    Pipe-along-path
    64 Posts 9 Posters 4.7k Views 9 Watching
      pipingguy
      This script is very useful to me. After extruding a pipe connected to another pipe with a 6 segmented tangent arc, is there away to erase the 90 degree elbow (arc) and be left with the two pipe ends being perpendicular to their paths?
        Hi Pipingguy,
        The pipe created this way will be a group. Double click on the group to edit it then turn on hidden geometry (View menu) and now you can select the facets of the bending part separately. Simply delete them.
          pipingguy
          attached, find an object that causes this plugin to freeze the program. let me know what you think. follow-me works, however.PIPE-ALONG-PATH CRASHES BUT FOLLOW-ME WON''T.skp
            I can run Pipe along path along your path using the default settings with no trouble. Maybe it has to do with some setting you're making for the plugin. Can you show us the settings you're trying to use?
            • TIGT Online
              I get fine results, BUT if I set the diameter to say 50" it does lock up.
              FollowMe using a similar sized circular face works.
              I have reviewed the code and whilst I can make a few minor improvements, in speed etc I can't see why it fails in code but succeeds in a manual FollowMe πŸ˜•
              I'm still looking at it...
                pipingguy
                Please see attached. 10.625" relates to 8" steel pipe with 1" insul in case you were wondering.
                pipe along path set-up screenshot.pdf
                  Those numbers work for me.
                  It looks like you're using an old version of the plugin, though. Why aren't you using the current version?
                    pipingguy
                    i just replaced it with a new one from the ruby library and the bugsplat / lockup continues. What made you think it was outdated in the first place?
                      The appearance of the input box in your PDF file made me think that.
                      I wonder if you have some other plugin causing a conflict. As I showed, it worked for me.
                        pipingguy
                        I see. Hey - the plugin rarely crashes - so I am not losing sleep over it. However, if the author is reading this (TIG?) and he feels inclined to fiddle with the code, I would suggest giving the users a way to change the input box default to suit their typical work habits. With me, it's always inches and the inside diameter is always zero. And if the linework upon which the pipe is extruded can automatically become part of the component instead of my having to cut and paste in in place as a separate operation, well that would be good.
                        • TIGT Online
                          I have an update 'in progress'.
                          Which will allow you to work in any units/formats.
                          It's be easy to set an alternative default in the code too...
                          But I still can't see where the splat is coming from πŸ˜•
                            pipingguy
                            GREAT
                            • TIGT Online
                              Well... 😲
                              I found the cause, πŸ˜„
                              but I can't find a coded workaround... 😞
                              I noticed that some of the lines forming the path were not quite horizontal... SlightSkew.PNG If the pipe's extrusion diameter is at a certain threshold then the coded FollowMe fails, I suspect its something to do with tolerances as the pipe twists around the form the side's segments can't intersect and form the pipe-run.
                              See the screen-grab when I use it on two individual pieces successfully...
                              Hidden Geometry ON, exploded and intersected. Bits.PNG If I 'flatten' the slightly sloping lines it will 'PipeAlongPath' just fine [front one]. Capture.PNG If I copy the top-most circle from that one and paste it onto the original path [or simply draw a flat circle on the top-end of the path] [the back-one], then select the path and use the native FollowMe on that circular face it will make the pipe with the slightly sloping sections... NativeFollowMe.PNG Because the slight slopes of the paths and the diameter threshold are not obviously linked I can't see how to trap it consistently.
                              I tried introducing a vector check on a pipe sections of multiple part pipes, and if that piece of pipe is within a limit of being coplanar with the next section etc, then it was made as if it were coplanar [the vertices are slightly adjusted in the Z]... But it's clunky and awkward... πŸ˜• This example in Xray shows that some of the verties in the paths have to be adjusted by ~1" to get PipeAlongPath to make the extrusion with the coded-followme, but the native-FollowMe works OK without that tweak - it's plain weird πŸ˜’ForcedCoplanarLines.PNG Comments appreciated - I'll hold off issuing any updates until someone responds... πŸ€“
                                Interesting. I see the issue but it did work for me. I wonder how the path got drawn with those very small errors.
                                • TIGT Online
                                  It works for me too, at say 4" or 6" diamter, but when I go up to ~40" if freezes as the coded-followme gets stuck in an unbreakable loop, trying to decide how to proceed around the slight twist!!
                                  The native-FollowMe succeeds using the same geometry... BUT one might reasonably supposed that both of the methods used very similar algorithms!
                                  Unfortunately there is no 'direct access': in code it's simply face.followme(edges) - which works 99/9% of the time, until someone contrives a combo of very slightly skewed paths that trips it up...
                                  Sometimes pipes do need a slight fall to 'drain' etc.
                                  But this is <0.375 degrees - aka 'flat'.
                                  So if I force it 'flat' in parts as I've indicated, then it works...
                                  BUT I don't want to make the pipe's path subtly different from the user's selected edges, unless I really need to...
                                    CRASHWORTHY1
                                    Please do not fret about the rare freezes. Kindly work on the default input box stuff mentioned above - if you so feel inclined. Speaking of 'inclined' - yes this particular pipe run is sloped for drainage. Even with such runs the plugin rarely freezes and Mr.TIG deserves accolades.
                                      pipingguy
                                      Construction points are appearing when I explode a pipe-along-path group. This only seems to be happening recently - maybe after I updated to the latest version? If it was engineered into the script, I am interested to know the purpose. I can't delete them by "edit>delete guides" because guides that I have set up permanently in my model will disappear - regardless of being in a locked group. And selecting and erasing each guide point is time consuming.
                                      • cottyC Offline
                                        cotty
                                        You can use Thomthoms selection tools to select all guide points in a group and delete them in one step.
                                        my SketchUp gallery
                                          Why not just opt for no C points when you make the pipe?
                                          I can see that some folks could use those C points as data points for locating the pipe in space. You could export their coordinates to a spreadsheet, for example, and manipulate them.
                                          Why are you using guidelines as "permanent" features in your model? They weren't intended for that.
                                          • TIGT Online
                                            The Cpoints are optional.
                                            Answer 'No' to stop them being added during that session.
                                            Their function is to allow snapping at nodes etc.
                                            If you want to edit the script with Notepad++, so the default is 'No' find the line reading:
                                            @cpoints = "Yes"
                                            and change it to
                                            @cpoints = "No"
                                            You can also change other defaults - for example if you always want 12 segments...
                                            • 1 / 4
