    [Plugin] Skelion (solar, shadows)
    102 Posts 45 Posters 288.3k Views 45 Watching
    • B
      bnwitt
      I have been using this plugin now for several months. It has changed the way I do PV system modeling. I now start every project in Sketchup with Skelion and then go to my cad program to finish the customer presentation. On some projects, I have created the entire presentation in Sketchup/Skelion.
      What I like best about working with Skelion, is the ability to set the start time and stop time on any date for the shading from row to row and having the row spacing automatically calculated by Skelion. I have redone several system layouts with Skelion and been able to get more modules on a site then my previous calcs allowed.
      I also love the speed at which I can complete a layout and then render it for a client in either jpeg or animation. This program has cut that time by leaps and bounds. For a ground mount where no building must be drawn I can create utility scale layouts in minutes. For projects where a structure must be created, the module layout is now the easiest part of the job. The simple rooftop layout shown in the attached file took 5 minutes and I know the row spacing is correct without doing the math. I've verified several layouts from skelion in other shading analysis programs and just by doing the math and the accuracy is excellent.
      Figuring out the Skelion interface didn't take too long with the help of Juan Pons(the creator of Skelion)since he is so quick to reply to emails. He even added some features I requested in one of my emails. Of course a detailed manual would be great and I'm sure once the number of users gets high enough to warrant a redo Juan will do that. If you are a PV designer Sketchup is an excellent tool for Shading analysis. With the Skelion plugin added it can't be beat. I love it. πŸ˜„
      Barry
      C3 Solar Design
      Simple rooftop PV layout
        AirWindSolar
        Maybe I'm missing something in setting up the component, but I've got a big project coming up that we might be using Zilla Cobra ( http://www.zillarac.com/Portals/0/Documents/PDF/systems/ZillaCobra_Specs_0512.pdf ) racking for. I built a component of a 280W panel attached to a single Cobra unit, and when I went to use it with Skelion, I couldn't figure out a way to get to it happily match up at the fixed spacing. (Cobra links together in columns, rather than rows.)
        • B
          bently
          I have been using your pro version for quite a while now, it is fantastic! I just wanted to thank you for an affordable time saver... I noticed on your new website it says the 3d model can be exported into PVSYST. Is there any instructions on that... That would be soooo helpful. PVsyst modeling is quite cumbersome!
          Thanks again,
          Bently
          • JuantxoJ
            Juantxo
            PVSYST exporter is not yest in manual but you can export pressing pvsyst icon: pvsyst_icon.JPG.
            Buildings does not project shadows over solar panels. They are working to fix that. But size and position of solar panels are right.
            • T
              The_Robbies
              My latest job:
              About 100 kWp
              http://solar.onlinedivision.eu/images/SKUP-MAXWELL-IMAGE-002.jpg
                solemassoud
                I have been using Skelion pro for a few months and it is a great tool. lately the 'sunny area' (Moon icon) calculation tool doesn't seem to work. I normally check for shaded surfaces before laying out the panels.
                could you please advise if there is a bug in the plug in or if there is detailed instructions on how to use the tool.
                Thanks,
                • K
                  kaiyer
                  PVWatts is changing. There is a new version http://pvwattsbeta.nrel.gov/
                  that will replace the v1 and v2 versions soon. How do I update to point to the new PVWatts. Is this something I can do myself? Can you update and release a new version?
                  • Y
                    yiannosh
                    I have just installed Skelion plugin V5.0.8 on my pc.
                    When i pick any button on Skelion toolbar, an empty window appeared on the screen, and I can't do anything.
                    Can anyone help me?
                    • JuantxoJ
                      Juantxo
                      No, you can not update yourself. You need to wait to for a new Skelion release.
                      You are talking of a beta PVWATTS. When it will be stable Skelion will change if it is necessary.
                        szumlanski
                        Something doesn't seem to behave the way I expect it to work. The Space between panels [S] works well, but the "Stack Space [K]" leaves no space between panels. Also, I do not understand the use or meaning for "Stack components."
                        Note the lack of vertical space between panels in the attached image. This occurs with embedded panel profiles and with custom loaded panels in landscape or portrait orientation. I can't figure out if I am doing something wrong, or if this is the intended result. I just downloaded the V5.08 version.
                        No vertical space between panels
                        • JuantxoJ
                          Juantxo
                          Don't use stack components when coplanar. Stack components is used to insert rows with more than one panel when they have some tilt over the roof or ground.
                            sunilc
                            Hello,
                            I have sketchup 2013 and skelion-make 5.09. I am not able to get any tilt on the laid out panels and hence they are not spaced apart for shadowing. Am I missing something?
                            Thanks,
                            Sunil
                            • JuantxoJ
                              Juantxo
                              Sorry, there was an error in version a 5.0.9.
                              It was fixed. Download 5.1.0 and install it.
                              • P
                                pagaling
                                Does not work now with Sketchup 2014. Is there an update other than 5.1.0? Danke.
                                • JuantxoJ
                                  Juantxo
                                  5.1.l works but in windows there is a problem. You need to open SketchUp files dragging them over SketchUp shortcut. And to open SketchUp you can not click the shortcut, you need to pin up SketchUp in main windows bar.
                                  It will be fixed soon.
                                  • P
                                    pagaling
                                    Hi. I still can't make it work in SU 2014. I put the plugin under C:\Users\MyName\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins but there is always an error when it loads. You said it works in Windows but that there is a small problem. Can you please let me know how to fix it? Thanks Juantxo!
                                    • P
                                      pagaling
                                      Hi Juantxo, I still can't make it work in SU 2014. I already installed manually by placing the files under Sketchup/Plugin founder under Appdata directory but it still gets error upon loading. I also tried installing via SU 2014 but the same thing happened.
                                      Hope you can help out a bit. Thanks
                                        RK26
                                        Cannot get it working in Sketchup 2014. Please help. I put the files into plugin folder but when i start the program, it runs a bunch of scripts and the a window with errors comes up.
                                        • P
                                          pagaling
                                          Now working on SU 2014!
                                          BIG TNX TO Juantxo
                                          β˜€
                                            AirWindSolar
                                            Same here, even on a relatively simple model (single triangular face of a pitched roof with a chimney) it gets to "step 1 of 6" and then bug splats.
                                            Also, would love to see it add something to specify an "acceptable" shade level, since sometimes on these systems we're using microinverters, and will tolerate an hour of shade on each panel, but obviously want to avoid panels that would be shaded 3-4 hours a day where possible. Maybe two separate indications of shadow to show unshaded all day, shaded within the tolerance, and shaded beyond the tolerance.
                                            EDIT TO ADD: Tried it again on one iteration, and it ran, but of course only gave the single shadow. Tries at 2 or 3 iterations crashed. "Join shadows" or not had no effect. Narrowing the time frame to 1000-1500 didn't help either. Changing to June 21 instead of December 21 did allow it to run a 2 iteration without joining shadows, but it failed again when I tried it with 0900-1600.
                                            Powell.skp
                                            • 3 / 6
