    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 188.1k Views 85 Watching
      pgarmyn
      RichSection plugin [highlight=#ffff00:2tqcoasz]UPDATED[/highlight:2tqcoasz] : download from the Plugin Store
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
        diegob
        I've just intsalled your updated plug-in
        but apparently is not working
        once Sketchup is started, a window is telling me that:
        Error loading files PiGa_Richsection.rb
        can not convert nil into String
        ca you please help me?
          bimbachi
          hello,
          after install via skechucation plugin store on mac sketchup
          • when starting skp. i'm geting this rubby error messge
          "Error Loading File PiGa_RichSection.rb
          can't convert nil into String"
          can you advice?
            bimbachi
            @pgarmyn said:
            @bimbachi @diegob
            It must be a MAC related problem, you are both running on MAC ?
            Any other Mac users with problems ❓ ❓ ❓ ❓ ❓
            I have no explanation. For me it works on SU8 and SU2013. But i can't test it on mac.
            Can you test the following : disable all the other plugins ❓
            If this doesn't help, can you test the following file : replace PiGa_RichSection.rb (in directory ..SketchUp..\Plugins) by the file below, and tell me if it works ❓
            Thanks in advance.
            @pgarmyn
            done what you adviced
            & no more error on app startup
            but ...
            at short test looks like that it is not working (add new section result nothing)
              pgarmyn
              @Bimbach
              Done as advised? What did you do : Uninstalled plugins, other file installed, or both?
              RichSection only creats sectionfaces for groups that produce a closed section.
              Did you activate the extension in 'preferences' ?
              Is there a menu in plugins/RichSection?
              Open the ruby panel : what is printed in the ruby-panel?
              • F Offline
                floffy1983
                It looks like my wish-list plugin, but i cannot get it to load.
                If it helps, i am stuck with the Italian SU8 on a partially locked down office pc, partially as i can install plugins but can't update.
                • F Offline
                  factopedia
                  Thanks so much.
                    pgarmyn
                    @floffy1983
                    What system (mac/windows) ? what version ?
                    Please complete your profile. This can help me to find a solution for you?
                      pgarmyn
                      @factopedia said:
                      Thanks so much.
                      Glad you like it 😄
                      • F Offline
                        floffy1983
                        Sorry, you are perfectly right.
                        I am working on a windows xp machine, pentium 4, 2gb.
                        I weep daily for its lack of power, but alas, my place of work will not let me bring my own laptop.
                          cilemomax
                          Can you help me with something? how do I uninstall it. I deleted it but every time I start up the program it gets an error saying it's trying loading the file. Thanks in advance
                            bimbachi
                            @pgarmyn said:
                            @Bimbach
                            ok (following on mac issue)
                            1./ as adviced I replaced only the file you forwarded "PiGa_RichSection.rb"
                            2./ then no more loading error on startup
                            3./ than RichSection is in the palet and plugins menu
                            4./ than when clicking or choosing from menu - "create richsection" in rubby panel there is:
                            "Error: #<TypeError: can't convert nil into String>
                            (eval):917:in +' (eval):917:in l_ctrl'
                            (eval):1466:in createRichSectionTool' (eval):4353:in require'
                            (eval):917:in `call'
                            (eval):917"
                              lcarlin247
                              It just does not work to me, i create the section but the paremeters do not appear, not even by using the paremeters icon
                              any advice? i use skp 2013
                                pgarmyn
                                @Bimbachi
                                Great, this wil perhaps help me to resolve my Mac-problem.
                                I will work on in now....
                                  pgarmyn
                                  How did you install. I know there are problems with Mac, but it should work with windows.
                                  The best way is to use de Sketchucation Plugin manager, Witch can install, disable and uninstall plugins.
                                  If you didn't used the Sketchucation plugin manager : delete the file PiGa_RichSection.rb in the Sketchup/plugins directory (optional but not necessary the directory with the same name).
                                    pgarmyn
                                    MAC ore Windows, apparently, ther is a compatibility problem with MAC
                                    If Windows :
                                    Did you creates the section with the most left icon ?
                                    Open the ruby panel. Are ther any error messages ?
                                    If your PC is slow, wait for the creation of the views (do not use the mousebuttons until done).
                                    • romboutR Offline
                                      rombout
                                      Tried the solution for the mac verion with a direct copy of the plugin to the folder. i get this error
                                       RS;licensefile found  ; /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/PiGa_RichSection/RichSectionLicense.rb
                                      (eval); warning >> is not an error but a "normal" ruby message
                                      RS;1 ; # RichSection License File for DEMO ; Time limited ; works until 1 june 2014
                                      RS;2 ; # Do not change this file
                                      RS;3 ; @@rsLic[;RScomp]='any'
                                      RS;4 ; @@rsLic[;RSmacAdr]='any'
                                      RS;5 ; @@rsLic[;RSsoftlicV]='any'
                                      RS;6 ; @@rsLic[;RSsoftlicDate]='1401580800'#Time.gm(2014,06,1).to_i.to_s#1396310400#
                                      RS;7 ; @@rsLic[;RSsoftlicType]='DEMO, valid until 2014-06-01'
                                      RS;8 ; @@rsLic[;RSsoftlicToName]='any'
                                      RS;9 ; @@rsLic[;RSsoftlicToMail]='any'
                                      RS;10 ; @@rsLic[;RSsoftlicKey1]='Key1ForDemoLicenseUntil-2014-06-01'
                                      RS;11 ; @@rsLic[;RSsoftlicKey2]='2n0xikomxzl8lnh357rruykadaq0q0c3g1b5e9k4i987ji42lbru3'
                                      RS;12 ; # Do not change this fil
                                      Error; #<TypeError; can't convert nil into String>
                                      (eval);917;in `+'
                                      (eval);917;in `l_ctrl'
                                      (eval);1466;in `createRichSectionTool'
                                      (eval);4353;in `require'
                                      • soloS Offline
                                        @jeff hammond said:
                                        @pgarmyn said:
                                        YES 😄
                                        Parameters for "cut color the same as the object" :
                                        • Set 'RichSection material name' to "prefix+materialname, default"
                                        • Set 'RichSection materials, prefix' to "" (empty)
                                        neat.
                                        i tried a quick one in indigo with glass, metal, and wood..
                                        [attachment=0:1ylc6qf1]<!-- ia0 -->section3.jpg<!-- ia0 -->[/attachment:1ylc6qf1]
                                        i didn't let it render as long as it would need but it shows that it would work in an actual render..
                                        glass- one solid sphere (rendered as a solid piece of glass)
                                        metal- sphere inside a sphere (rendered as if it were a bowl)
                                        wood- i resized the texture on the facing side.. the cut shows the original size.. probably not good to use this technique on renders requiring high quality texturing/mapping (as in- that block would require end grain etc.)
                                        Good news for Thea users, Tomasz has been made aware of this and will support this in an upcoming release.
                                          driven
                                          @Piet
                                          ` > Sketchup.version_number < 8000999
                                          false
                                          8000999`
                                          your excluding v8 on mac...
                                          • tt_suT Offline
                                            tt_su
                                            @driven said:
                                            @Piet
                                            false
                                            8000999`
                                            Sketchup.version_number doesn't work that well with the recent version number scheme of SketchUp. It's better to parse Sketchup.version.
                                            • 19
                                            • 20
                                            • 8 / 20
