    Get MAC Address
    55 Posts 8 Posters 6.2k Views 8 Watching
      driven
      There's also this one
      mac_MAC = %x(ioreg -rd1 -c IOPlatformExpertDevice |  awk "/IOPlatformUUID/ { print $3; }")
      returns
      "IOPlatformUUID" = "00000000-0000-1000-8000-00**********" [my address obscured with ***]
        pgarmyn
        @dan rathbun said:
        DUh... I just stumbled upon GetMAC.exe on my Win 7 machine....
        Yes, i have it also on Win8.1 👍
        For the MAC-world (Apple-users) is there an equivalent ❓
          driven
          @pgarmyn said:
          For the MAC-world (Apple-users) is there an equivalent :?:
          I just posted it above?
          The command ioreg located in /usr/sbin/ioreg is used to display the I/O Kit registry.
            pgarmyn
            👍 👍 👍 @driven
              driven
              @pgarmyn said:
              :thumb: :thumb: :thumb: @driven
              Well, maybe not three thumbs... it's unclear to me if that's a standard or an xtool instal, so a safer bet would be
              getMACADDRESS = %x(/usr/sbin/networksetup -getMACADDRESS en0 | /usr/bin/awk '{print $3}' | /usr/bin/sed s/;//g)
              which returns
              001ec*******
              the mac MAC address using standard instal items...
              • Dan RathbunD Offline
                Dan Rathbun
                There IS a gem that can be used for reference (perhaps it can be made SketchUp friendly.)
                macaddr/lib/macaddr.rb at master · ahoward/macaddr
                cross platform mac address determination for ruby. Contribute to ahoward/macaddr development by creating an account on GitHub.
                GitHub (github.com)
                I'm not here much anymore.
                  Garry K
                  I'm back at this MAC address - specifically for first Ethernet device.
                  This code seems to work fine for Windows 7 - but will it work for OSX ??
                  Has anyone tried this in a French computer or some other language?
                  ` def get_mac_address()
                  return @mac_address if defined?( @mac_address )
                  @win = ( RUBY_PLATFORM =~ /darwin/i ) == nil
                  tmp = ""
                  str = ""
                  first = true
                  if ( @win )
                  # for windows put results in array - splitting on newline
                  ipa = %x[ipconfig /all].split("\n")
                  # check begining of string for 'Ethernet' and set flag once found
                  # then check for 'Physical Address' and look at everything after the ':'
                  # set mac_address and return
                  ipa.each {|line|
                    tmp = line.strip
                    str = tmp[0..7]
                    if ( first )
                      first = false if ( "Ethernet" == str )
                    elsif ( "Physical" == str )
                      pos = tmp.rindex( ":" )
                      @mac_address = tmp[pos+2, tmp.length ]
                      return @mac_address
                  else
                  tmp = %x[ifconfig eth0].strip
                  pos = tmp.rindex( " " )
                  @mac_address = tmp[pos+1, tmp.length ]
                  return @mac_address
                  return ""
                  end`
                    pgarmyn
                    @Garry
                    As i said before, this only works for US or EN OS.
                    The output of ipconfig depends on the OS language.
                    In French you will have to scan for "adresse physique" and for the other languages....
                      Garry K
                      This works in Windows 7
                      	return @@mac_address if defined?( @@mac_address )
                      	if ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                      		cmd = 'ipconfig /all'
                      	else
                      		cmd = 'ifconfig'
                      	macs = []
                      	lines = %x[#{cmd}].split("\n").grep( /^.*\s([0-9a-f|A-F]{2}[:-]){5}([0-9a-f|A-F]{2})$/ )
                      	lines.each{|line| macs << line.strip[-17,17] }
                      	@@mac_address = macs.first.gsub( '-', ':' )
                        Garry K
                        Thanks pgarmyn - I was just confirming the language thing
                        I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
                        I have cleaned this up so if it is benefit to others
                        mac_addr = []
                        cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
                        # choose lines that have only six pairs of 2 char hex values separated by either a : or -
                        # pattern must start with a space and be at the end of the line
                        # there can be white space at the end of the line
                        lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
                        lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
                        # if windows and we have more than 1 mac address use the second one otherwise use the first
                        # if not windows then use the first address
                        index = @@windows && mac_addr.length > 1 ? 1 : 0
                        @@mac_address = mac_addr[index]
                        end`
                          driven
                          @gary
                          couple of changes needed to run on my mac,
                          got rid of class variables
                          added windows =
                          added simplified regex = with .. for grep
                          windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                          return mac_address if defined?( mac_address )
                          mac_addr = []
                          cmd = windows ? 'ipconfig /all' ; 'ifconfig'
                          # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                          regex = Regexp.compile("(..[;-]){5}..")
                          lines = %x[#{cmd}].split("\n").grep( regex )
                          lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
                          index = windows && mac_addr.length > 1 ? 1 ; 0
                          return mac_address
                          > get_mac_address 00:1e:c4:16:08:46
                            Garry K
                            Thank-you very much, I appreciate this, since I don't have access to a mac.
                            I will test on Windows with your simplified regex.
                            You show the mac_address as lower case - can you confirm that is indeed the output.
                            Also - off topic - but how do you get the source code to go into the embedded window?
                              driven
                              yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
                              the one with the red circle...
                                Garry K
                                Thanks again. I checked the code for windows and it works fine.
                                I've added an upcase on the following line
                                lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
                                • jaimedaJ Offline
                                  jaimeda
                                  Hello
                                  This works fine in Sketchup 2013 but not in 2014.
                                  Any tips?
                                  • tt_suT Offline
                                    tt_su
                                    Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
                                    <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                    • jaimedaJ Offline
                                      jaimeda
                                      Thanks Thomas.
                                      It works perfectly.
                                        Garry K
                                        <span class="syntaxdefault"><br />tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                                        In my C++ programming for windows I would create a temp file this way
                                        tempfp = tmpfile();
                                        Is there anything in Sketchup that would do the same for both Windows and Mac?
                                        • tt_suT Offline
                                          tt_su
                                          Well,... since we now have the Ruby Standard Library available: http://ruby-doc.org/stdlib-2.0.0/libdoc/tempfile/rdoc/Tempfile.html
                                          So an updated example would be:
                                          <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                                            Dan Rathbun
                                            Weirdly the backquotes, & %x strings which use the ()` method, work on my machine.
                                            And I verified that I do not have the backquote_patch.rb (that I proposed,) loaded.
                                            • 2 / 3
