    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 434.3k Views 80 Watching
    • V Offline
      vicxp0518
      @unclex said:
      and i can not dare try the Menu Option, if i close it, how reopen it ??
      Yes i'm encountering with the problem ๐Ÿ˜ž It's bad to me, 'cos I've already hidden everything in the window include the menu bar, then, how can I bring it back again?? I've got nothing to do with my Sketchup now even if I reinstalled both SU and this plugin. Please tell me.
        Anton_S
        Didn't you download the latest version? Use F12 to toggle the menubar and it would be a good idea to assign more shortcuts, as well. For example, SHIFT-S could be used to toggle statusbar, SHIFT-D could be used to toggle toolbar containers, and F11 could be assigned to toggle fullscreen. The latest version automatically assigns F12 shortctut at the begging of use.
        If you don't have any shortcuts, and made it so all elements hide at start, do the following:
        1. run regedit.exe
        2. If using SU6-SU8, locate to HKEY_CURRENTUSER/Software/Google/Sketchup[n]/, otherwise locate HKEY_CURRENTUSER/Software/SketchUp/SketchUp[n]/
        3. Delete the Plugins_ams folder. This will reset all plugin data.
        Next time, have assign shortcut to reset.
          Anton_S
          @vicxp0518, I updated the plugin so the menubar remains visible on start, under certain conditions. Download the latest version 3.7.3 and your good to go.
          • H Offline
            HirokaMatsuiko
            this is wonderful plugin
            my shortcut is almost full
            request if can future updates
            add Full Screen Button toggle on / off for toolbar
            thank you again
              Anton_S
              Added!. ๐Ÿ‘
                Jim
                Really nice plugin, Anton. Thank you.
                • W Offline
                  whiteanne
                  I have a proble when running this plugin(latest version) on sketchup pro 2014,it shows like the photo below. Can anyone tell me what should I do to fix it??? it would helps,thats really a useful plugin.
                    Anton_S
                    It seems Sketchup.register_extension is undefined. Scroll down to line 33 and add :: in from of the word Sketchup, save, and test.
                    It should look like this:
                    ::Sketchup.register_extension @extension, true
                    If it doesn't work then your SU was modified, or some files were deleted. Try re-installing SketchUp and see what happens.
                    • ArchieAA Offline
                      ArchieA
                      Windows 8, SU 2014. There's no Plugins folder to unzip ams_Lib_1.0.8.zip so I extracted the files to the folder Tools.
                      Fullscreen still doesn't work.
                      How to I get rid of the annoying popup stating, Download ams_Lib? Or remove the plugin?
                      Thanks in advance.
                        Anton_S
                        @archieA The plugins folder is located in %appdata%\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                        This plugin is not a standalone plugin. It requires AMS Library. Here is the link: http://sketchucation.com/forums/viewtopic.php?t=55067#p499835 Extract AMS Library in the plugins folder as well.
                        • ArchieAA Offline
                          ArchieA
                          Thank you. I got it working on SU 2014 on Windows 8. Easy enough when it's clear. I've started using it using F12 to toggle. Great plugin!
                          • chriC Offline
                            chri
                            Hi Anton
                            You have done a great job ๐Ÿ‘
                            Is-it difficult to create a file ( rb for example ) to change the commands language ?
                            I have done a french example of what i mean on the next pictures .
                            Bye
                            Chri
                              Anton_S
                              Very well, I'll add the description to first post. ๐Ÿ˜„
                              Yeah, its quite difficult to translate webdialogs.
                              I heard Aerilius created a method, that could translate the Webdialog, so we'll see.
                              Thanks for request.
                              • JQLJ Offline
                                JQL
                                Hi Anton,
                                I don't think this plugin is 2015 ready or is it?
                                www.casca.pt
                                Visit us on facebook!
                                  Pherim
                                  It's not, because AMS library isn't.
                                  • CadFatherC Offline
                                    CadFather
                                    Thank you Master Anton!
                                    (can't believe i was even few weeks without WS!)
                                    laptop is smiling again. ๐Ÿ˜„ ๐Ÿ˜Ž
                                      @max
                                      That laptop is unique.
                                      Treasure it
                                        CadFather
                                        true... ๐Ÿ˜† and you should see it now!
                                        PS. easy with your psychic powers.... (i sold it today) ๐Ÿ˜ฎ
                                          They say there's one born every minute.
                                            CadFather
                                            hahaha... not at all mister, this is a beast which should last plenty (unless you jinx it!) ๐Ÿ˜†
                                            • 14
                                            • 15
                                            • 7 / 15
