    Get MAC Address
    55 Posts 8 Posters 8.3k Views 8 Watching
    • G
      Garry K
      Thanks pgarmyn - I was just confirming the language thing
      I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
      I have cleaned this up so if it is benefit to others
      ` def get_mac_address()
      return @@mac_address if defined?( @@mac_address )
      mac_addr = []
      cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
      # choose lines that have only six pairs of 2 char hex values separated by either a : or -
      # pattern must start with a space and be at the end of the line
      # there can be white space at the end of the line
      lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
      lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
      # if windows and we have more than 1 mac address use the second one otherwise use the first
      # if not windows then use the first address
      index = @@windows && mac_addr.length > 1 ? 1 : 0
      @@mac_address = mac_addr[index]
      end`
        driven
        @gary
        couple of changes needed to run on my mac,
        got rid of class variables
        added windows =
        added simplified regex = with .. for grep
        windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
        return mac_address if defined?( mac_address )
        mac_addr = []
        cmd = windows ? 'ipconfig /all' ; 'ifconfig'
        # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
        regex = Regexp.compile("(..[;-]){5}..")
        lines = %x[#{cmd}].split("\n").grep( regex )
        lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
        index = windows && mac_addr.length > 1 ? 1 ; 0
        return mac_address
        > get_mac_address 00:1e:c4:16:08:46
        • G
          Garry K
          Thank-you very much, I appreciate this, since I don't have access to a mac.
          I will test on Windows with your simplified regex.
          You show the mac_address as lower case - can you confirm that is indeed the output.
          Also - off topic - but how do you get the source code to go into the embedded window?
            driven
            yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
            the one with the red circle...
            • G
              Garry K
              Thanks again. I checked the code for windows and it works fine.
              I've added an upcase on the following line
              lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
              • jaimedaJ
                jaimeda
                Hello
                This works fine in Sketchup 2013 but not in 2014.
                Any tips?
                • tt_suT
                  tt_su
                  Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
                  <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                  • jaimedaJ
                    jaimeda
                    Thanks Thomas.
                    It works perfectly.
                    • G
                      Garry K
                      <span class="syntaxdefault"><br />tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                      In my C++ programming for windows I would create a temp file this way
                      tempfp = tmpfile();
                      Is there anything in Sketchup that would do the same for both Windows and Mac?
                      • tt_suT
                        tt_su
                        Well,... since we now have the Ruby Standard Library available: http://ruby-doc.org/stdlib-2.0.0/libdoc/tempfile/rdoc/Tempfile.html
                        So an updated example would be:
                        <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                        • Dan RathbunD
                          Dan Rathbun
                          Weirdly the backquotes, & %x strings which use the ()` method, work on my machine.
                          And I verified that I do not have the backquote_patch.rb (that I proposed,) loaded.
                          I'm not here much anymore.
                          • Chris FullmerC
                            We have seen that if a user drags a skp model onto their SU icon, then they work. but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                            • G
                              Garry K
                              <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                              This is great for 2014 and forward - but what if you want to support earlier versions.
                              I guess we have to either use a one size fits all strategy or check the version an branch appropriately.
                              • Dan RathbunD
                                Dan Rathbun
                                There are whole topic threads on using the TEMP directory.
                                No problem on Mac OSX...
                                The issue on PC is unicode characters in usernames, which cause Ruby 1.8.x to choke.
                                So some coders create a TEMP subdir of THEIR specific plugin's folder.
                                (I think this is better than creating any temp folders in the root dir of the system drive.)
                                • Dan RathbunD
                                  Dan Rathbun
                                  @chris fullmer said:
                                  ... but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                                  NO neither.
                                  I see now, I either have used a pinned shortcut copy (of the desktop icon,) on the taskbar, or a copy on the StartMenu, or from a popup menu of the Desktop taskbar.
                                  These are all single-click ways of launching SketchUp. I usually start SU this way because the Desktop is covered up.
                                  • jaimedaJ
                                    jaimeda
                                    I think this works in 2014 and earlier
                                    <span class="syntaxdefault">IO</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">popen</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"ipconfig/all >temp.txt"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">fd</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> fd</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">readlines</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">lines </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> open</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"temp.txt"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">readlines<br />puts</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">lines</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                                    • G
                                      Garry K
                                      Does this code work with Mac OS.
                                      With windows the tempfile goes to desktop and gets discarded when finished.
                                      Where does the file go for Mac OS and do we have rights?
                                            # do this for testing on a mac
                                            @@windows = false
                                            # do this for testing on windows
                                            # @@windows = false
                                            mac_addr = []
                                            cmd = @@windows ? 'ipconfig /all' ; 'ifconfig'
                                            # separated by either a ; or -
                                            regex = Regexp.compile('(..[;-]){5}..')
                                            tempfile = "temp.txt"
                                            `#{cmd} > #{tempfile}`
                                            File.open(tempfile, 'r') do |file|
                                              lines = file.grep(regex)
                                              lines.each { |line| mac_addr << (line.strip[-17, 17]).upcase().gsub(/-/, ';') }
                                            File.unlink(tempfile)
                                            # then use the second one otherwise use the first
                                            index = @@windows && mac_addr.length > 1 ? 1 ; 0
                                      • Dan RathbunD
                                        Dan Rathbun
                                        The temp file only goes to the desktop by chance that your current working directory is pointing at the desktop directory.
                                        WIN = RUBY_PLATFORM !~ /darwin/i OSX =( not WIN ) desktop_dir = WIN ? "#{ENV['USERPROFILE']}/Desktop" : "~/Desktop"
                                        Assuming that the name of the directory is not language localized, but it likely IS.
                                        You should not ever assume some other script has not changed the working directory.
                                        All older SketchUp versions attempted to set it to the user's home directory.
                                        SketchUp 2014 (on my machine,) has left me in "#{ENV['SystemRoot']}/System32" (why I do not know, but have asked.)
                                        To see what the current working directory is, use:
                                        Dir::getwd
                                        or, it's alias:
                                        Dir::pwd
                                        To temporarily change the working directory (and have it change back to whatever it was,) use the blockform of the Dir::chdir class method.
                                        Dir;;chdir( RUBY_PLATFORM !~ /darwin/i ? "#{ENV['USERPROFILE']}/Desktop" ; "~/Desktop" ) {
                                              @@windows = false
                                              # @@windows = false
                                              mac_addr = []
                                        } # chdir block
                                        To test for access rights:
                                        File::directory?( dirname ) && File::writable?( dirname )
                                        See the File class for other class query methods to determine access info: executable?(), executable_real?(), readable?(), readable_real?(), writable_real?, etc.
                                        Be aware that path strings with unicode characters will not work well under Ruby 1.8.x on PC. (Mac OSX does not have these problems.)
                                        • G
                                          Garry K
                                          Thanks Dan. I should have thought about the whole issue of current working directory. This has been true since the beginning of DOS.
                                          I'm going to put a config folder in my own plugin folder. I can put the temp.txt file there. I can also use the folder to put user custom settings so that updates don't overwrite user settings.
                                          • tt_suT
                                            tt_su
                                            For SketchUp versions older than SU2014 that might cause problems if the user doesn't have full permissions to the Plugins folder since Windows locks down Program Files quite tight. Ruby will in many cases not have write access.
                                            • 2 / 3
