    Sample Model for Rendering - Ferrari
    79 Posts 25 Posters 28.9k Views 25 Watching
    • micioneM
      micione
      Another test with Renditioner V3
      • BoxB
        Trying to get Christmas organised, still need the decorations but I've got the boy's toys all lined up.
        All SU geometry except the three framed pictures and the foggy trees outside.
        Twilight Render no post.
        • 3dita3
          3dita
          Nice one Micione πŸ˜‰
          3dita - Digital Visual Motion
          • micioneM
            micione
            3dita, grazie mille.
            Un saluto alla tua bella cittΓ  .
            • majidM
              majid
              When you may not sleep , rendering is one of best choice instead... thea render
              • cottyC
                cotty
                You donn't render when you sleep? πŸ˜‰
                πŸ‘
                my SketchUp gallery
                • FrederikF
                  Frederik
                  @micione said:
                  Con IRender nxt .
                  So... How long time did it take to render these...?
                  Cheers
                  Kim Frederik
                  • micioneM
                    micione
                    Frederik,
                    With Renditioner, the rendering time is about two minutes.
                    With Irender nxt, about four minutes.
                    Of course you have to calculate the time for the setting:
                    average: ten minutes for both.
                      dtrarch
                      Paint finish example.
                      A old test using ATL 4.1 and included Maxwell auto paint shader.
                      IMO car show finish for paint. πŸ‘
                      Super reflections of the other model elements.
                      (No other elements were textured for final render.)
                      dtr
                      • majidM
                        majid
                        It took about 17 min on my old laptop (the original render is larger), and some times to tweak, I used the material template system. Thanks to Tomasz πŸ˜„
                        • majidM
                          majid
                          Just modified the color manually and rendered these:
                          • NigeCN
                            NigeC
                            I thought I'd have a quick try, thanks majid for the heads up πŸ˜‰
                            Thea progressive (AO) 5 minutes
                            β€œIt’s only impossible if you stop and think about it!”
                            • majidM
                              majid
                              Nice render, and what about the trees? are they 3D or part of IBL?
                              • NigeCN
                                NigeC
                                geometry wise its just the car and a plane, I used a frontal projection texture *the background image)on the plane
                                here's a skp with how I did it, it'll only work as Thea materials
                                https://dl.dropboxusercontent.com/u/26539256/frontalprojection.rar
                                • majidM
                                  majid
                                  Thank you for sharing πŸ‘
                                  • jeff hammondJ
                                    @al hart said:
                                    We received an email from a SketchUp user who liked a rendering of a Rhino Model using Brazil better than the renderings he saw of SketchUp models.
                                    We have often wondered if it is the Nurbs Geometry in Rhino which makes good renderings
                                    for what it's worth.
                                    rhino renders are still meshes.. all the surfaces you see visually on screen are meshes.. the renders produced from rhino models are meshes.. etc.. and often, those meshes are worse than what you might create had a similar model been drawn in sketchup.
                                    one of the main differences you'll notice when coming from a sketchup background is that when drawing, those meshes are completely ignored by the program (unless you want to use them for whatever reason).. all the calculations are being based off of the true surfaces which are being represented by control points instead of a series of vertices&edges..
                                    here are a few pictures which might help visually explain what i'm getting at to someone proficient in sketchup.. (for sake of example, i've set my renderMesh setting real low here.. it doesn't actually look this bad while you're drawing in rhino but you do bump into to from time to time.. in short, if you're using nurbs apps, ignore the surfaces and only concern yourself with the wires.)
                                    here are the outline curves for a revolved surface: (arcs/curves/etc in rhino appear as true curves on screen-- it's the surfaces which don't)
                                    click pic for a little cleaner view
                                    this is the surface.. the pink lines are the lines/vertices of the mesh and if i exported this model to sketchup (or a rendering app), these pink lines are exactly what i'd get upon import.
                                    same view as above only zoomed in.. again, the black curves are the true surface borders..
                                    setting up for an intersect: (this is where things can start going sour in sketchup πŸ˜‰ )
                                    after the intersect.. notice the mesh had nothing to do with it.. i'm left with the true intersecting curve between the two surfaces.
                                    so i could keep going on and on with this stuff and point out some very advantageous aspects of nurbs modeling (especially if the model is meant to be built in real life) but i'll stop here.. the above possibly outline it enough..
                                    my main point though has to do with the guy saying models drawn in rhino will produce better renders.. because i sort of think that's baloney.. there's nothing inherently better or different about a mesh coming out of rhino or one coming out of sketchup (and again, often times i can get better meshes out of sketchup because sometimes, rhino likes to give me a bunch of long skinny triangles very close to each other and my render app doesn't like that too much πŸ˜‰ )
                                    i've never used brazil so i wouldn't know if it's better or worse than say maxwell or vray but i can't imagine that it would be.. most people i know of using rhino are rendering in those apps anyway.
                                    i'd definitely rather build a car which was drawn in rhino instead of sketchup but if we're talking renders, that difference no longer exists for the most part.
                                    just another fwiw.. this is the mesh settings i typically work with in rhino.. slightly above a medium setting.
                                    but one of the nice things about the way it's set up is you can draw with fast&jagged meshes all day long then export for 3D prints or rendering etc with very dense meshes- very easily.
                                    (also, you don't visually see these pink mesh outlines while working.. i'm just showing it this way for sake of explanation)
                                    • NigeCN
                                      NigeC
                                      another try:
                                      • alexandre skA
                                        alexandre sk
                                        great renders!
                                        • AdamBA
                                          AdamB
                                          Waaay late for the party, but this is SU2014 + LightUp using hdr IBL (Image Based Lighting) with a Shadow Catcher Material underneath.
                                          Lighting time: 2min 8sec (then realtime)
                                          • olisheaO
                                            olishea
                                            Great Adam, very convincing. Your last image looks totally real Majid, well done! I love your images too Nige! I also particularly like your signature, it reminds me of how I act sometimes. I overthink things. haha
                                            oli
                                            • 4 / 4
