    Get MAC Address
    55 Posts 8 Posters 9.0k Views 8 Watching
    • G
      Garry K
      This link makes references to it
      http://stackoverflow.com/questions/690151/getting-output-of-system-calls-in-ruby
        driven
        @garry k said:
        I'm reading that back ticks ` won't work in OSX
        where are you reading that? they are interchangeable on a mac. Both return in Ruby Console.
        > puts `ifconfig -a | grep "ether"`
        	ether 00;** ;** ;** ;** ;36
        	ether 00;** ;** ;** ;** ;ad
        nil
        > puts %x(ifconfig -a | grep "ether")
        nil
        but ifconfig will give you more that one ether, so...
         puts (%x(ifconfig -a | grep "ether")).split[1]
        "00;** ;** ;** ;** ;36"
        nil
        or mac only [I think]
        > > puts (%x(netstat -in | grep "en0")).split[3].inspect
        nil
        you'll get what you want...
          slbaumgartner
          That link discusses the various ways to capture the output of a system command and security issues that arise from issuing a system command from Ruby. Nowhere does it say that the backtick syntax does not work on Mac OS X!
          • Dan RathbunD
            Dan Rathbun
            Garry.. this is safer and faster to use boolean Constants throughout your module(s) [ie, Strings are slow.]
            At the top of your module:
            MAC = OSX = RUBY_PLATFORM !~ /mswin|mingw/ PC = WIN = (not MAC)
            Then say down further:
            if WIN
              # do this
            else
              # it's a Mac, do that
            another example, showing a webdialog:
            WIN ? @dlg.show() : @dlg.show_modal()
            I'm not here much anymore.
            • Dan RathbunD
              Dan Rathbun
              @garry k said:
              then for windows I can redirect the output of ipconfig
              null = test(?e, '/dev/null') ? '/dev/null' : 'NUL'
              Why? The %x or backquoted string method returns it's result.
              so:
              ip = %x[ipconfig /all]
              Then parse the string ip,.. iterate it using each_line or
              split("\n") it into an array of lines, then use find, etc.
                driven
                @dan
                does reply_from_ifconig.split("\n").grep("Physical Address") or similar work on a PC?
                EDIT for something as un-changing as ifconfig on a mac you could use
                (%x(ifconfig -a)).split("\n")[10].split[1]
                • P
                  pgarmyn
                  @dan rathbun said:
                  similar:
                  ipa = %x[ipconfig /all].split("\n").grep /\A\s*(Physical Address)/....
                  Scanning for “Physical Address” only gives a result with an EN/US OS
                  This works also on the old continent :
                  def MyModule.mac_address
                  	platform = RUBY_PLATFORM.downcase
                  	iptxt = `#{(platform =~ /win32/) ? 'ipconfig /all' ; 'ifconfig'}`
                  	## delete DHCPv6 ;
                  	iptxt.gsub!(/..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-../,"")
                  	# delete Tunnel ;
                  	iptxt.gsub!("00-00-00-00-","")
                  	## create array with all the physical adresses ;
                  	t_array=iptxt.scan(/..\-..\-..\-..\-..\-../)
                  	#puts t_array.inspect
                  	## returns first physical adresses if one found
                  	return t_array[0] if t_array.length>0
                  	return nil
                    driven
                    There's also this one
                    mac_MAC = %x(ioreg -rd1 -c IOPlatformExpertDevice |  awk "/IOPlatformUUID/ { print $3; }")
                    returns
                    "IOPlatformUUID" = "00000000-0000-1000-8000-00**********" [my address obscured with ***]
                    • P
                      pgarmyn
                      @dan rathbun said:
                      DUh... I just stumbled upon GetMAC.exe on my Win 7 machine....
                      Yes, i have it also on Win8.1 👍
                      For the MAC-world (Apple-users) is there an equivalent ❓
                        driven
                        @pgarmyn said:
                        For the MAC-world (Apple-users) is there an equivalent :?:
                        I just posted it above?
                        The command ioreg located in /usr/sbin/ioreg is used to display the I/O Kit registry.
                        • P
                          pgarmyn
                          👍 👍 👍 @driven
                            driven
                            @pgarmyn said:
                            :thumb: :thumb: :thumb: @driven
                            Well, maybe not three thumbs... it's unclear to me if that's a standard or an xtool instal, so a safer bet would be
                            getMACADDRESS = %x(/usr/sbin/networksetup -getMACADDRESS en0 | /usr/bin/awk '{print $3}' | /usr/bin/sed s/;//g)
                            which returns
                            001ec*******
                            the mac MAC address using standard instal items...
