    Get MAC Address
    55 Posts 8 Posters 7.1k Views 8 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Garry.. this is safer and faster to use boolean Constants throughout your module(s) [ie, Strings are slow.]
      At the top of your module:
      MAC = OSX = RUBY_PLATFORM !~ /mswin|mingw/ PC = WIN = (not MAC)
      Then say down further:
      if WIN
        # do this
      else
        # it's a Mac, do that
      another example, showing a webdialog:
      WIN ? @dlg.show() : @dlg.show_modal()
      I'm not here much anymore.
        Dan Rathbun
        @garry k said:
        then for windows I can redirect the output of ipconfig
        null = test(?e, '/dev/null') ? '/dev/null' : 'NUL'
        Why? The %x or backquoted string method returns it's result.
        so:
        ip = %x[ipconfig /all]
        Then parse the string ip,.. iterate it using each_line or
        split("\n") it into an array of lines, then use find, etc.
          driven
          @dan
          does reply_from_ifconig.split("\n").grep("Physical Address") or similar work on a PC?
          EDIT for something as un-changing as ifconfig on a mac you could use
          (%x(ifconfig -a)).split("\n")[10].split[1]
            pgarmyn
            @dan rathbun said:
            similar:
            ipa = %x[ipconfig /all].split("\n").grep /\A\s*(Physical Address)/....
            Scanning for “Physical Address” only gives a result with an EN/US OS
            This works also on the old continent :
            def MyModule.mac_address
            	platform = RUBY_PLATFORM.downcase
            	iptxt = `#{(platform =~ /win32/) ? 'ipconfig /all' ; 'ifconfig'}`
            	## delete DHCPv6 ;
            	iptxt.gsub!(/..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-../,"")
            	# delete Tunnel ;
            	iptxt.gsub!("00-00-00-00-","")
            	## create array with all the physical adresses ;
            	t_array=iptxt.scan(/..\-..\-..\-..\-..\-../)
            	#puts t_array.inspect
            	## returns first physical adresses if one found
            	return t_array[0] if t_array.length>0
            	return nil
              driven
              There's also this one
              mac_MAC = %x(ioreg -rd1 -c IOPlatformExpertDevice |  awk "/IOPlatformUUID/ { print $3; }")
              returns
              "IOPlatformUUID" = "00000000-0000-1000-8000-00**********" [my address obscured with ***]
                pgarmyn
                @dan rathbun said:
                DUh... I just stumbled upon GetMAC.exe on my Win 7 machine....
                Yes, i have it also on Win8.1 👍
                For the MAC-world (Apple-users) is there an equivalent ❓
                  driven
                  @pgarmyn said:
                  For the MAC-world (Apple-users) is there an equivalent :?:
                  I just posted it above?
                  The command ioreg located in /usr/sbin/ioreg is used to display the I/O Kit registry.
                    pgarmyn
                    👍 👍 👍 @driven
                      driven
                      @pgarmyn said:
                      :thumb: :thumb: :thumb: @driven
                      Well, maybe not three thumbs... it's unclear to me if that's a standard or an xtool instal, so a safer bet would be
                      getMACADDRESS = %x(/usr/sbin/networksetup -getMACADDRESS en0 | /usr/bin/awk '{print $3}' | /usr/bin/sed s/;//g)
                      which returns
                      001ec*******
                      the mac MAC address using standard instal items...
                        Dan Rathbun
                        There IS a gem that can be used for reference (perhaps it can be made SketchUp friendly.)
                        macaddr/lib/macaddr.rb at master · ahoward/macaddr
                        cross platform mac address determination for ruby. Contribute to ahoward/macaddr development by creating an account on GitHub.
                        GitHub (github.com)
                          Garry K
                          I'm back at this MAC address - specifically for first Ethernet device.
                          This code seems to work fine for Windows 7 - but will it work for OSX ??
                          Has anyone tried this in a French computer or some other language?
                          ` def get_mac_address()
                          return @mac_address if defined?( @mac_address )
                          @win = ( RUBY_PLATFORM =~ /darwin/i ) == nil
                          tmp = ""
                          str = ""
                          first = true
                          if ( @win )
                          # for windows put results in array - splitting on newline
                          # check begining of string for 'Ethernet' and set flag once found
                          # then check for 'Physical Address' and look at everything after the ':'
                          # set mac_address and return
                          ipa.each {|line|
                            tmp = line.strip
                            str = tmp[0..7]
                            if ( first )
                              first = false if ( "Ethernet" == str )
                            elsif ( "Physical" == str )
                              pos = tmp.rindex( ":" )
                              @mac_address = tmp[pos+2, tmp.length ]
                              return @mac_address
                          else
                          tmp = %x[ifconfig eth0].strip
                          pos = tmp.rindex( " " )
                          @mac_address = tmp[pos+1, tmp.length ]
                          return @mac_address
                          return ""
                          end`
                            pgarmyn
                            @Garry
                            As i said before, this only works for US or EN OS.
