    [Plugin] Window Tools 1.1
    19 Posts 16 Posters 24.3k Views 16 Watching
    • CadFatherC
      CadFather
      @tomot said:
      CadFather: I don't mind seeing an expanded Architect Tool bar with Window Tools 1.1 and Door Tools being part of it......Go for it! ...... Just don't get me in trouble with your partner πŸ˜„
      πŸ˜† - Thanks Tomot! you will be the first to receive it if i do..
        123zxy
        Perdon, Pero hablo muy mal ingles:
        Serian tan amables de comprimir el archivo en extension zip?
        Gracias Carlos
        • EdsonE
          Edson
          Gracias Carlos
          ahi lo tienes, carlos. there you have it, carlos.
          WindowTools1.1.zip
          http://www.mahfuz.arq.br
          • G
            gksl4
            Very nice job,
            Thanks,
            George
              decorarq
              Muchas Gracias http://www.sketchucation.com/forums/scf/posting.php?mode=reply&f=180&t=14394# very easy to ese thanks a lot
              • PixeroP
                Pixero
                Does the new version also work as the old one? I mean adding windows to existion holes?
                I usually use that method and if not, could you add both functionalities.
                • T
                  tomot
                  There are only 2 lines of code I added in order to cut the opening,
                  which the previous version did not have. I was not able to make this
                  new script automatically recognize an opening from a face, at this time.
                  Hence if you prefer to use the opening method only, then remove the following 2 lines of code. from glass_tool.rb and frame_tool.rb
                  #-------Cut Face
                      base=entities.add_face(@pt0jj, @pt1jj, @pt2jj, @pt3jj)
                      base.pushpull -$kqBC45
                  my plugins
                  tomot
                  • arquitectomaracuchoA
                    arquitectomaracucho
                    πŸ‘ πŸ‘ I am an architect and I feel very good improvement, is revolutionary, I can add options for example 2 windows or sliding panels swing, besides giving the same property of cutting tools wall to door. For the rest thank you very much!
                    • deaneauD
                      deaneau
                      i have now two version of mullion, could you write the mullion.rb so that i have two version to choose in dropdown.
                      the new version looks like a windows in a yail πŸ˜‰
                      the first picture is the new mullion
                      thank you
                      dean
                        ReyT
                        Your trim tool both side option is not working.
                        • G
                          gap007
                          I have installed New version Sketchup 2014 but your wiindow tools are not working!
                          Please let me know how to fix?
