    Get MAC Address
    55 Posts 8 Posters 8.3k Views 8 Watching
      driven
      @pgarmyn said:
      For the MAC-world (Apple-users) is there an equivalent :?:
      I just posted it above?
      The command ioreg located in /usr/sbin/ioreg is used to display the I/O Kit registry.
      • P
        pgarmyn
        👍 👍 👍 @driven
          driven
          @pgarmyn said:
          :thumb: :thumb: :thumb: @driven
          Well, maybe not three thumbs... it's unclear to me if that's a standard or an xtool instal, so a safer bet would be
          getMACADDRESS = %x(/usr/sbin/networksetup -getMACADDRESS en0 | /usr/bin/awk '{print $3}' | /usr/bin/sed s/;//g)
          which returns
          001ec*******
          the mac MAC address using standard instal items...
          • Dan RathbunD
            Dan Rathbun
            There IS a gem that can be used for reference (perhaps it can be made SketchUp friendly.)
            macaddr/lib/macaddr.rb at master · ahoward/macaddr
            cross platform mac address determination for ruby. Contribute to ahoward/macaddr development by creating an account on GitHub.
            GitHub (github.com)
            I'm not here much anymore.
            • G
              Garry K
              I'm back at this MAC address - specifically for first Ethernet device.
              This code seems to work fine for Windows 7 - but will it work for OSX ??
              Has anyone tried this in a French computer or some other language?
              ` def get_mac_address()
              return @mac_address if defined?( @mac_address )
              @win = ( RUBY_PLATFORM =~ /darwin/i ) == nil
              tmp = ""
              str = ""
              first = true
              if ( @win )
              # for windows put results in array - splitting on newline
              ipa = %x[ipconfig /all].split("\n")
              # check begining of string for 'Ethernet' and set flag once found
              # then check for 'Physical Address' and look at everything after the ':'
              # set mac_address and return
              ipa.each {|line|
                tmp = line.strip
                str = tmp[0..7]
                if ( first )
                  first = false if ( "Ethernet" == str )
                elsif ( "Physical" == str )
                  pos = tmp.rindex( ":" )
                  @mac_address = tmp[pos+2, tmp.length ]
                  return @mac_address
              else
              tmp = %x[ifconfig eth0].strip
              pos = tmp.rindex( " " )
              @mac_address = tmp[pos+1, tmp.length ]
              return @mac_address
              return ""
              end`
              • P
                pgarmyn
                @Garry
                As i said before, this only works for US or EN OS.
                The output of ipconfig depends on the OS language.
                In French you will have to scan for "adresse physique" and for the other languages....
                • G
                  Garry K
                  This works in Windows 7
                  	return @@mac_address if defined?( @@mac_address )
                  	if ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                  		cmd = 'ipconfig /all'
                  	else
                  		cmd = 'ifconfig'
                  	macs = []
                  	lines = %x[#{cmd}].split("\n").grep( /^.*\s([0-9a-f|A-F]{2}[:-]){5}([0-9a-f|A-F]{2})$/ )
                  	lines.each{|line| macs << line.strip[-17,17] }
                  	@@mac_address = macs.first.gsub( '-', ':' )
                  • G
                    Garry K
                    Thanks pgarmyn - I was just confirming the language thing
                    I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
                    I have cleaned this up so if it is benefit to others
                    mac_addr = []
                    cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
                    # choose lines that have only six pairs of 2 char hex values separated by either a : or -
                    # pattern must start with a space and be at the end of the line
                    # there can be white space at the end of the line
                    lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
                    lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
                    # if windows and we have more than 1 mac address use the second one otherwise use the first
                    # if not windows then use the first address
                    index = @@windows && mac_addr.length > 1 ? 1 : 0
                    @@mac_address = mac_addr[index]
                    end`
                      driven
                      @gary
                      couple of changes needed to run on my mac,
                      got rid of class variables
                      added windows =
                      added simplified regex = with .. for grep
                      windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                      return mac_address if defined?( mac_address )
                      mac_addr = []
                      cmd = windows ? 'ipconfig /all' ; 'ifconfig'
                      # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                      regex = Regexp.compile("(..[;-]){5}..")
                      lines = %x[#{cmd}].split("\n").grep( regex )
                      lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
                      index = windows && mac_addr.length > 1 ? 1 ; 0
                      return mac_address
                      > get_mac_address 00:1e:c4:16:08:46
                      • G
                        Garry K
                        Thank-you very much, I appreciate this, since I don't have access to a mac.
                        I will test on Windows with your simplified regex.
                        You show the mac_address as lower case - can you confirm that is indeed the output.
                        Also - off topic - but how do you get the source code to go into the embedded window?
                          driven
                          yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
                          the one with the red circle...
                          • G
                            Garry K
                            Thanks again. I checked the code for windows and it works fine.
                            I've added an upcase on the following line
                            lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
                            • jaimedaJ
                              jaimeda
                              Hello
                              This works fine in Sketchup 2013 but not in 2014.
                              Any tips?
                              • tt_suT
                                tt_su
                                Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
                                <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                • jaimedaJ
                                  jaimeda
                                  Thanks Thomas.
                                  It works perfectly.
                                  • G
                                    Garry K
                                    <span class="syntaxdefault"><br />tempfile </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
                                    In my C++ programming for windows I would create a temp file this way
                                    tempfp = tmpfile();
                                    Is there anything in Sketchup that would do the same for both Windows and Mac?
                                    • tt_suT
                                      tt_su
                                      Well,... since we now have the Ruby Standard Library available: http://ruby-doc.org/stdlib-2.0.0/libdoc/tempfile/rdoc/Tempfile.html
                                      So an updated example would be:
                                      <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">require&nbsp;</span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Weirdly the backquotes, & %x strings which use the ()` method, work on my machine.
                                        And I verified that I do not have the backquote_patch.rb (that I proposed,) loaded.
                                        • Chris FullmerC
                                          We have seen that if a user drags a skp model onto their SU icon, then they work. but if they double click on a skp model file, or double click on the SU icon, then it does not work. Are you seeing it work in both scenarios?
                                          • G
                                            Garry K
                                            <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'tempfile'<br /></span><span class="syntaxdefault">file </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Tempfile</span><span class="syntaxkeyword">.new(</span><span class="syntaxstring">'my_prefix'</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">close<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig /all > #{file.path}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">file</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">unlink<br /></span>
                                            This is great for 2014 and forward - but what if you want to support earlier versions.
                                            I guess we have to either use a one size fits all strategy or check the version an branch appropriately.
                                            • 2 / 3
