0q0c3g1b5e9k4i987ji42lbru3'
                                RS;12 ; # Do not change this fil
                                Error; #<TypeError; can't convert nil into String>
                                (eval);917;in `+'
                                (eval);917;in `l_ctrl'
                                (eval);1466;in `createRichSectionTool'
                                (eval);4353;in `require'
                                • soloS Offline
                                  @jeff hammond said:
                                  @pgarmyn said:
                                  YES 😄
                                  Parameters for "cut color the same as the object" :
                                  • Set 'RichSection material name' to "prefix+materialname, default"
                                  • Set 'RichSection materials, prefix' to "" (empty)
                                  neat.
                                  i tried a quick one in indigo with glass, metal, and wood..
                                  [attachment=0:1ylc6qf1]<!-- ia0 -->section3.jpg<!-- ia0 -->[/attachment:1ylc6qf1]
                                  i didn't let it render as long as it would need but it shows that it would work in an actual render..
                                  glass- one solid sphere (rendered as a solid piece of glass)
                                  metal- sphere inside a sphere (rendered as if it were a bowl)
                                  wood- i resized the texture on the facing side.. the cut shows the original size.. probably not good to use this technique on renders requiring high quality texturing/mapping (as in- that block would require end grain etc.)
                                  Good news for Thea users, Tomasz has been made aware of this and will support this in an upcoming release.
                                    driven
                                    @Piet
                                    ` > Sketchup.version_number < 8000999
                                    false
                                    8000999`
                                    your excluding v8 on mac...
                                    • tt_suT Offline
                                      tt_su
                                      @driven said:
                                      @Piet
                                      false
                                      8000999`
                                      Sketchup.version_number doesn't work that well with the recent version number scheme of SketchUp. It's better to parse Sketchup.version.
                                        pgarmyn
                                        @tt_su
                                        Thanks x 1000, i will correct that this evening, to get it working for Mac.
                                        But it's not the only conflict in my code.
                                        My Mac experience is quite limited, actually zero.
                                        Maybee we must start a Post listing all restrictions and problems in relation to Mac, Windows, ....?
                                          pgarmyn
                                          @rombout said:
                                          Tried the solution ....
                                          Dank U, meneer Rombout.
                                          I know, I will work on it as soon as i can.
                                          Sorry for the inconveniance....
                                            pgarmyn
                                            • 19
                                            • 20
                                            • 8 / 20
