    Rbz error
    7 Posts 3 Posters 705 Views 3 Watching
    • Q
      QuadDam
      I am trying to install extentions, rbz files, but i get bugslat, I have attached the files. Not sure what I am doing wrong?
      File New
      File New
      ======== Starting GL ========
      CBaseGLView::OnInitialUpdate
      InitializeOpenGL
      GetActivePixelFormat
      Got PF= 0 from registry
      requestedpf.accel=1
      ARB functions NOT available.
      nPfds=60
      Pixel format 1 does not do a swap copy.
      Pixel format 4 does not do a swap copy.
      Pixel format 7 does not do a swap copy.
      Pixel format 10 does not do a swap copy.
      Pixel format 13 does not do a swap copy.
      Pixel format 16 does not do a swap copy.
      Pixel format 19 does not do a swap copy.
      Pixel format 22 does not do a swap copy.
      ChoosePixelFormat returning 3
      GLConfigUtils::GetActivePixelFormat ... returning 3
      Make a context ... pf=3
      Got context @43f32c0 error=0
      GL initialization succeeded
      Tool(SelectionTool)
      UseHWAccelerationFirstTime
      Got vendor (ATI Technologies Inc.) renderer(ATI Mobility Radeon HD 5470 )
      Returning 0
      UpdateView
      Create rv=1
      InitializeOpenGL
      requestedpf.accel=1
      ARB functions available.
      WGL_SWAP_COPY_ARB
      Got context @6a38ac0 error=0
      TerminateOpenGL
      HW_OK=1
      pNew=6a686a8
      Tool(SelectionTool)
      Tool(SelectionTool)
      ***** First UI thread = 4772
      requestedpf.accel=1
      WGL_SWAP_UNDEFINED_ARB
      Did not find PF from GetCompatibleGLDevCapsARB.
      nPfds=60
      requestedpf.accel=1
      WGL_SWAP_COPY_ARB
      requestedpf.accel=1
      WGL_SWAP_COPY_ARB
        It looks to me as if there's an issue with OpenGL. You might try updating the video drivers for a start.
        • Q
          QuadDam
          Thanks so much that was the problem! Another question I want to pull out the bottom of the connected arcs I have created to create a rolling bike track. I cant get the arcs to attach to the wall, I have the joint push pull interactive tool installed, is there a tool to attach an arc to the wall so it follows the curve so can push pull the bottom out?
            You could use Shape Bender to bend the curve to match the surface. Then use JPP to pull out the bottom part to the opposite side.
              Try Fredo's 'ToolsOnSurface', which lets you draw onto a surface that is not 'flat' - including Arcs...
              Then to PushPull that newly divided surface use his 'JointPushPull' tools - the native tool only works on flat faces...
              • Q
                QuadDam
                awesome, thanks so much for your help!
                • Q
                  QuadDam
                  The tools on surface with the push pull tool was great, I am noticing now that when i start to curve the rolls are not smooth and have irregularities in them. Is there a way to smooth out the surface or am I not connecting the arcs correctly? As well is there a way to connect all my arcs together so i don't have to pull sections of the wall out separetly?
