    Re; Animation output - DOES NOT create AVI file when it's a
    28 Posts 6 Posters 5.7k Views 6 Watching
    • bikerchrisB
      bikerchris
      Thanks Dave, much appreciated. I've deduced that I have a problem with the sketchup install. I don't know whether a plugin is effecting it, but it's making any AVI output files that exceed 1GB, completely unusable. Also, if I try to make just one AVI output file of all the scenes, sketchup appears to be creating the slides, and then gets to the end and produces NO FILE. I have even found that if I cancel the process part way through, the file DOES appear.
      I'm quite annoyed to put it mildly.
        Did you try disabling plugins to make sure it isn't a problem caused by one of them? If that doesn't change anything, try reinstalling SketchUp from a fresh download.
        • bikerchrisB
          bikerchris
          I have disabled all plugins apart from Twilight. Next up seems to be to re-install 😞
            Do you need Twilight running?
            • bikerchrisB
              bikerchris
              Hi all,
              Quick and easy question, what experiences have you had with AVI file sizes and what's the biggest you've been able to create.
              Also, have you ever had the slide creation process occur without issue, only to find that at the end of it, you are not provided with an AVI file OR error messages?
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-29-07.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-31-55.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-39-31.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-40-18.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-40-53.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-41-02.png
              http://www.bikerchris.co.uk/wp-content/gallery/sketchup-no-animation-file/screenshot-2014-02-06-18-41-21.png
              • bikerchrisB
                bikerchris
                I disabled it, restarted sketchup, same result 😞
                • bikerchrisB
                  bikerchris
                  I've also now restarted the PC and still the same thing occurs. πŸ˜•
                  • cottyC
                    cotty
                    With Windows file system Fat32, the maximum file size for a single file is 4GB and your pictures show that you crossed this border...
                    my SketchUp gallery
                    • cottyC
                      cotty
                      Answer in your new topic ❓
                      my SketchUp gallery
                      • bikerchrisB
                        bikerchris
                        Quite right, I'm using NTFS though, and have had other single file types with sizes exceeding 20GB and over.
                        • bikerchrisB
                          bikerchris
                          Response to your answer in that new topic πŸ˜„
                            dtrarch
                            Hi bikerchris
                            Checkout Magix Moviemaker pro πŸ‘ πŸ‘
                            (my choice)
                            I have tried them all even the hi-price stuff too.
                            Here is a link and demos to try too.
                            IMO very easy to use and good value
                            http://www.magix.com/us/movie-edit-pro/
                            dtr
                            • bikerchrisB
                              bikerchris
                              Cheers for that dtrarch, I think the problem is a limitation with sketchup, but I just want some confirmation that others have had similar problems, and then I can rest!
                              Cheers,
                              • B
                                blackdogsketch
                                I know this is a year old, but I'm having the same experience. And it's truly frustrating...no error message...nothing. Just no file to be found.
                                What I don't get is how Windows Movie Maker comes into play. To me, I ask Sketchup to generate a file.
                                This means it goes and gets Movie Maker to do it's work?
                                Why is sketchup so lame- even Pro- it seems year after year the capabilities do not increase.
                                It's hard to believe that I cannot get sketchup to make anything over 1GB video file out of the box. I've got to go back to my team and tell them I cannot do this.
                                So I need to go and spend more money on a video making program? And then what happens, sketchup automatically looks for that to make the video? there are no options under "export video" to select the video engine.
                                Maddening.
                                • B
                                  blackdogsketch
                                  Plus, what I don't get is that Bikerchris has a file that's 201Mb. (see his "progress dialog box" screenshot) Not 2GB!
                                  You can't even get a 200 MB file generated from SU??? That is FAR from a large file when you're talking about video.
                                  • P
                                    pat gunter
                                    SAME THING HAPPENS TO ME! 😞 so annoying,, that at least a error message doesnt come up at least. win7 64 4gig ram. so 4gigs is the max for the vid size i take it? guess only fix is, to make multiple sketchup file copys and then doing it in parts, and then put vids together in some movie making program. https://www.youtube.com/watch?v=NK9IULYXvTU
                                    • bikerchrisB
                                      bikerchris
                                      Something I started doing was using MP4's, as the file size is much smaller - the sacrifice being the quality sometimes, but it's good enough for my needs.
                                      What you mentioned is what I did though, just stitch them together in some movie editing software. Hey ho!
                                      • 2 / 2
