    Multiple Offset?
    23 Posts 7 Posters 2.0k Views 7 Watching
      Well, unfortunately, neither one does what I want but thanks. Both require a face or at least a closed loop of edges. I have an open Bezier curve I want to run a multiple offset on.
      • gillesG
        gilles
        A picture, a model of what you want?
        • massimoM
          massimo Moderator
          Have you already tried with the native offset tool Dave? No surface or closed loop needed. Offset the curve then double click on the new curve and so on.
            jpalm32
            @dave r said:
            Thank you. It's odd that it doesn't come up when I searched. Especially so since the name is exactly what I was searching for. πŸ˜’
            Search has been letting me down also. With names that should show up.
              I just want to make a series of offsets of a curve like this:
              And wind up with something like this:
              I know I could use the double click. For the task that made me think of this, I know the overall width and the number of spaces between. I thought it would be nice to be able to make the outermost offset, hit Enter and then type /7, Enter and wind up with all the offsets spaced evenly between. As I said before, it would work like Move/Copy to make arrays.
              In the case of the model I'm working on at the moment, the offset distance isn't an easy dimension but the overall thickness is.
              • gillesG
                gilles
                You could draw the thickness as a line divide it to have accurate inferences to offset.
                • cottyC
                  cotty
                  And here's the picture to "your" great idea πŸ˜‰
                  my SketchUp gallery
                    Gilles and Cotty, that's what I wound up doing. I just thought it would be nice to have a more direct option. Maybe I'm the only one who would ever use the tool that way.
                    Box, I'll see what I get with that. Thanks.
                    • BoxB
                      Offset once and use curviloft for the subdivision.
                      • BoxB
                        I fixed a screenr issue I'd been having so made quick vid as a tester.
                        [screenr:1ayanbpo]gWHN[/screenr:1ayanbpo]
                        • cottyC
                          cotty
                          Java issue?
                          my SketchUp gallery
                          • BoxB
                            Yep
                            • gillesG
                              gilles
                              Brillant and fast method.
                                Box, thanks for that. Very helpful.
                                • cottyC
                                  cotty
                                  @box said:
                                  Yep
                                  How did you solve it? I wasn't able...
                                  my SketchUp gallery
                                  • BoxB
                                    It's the upgraded security of the new java version that causes the problem, hopefully screenr will adjust their page to suit in the future. But fixing it is easy, you just need to add screenr to java's security exceptions list. I screenr'd how for you, note I remove the site first so I can type it in and show you the warning message, you shouldn't have it there to remove, just add.
                                    If you don't have the option to add exceptions then you don't have the most recent Java.
                                    If you are feeling young and vigorous and want to live life to the full without restrictions and throw caution to the wind,You can simply adjust the security level slider down to the minimum, that works too.
                                    Oh, this is Win7 other systems may be different but it will be there somewhere.
                                    [screenr:1z0qipxk]upHN[/screenr:1z0qipxk]
                                    • cottyC
                                      cotty
                                      Thank you very much, Box, works great!
                                      my SketchUp gallery
                                      • BoxB
                                        No worries Carsten, but next time it breaks it's your turn to fix it and tell me how.