                            • Dan RathbunD
                              Dan Rathbun
                              There IS a gem that can be used for reference (perhaps it can be made SketchUp friendly.)
                              macaddr/lib/macaddr.rb at master · ahoward/macaddr
                              cross platform mac address determination for ruby. Contribute to ahoward/macaddr development by creating an account on GitHub.
                              GitHub (github.com)
                              • G
                                Garry K
                                I'm back at this MAC address - specifically for first Ethernet device.
                                This code seems to work fine for Windows 7 - but will it work for OSX ??
                                Has anyone tried this in a French computer or some other language?
                                ` def get_mac_address()
                                return @mac_address if defined?( @mac_address )
                                @win = ( RUBY_PLATFORM =~ /darwin/i ) == nil
                                tmp = ""
                                str = ""
                                first = true
                                if ( @win )
                                # for windows put results in array - splitting on newline
                                # check begining of string for 'Ethernet' and set flag once found
                                # then check for 'Physical Address' and look at everything after the ':'
                                # set mac_address and return
                                ipa.each {|line|
                                  tmp = line.strip
                                  str = tmp[0..7]
                                  if ( first )
                                    first = false if ( "Ethernet" == str )
                                  elsif ( "Physical" == str )
                                    pos = tmp.rindex( ":" )
                                    @mac_address = tmp[pos+2, tmp.length ]
                                    return @mac_address
                                else
                                tmp = %x[ifconfig eth0].strip
                                pos = tmp.rindex( " " )
                                @mac_address = tmp[pos+1, tmp.length ]
                                return @mac_address
                                return ""
                                end`
                                • P
                                  pgarmyn
                                  @Garry
                                  As i said before, this only works for US or EN OS.
                                  The output of ipconfig depends on the OS language.
                                  In French you will have to scan for "adresse physique" and for the other languages....
                                  • G
                                    Garry K
                                    This works in Windows 7
                                    	return @@mac_address if defined?( @@mac_address )
                                    	if ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                                    		cmd = 'ipconfig /all'
                                    	else
                                    		cmd = 'ifconfig'
                                    	macs = []
                                    	lines = %x[#{cmd}].split("\n").grep( /^.*\s([0-9a-f|A-F]{2}[:-]){5}([0-9a-f|A-F]{2})$/ )
                                    	lines.each{|line| macs << line.strip[-17,17] }
                                    	@@mac_address = macs.first.gsub( '-', ':' )
                                    • G
                                      Garry K
                                      Thanks pgarmyn - I was just confirming the language thing
                                      I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
                                      I have cleaned this up so if it is benefit to others
                                      mac_addr = []
                                      cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
                                      # choose lines that have only six pairs of 2 char hex values separated by either a : or -
                                      # pattern must start with a space and be at the end of the line
                                      # there can be white space at the end of the line
                                      lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
                                      lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
                                      # if windows and we have more than 1 mac address use the second one otherwise use the first
                                      # if not windows then use the first address
                                      index = @@windows && mac_addr.length > 1 ? 1 : 0
                                      @@mac_address = mac_addr[index]
                                      end`
                                        driven
                                        @gary
                                        couple of changes needed to run on my mac,
                                        got rid of class variables
                                        added windows =
                                        added simplified regex = with .. for grep
                                        windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                                        return mac_address if defined?( mac_address )
                                        mac_addr = []
                                        cmd = windows ? 'ipconfig /all' ; 'ifconfig'
                                        # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                                        regex = Regexp.compile("(..[;-]){5}..")
                                        lines = %x[#{cmd}].split("\n").grep( regex )
                                        lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
                                        index = windows && mac_addr.length > 1 ? 1 ; 0
                                        return mac_address
                                        > get_mac_address 00:1e:c4:16:08:46
                                        • G
                                          Garry K
                                          Thank-you very much, I appreciate this, since I don't have access to a mac.
                                          I will test on Windows with your simplified regex.
                                          You show the mac_address as lower case - can you confirm that is indeed the output.
                                          Also - off topic - but how do you get the source code to go into the embedded window?
                                            driven
                                            yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
                                            the one with the red circle...
                                            • 1 / 3