                            The output of ipconfig depends on the OS language.
                            In French you will have to scan for "adresse physique" and for the other languages....
                              Garry K
                              This works in Windows 7
                              	return @@mac_address if defined?( @@mac_address )
                              	if ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                              		cmd = 'ipconfig /all'
                              	else
                              		cmd = 'ifconfig'
                              	macs = []
                              	lines = %x[#{cmd}].split("\n").grep( /^.*\s([0-9a-f|A-F]{2}[:-]){5}([0-9a-f|A-F]{2})$/ )
                              	lines.each{|line| macs << line.strip[-17,17] }
                              	@@mac_address = macs.first.gsub( '-', ':' )
                                Garry K
                                Thanks pgarmyn - I was just confirming the language thing
                                I did try running the code that you posted earlier - but it gave me an error so I decided this was a good opportunity to learn more.
                                I have cleaned this up so if it is benefit to others
                                mac_addr = []
                                cmd = @@windows ? 'ipconfig /all' : 'ifconfig'
                                # choose lines that have only six pairs of 2 char hex values separated by either a : or -
                                # pattern must start with a space and be at the end of the line
                                # there can be white space at the end of the line
                                lines = %x[#{cmd}].split("\n").grep( /\s([0-9A-F]{2}[-:]){5}([0-9A-F]{2})\s*$/ )
                                lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ':' ) }
                                # if windows and we have more than 1 mac address use the second one otherwise use the first
                                # if not windows then use the first address
                                index = @@windows && mac_addr.length > 1 ? 1 : 0
                                @@mac_address = mac_addr[index]
                                end`
                                  driven
                                  @gary
                                  couple of changes needed to run on my mac,
                                  got rid of class variables
                                  added windows =
                                  added simplified regex = with .. for grep
                                  windows  = ( ( RUBY_PLATFORM =~ /darwin/i ) == nil )
                                  return mac_address if defined?( mac_address )
                                  mac_addr = []
                                  cmd = windows ? 'ipconfig /all' ; 'ifconfig'
                                  # choose lines that have only six pairs of 2 char hex values separated by either a ; or -
                                  regex = Regexp.compile("(..[;-]){5}..")
                                  lines = %x[#{cmd}].split("\n").grep( regex )
                                  lines.each{|line| mac_addr << (line.strip[-17,17]).gsub( /-/, ';' ) }
                                  index = windows && mac_addr.length > 1 ? 1 ; 0
                                  return mac_address
                                  > get_mac_address 00:1e:c4:16:08:46
                                    Garry K
                                    Thank-you very much, I appreciate this, since I don't have access to a mac.
                                    I will test on Windows with your simplified regex.
                                    You show the mac_address as lower case - can you confirm that is indeed the output.
                                    Also - off topic - but how do you get the source code to go into the embedded window?
                                      driven
                                      yes it's lower-case, I realised that obscuring it in my other posts was counter productive, so I just adjusted only the number values to show the return this time...
                                      the one with the red circle...
                                        Garry K
                                        Thanks again. I checked the code for windows and it works fine.
                                        I've added an upcase on the following line
                                        lines.each{|line| mac_addr << (line.strip[-17,17]).upcase().gsub( /-/, ':' ) }
                                        • jaimedaJ Offline
                                          jaimeda
                                          Hello
                                          This works fine in Sketchup 2013 but not in 2014.
                                          Any tips?
                                          • tt_suT Offline
                                            tt_su
                                            Due to the upgrade of the Ruby core this broke. We haven't been able to figure out why. But the workaround is to pipe the result from the command to a temporary file and read it after executing the command.
                                            <span class="syntaxdefault"><br />tempfile&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"C;/Users/Thomas/Desktop/temp.txt"<br /></span><span class="syntaxkeyword">`</span><span class="syntaxstring">ipconfig&nbsp;/all&nbsp;>&nbsp;#{tempfile}</span><span class="syntaxkeyword">`<br /></span><span class="syntaxdefault">puts&nbsp;File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">read</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">tempfile</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
                                            • 1 / 3
