    [Plugin] SUClock - v3.1a - 02 Apr 24 - Tracking time in SU
    138 Posts 46 Posters 164.6k Views 46 Watching
      rv1974
      Is there way to permanently hide 'check plugins for update' window (the small yellow one with ruby)?
        mwm5053
        You should only see it every 15 days or so, good to have if there have been updates, bug fixes and such.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          That's part of LibFredo. Set the frequency to 999 to disable.
            If you really don't want to see it every 15 days, go to window>LibFredo6 Settings>Default Parameters and change it.
            As Walt says, though, it doesn't hurt to have it pop up. It makes it easy to check for updates.
              JFought
              really having a problem installing this. I could use some help.
                Is there any chance you could describe the problem?
                • KrisidiousK
                  Krisidious
                  Love the plugin updater...
                  By: Kristoff Rand
                  • LanaL
                    Lana
                    It's is new for me. Thankssssssss 😍
                    • fredo6F
                      NEW RELEASE: SUClock v1.5a - 27 Nov 13
                      SUClock 1.5a is a release for future Sketchup compatibility. It is advised to upgrade even if there are no functional changes.
                      • P
                        paul.wacko
                        Capture.JPGI am getting this error message when I am trying to start s clock to an existing file
                        • fredo6F
                          @paul.wacko said:
                          [attachment=0:3v99e7vw]<!-- ia0 -->Capture.JPG<!-- ia0 -->[/attachment:3v99e7vw]I am getting this error message when I am trying to start s clock to an existing file
                          You need to choose a file with .suclock extension, not skp.
                          • P
                            paul.wacko
                            Thanks for that.
                            I had worked it out and felt rather stupid not realising the skp extension.
                            However it would be nice to have the option to edit the session time or add session times for additional things such as Photoshop PP etc...
                            Paul
                            • fredo6F
                              The only thing you can do currently is to export to Excel and then add other duration items.
                              SUClock is only aware of the activiy in SU and the Ruby API does not allow making a difference between being idle in SU and being in another applications.
                                rythm
                                Hi Fredo6,
                                I just downloaded your SUClock plugin and would love to try it out but when I try to attach an existing file (after clicking the little clock icon) to it I get the image attached.
                                I also tried attaching different files, and tried to attach a new project and get the same results.
                                I have Macbook Pro, OS X, 10.7.5 and plenty of power behind it.
                                Any thoughts? Solutions?
                                Thanks,
                                -R
                                • fredo6F
                                  The files created and manipulated by SUClock have extension .suclock, not .skp. Please refer to the documentation.
                                  • L
                                    lucap90
                                    hello. I have a problem with suclock. I installed everything and when i turn on the program and press the clock icon nothing happens, no icon like this http://sketchucation.com/forums/download/file.php?id=67045 have you got some idea for this problem?
                                      Perhaps you missed installing LibFredo6?
                                      • L
                                        lucap90
                                        Of course I installed LibFredo...
                                          How did you install them? Exact steps, please.
                                          • L
                                            lucap90
                                            well...first I downloaded Fredo6_SUClock - v1.5a - 27 Nov 13.zip and LibFredo6 5.4b. Then I unzipped both files and put them to the folder: Program Files (x86)\Google\Google SketchUp 8\Plugins. After that I ran the sketchup and It was white small clock icon like this http://jroot.sketchucation.com/pluginrepo/image/SUClock.png When I clicked this icon opened a window with project 'Tracking of the Model in Project' and I tried to use 'Attach to New Project' or 'Attach to an existing Project' and finally when I clicked 'done' nothing happened. I think that then should be small icon http://sketchucation.com/forums/download/file.php?id=67045 to time count. I don't know what i'm doing wrong....
