    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 164.6k Views 46 Watching
      Is there any chance you could describe the problem?
      • KrisidiousK
        Krisidious
        Love the plugin updater...
        By: Kristoff Rand
        • LanaL
          Lana
          It's is new for me. Thankssssssss 😍
          • fredo6F
            NEW RELEASE: SUClock v1.5a - 27 Nov 13
            SUClock 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
            • P
              paul.wacko
              Capture.JPGI am getting this error message when I am trying to start s clock to an existing file
              • fredo6F
                @paul.wacko said:
                [attachment=0:3v99e7vw]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:3v99e7vw]I am getting this error message when I am trying to start s clock to an existing file
                You need to choose a file with .suclock extension, not skp.
                • P
                  paul.wacko
                  Thanks for that.
                  I had worked it out and felt rather stupid not realising the skp extension.
                  However it would be nice to have the option to edit the session time or add session times for additional things such as Photoshop PP etc...
                  Paul
                  • fredo6F
                    The only thing you can do currently is to export to Excel and then add other duration items.
                    SUClock is only aware of the activiy in SU and the Ruby API does not allow making a difference between being idle in SU and being in another applications.
                      rythm
                      Hi Fredo6,
                      I just downloaded your SUClock plugin and would love to try it out but when I try to attach an existing file (after clicking the little clock icon) to it I get the image attached.
                      I also tried attaching different files, and tried to attach a new project and get the same results.
                      I have Macbook Pro, OS X, 10.7.5 and plenty of power behind it.
                      Any thoughts? Solutions?
                      Thanks,
                      -R
                      • fredo6F
                        The files created and manipulated by SUClock have extension .suclock, not .skp. Please refer to the documentation.
                        • L
                          lucap90
                          hello. I have a problem with suclock. I installed everything and when i turn on the program and press the clock icon nothing happens, no icon like this http://sketchucation.com/forums/download/file.php?id=67045 have you got some idea for this problem?
                            Perhaps you missed installing LibFredo6?
                            • L
                              lucap90
                              Of course I installed LibFredo...
                                How did you install them? Exact steps, please.
                                • L
                                  lucap90
                                  well...first I downloaded Fredo6_SUClock - v1.5a - 27 Nov 13.zip and LibFredo6 5.4b. Then I unzipped both files and put them to the folder: Program Files (x86)\Google\Google SketchUp 8\Plugins. After that I ran the sketchup and It was white small clock icon like this http://jroot.sketchucation.com/pluginrepo/image/SUClock.png When I clicked this icon opened a window with project 'Tracking of the Model in Project' and I tried to use 'Attach to New Project' or 'Attach to an existing Project' and finally when I clicked 'done' nothing happened. I think that then should be small icon http://sketchucation.com/forums/download/file.php?id=67045 to time count. I don't know what i'm doing wrong....
                                    The plugin clearly works in SketchUp 8 so it must be something on your end. Historically, the most common reason that plugins fail to work correctly when installed from the ZIP file is that the user extracted the contents incorrectly and destroyed the file structure. This is the reason for the RBZ files for plugins. Go into the Plugins folder and delete all of the files and folders related to this plugin. Download the RBZ file and use Install Extension from Preferences>Extensions to install it. Then try the plugin again.
                                    Even better would be to install the Sketchucation PluginStore and use it to automatically install plugins.
                                    • fredo6F
                                      NEW RELEASE: SUClock v1.6a - 20 Oct 14
                                      SUClock 1.6a is required for the support of usernames with non-ascii characters in Sketchup 2014
                                        smartsizer
                                        I'm having a similar problem. I am using a Dell Precision T3400, running Windows Vista Business SP2, with Sketchup 14.1.1282.
                                        I have deleted old versions of SUclock and LibFredo, and re-installed fresh versions of both of these from Sketchucation just yesterday. The installation seemed to go normally. When I open a new file and save it, I can then use SUclock normally. If I then close the file and re-open it, when I click on the SUclock icon, nothing happens. If I select all entities, copy them and paste into a new file, the SUclock will work (the first time). After saving and closing, the SUclock will not work.
                                        Any tips on how to fix this?
                                        • fredo6F
                                          Could you open the Ruby Console and check if there are messages when launching SUClock.
                                            smartsizer
                                            Nothing at all shows up in the Ruby Console windows.
                                            • 4 / 7
