    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 402.2k Views 80 Watching
      Anton_S
      3.5.0 Dec 15, 2013
      • Added customizable shortcuts, thanks to CadFather.
      • Added drag, clip, snap dialog.
      • Added dialog clear borders option.
      • Changed default set/remove menu shortcut key from ALT to F12.
        laudhi
        sketchup always freeze when i make a rectangle and select the face,right click and press R
        I tried without any other plugin.......
        (sketchup make,windows 7 x64)
        btw,thanxz for the plugin..... πŸ˜„
          Anton_S
          Thank you for the report laudhi.
          I found and fixed it. Download the latest version of AMS Library.
            laudhi
            thanks Anton_S,now everything is running smoothly without any problems with other plugins 😍
            i love the floating window....
              Anton_S
              3.6.0 Jan 29, 2014
              • Figured out a way to keep all shortcuts working while the menu bar is removed. The fancy shortcuts sections and the show/hide menu bar option were removed. They are no longer required! πŸ˜„
              • Fixed the get screen resolution function in AMS library. Now, it will return the size of all monitors combined. This fixes an issue where the dialog could not be moved to another screen.
              • Simplified and improved stuff.
              • CadFatherC Offline
                CadFather
                Master Anton strikes again - thanks!
                • U Offline
                  unearthed
                  Thanks for this plugin Anton, it's arguably the number 1 plugin for me as it enables me to quickly clear my screen for online client presentations. The only thing is could the floating black dialog be made smaller?
                  Growplan - People ∩ Plants ∩ Place
                  windows 7 64b, 4GB RAM, SU 8.0.16846
                  Gimp, QGIS, Vectorworks 12, Bricscad 11
                    Anton_S
                    Thank you, CadFather!
                    I'm glad you like it. πŸ˜„ I've been thinking about making another collapsible on top, that would collapse/uncollapse all other collapsibles. Perhaps this feature could be available in the next release. Thanks for suggestion!
                    • V Offline
                      vicxp0518
                      @unclex said:
                      and i can not dare try the Menu Option, if i close it, how reopen it ??
                      Yes i'm encountering with the problem 😞 It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
                        Anton_S
                        Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
                        If you don't have any shortcuts, and made it so all elements hide at start, do the following:
                        1. run regedit.exe
                        2. If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
                        3. Delete the Plugins_ams folder. This will reset all plugin data.
                        Next time, have assign shortcut to reset.
                          Anton_S
                          @vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
                          • H Offline
                            HirokaMatsuiko
                            this is wonderful plugin
                            my shortcut is almost full
                            request if can future updates
                            add Full Screen Button toggle on / off for toolbar
                            thank you again
                              Anton_S
                              Added!. πŸ‘
                                Jim
                                Really nice plugin, Anton. Thank you.
                                • W Offline
                                  whiteanne
                                  I have a proble when running this plugin(latest version) on sketchup pro 2014,it shows like the photo below. Can anyone tell me what should I do to fix it??? it would helps,thats really a useful plugin.
                                    Anton_S
                                    It seems Sketchup.register_extension is undefined. Scroll down to line 33 and add :: in from of the word Sketchup, save, and test.
                                    It should look like this:
                                    ::Sketchup.register_extension @extension, true
                                    If it doesn't work then your SU was modified, or some files were deleted. Try re-installing SketchUp and see what happens.
                                    • ArchieAA Offline
                                      ArchieA
                                      Windows 8, SU 2014. There's no Plugins folder to unzip ams_Lib_1.0.8.zip so I extracted the files to the folder Tools.
                                      Fullscreen still doesn't work.
                                      How to I get rid of the annoying popup stating, Download ams_Lib? Or remove the plugin?
                                      Thanks in advance.
                                        Anton_S
                                        @archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                                        This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
                                        • ArchieAA Offline
                                          ArchieA
                                          Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
                                          • chriC Offline
                                            chri
                                            Hi Anton
                                            You have done a great job πŸ‘
                                            Is-it difficult to create a file ( rb for example ) to change the commands language ?
                                            I have done a french example of what i mean on the next pictures .
                                            Bye
                                            Chri
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
