    LumenRT Training Needed - Willing to pay.....
    extensions
    35 Posts 5 Posters 4.6k Views 5 Watching
    • JAWSnAZJ
      JAWSnAZ
      OK. Cool.
      Next question is about the glass bulb. Is there a way to make the glass bulb itself glow like it is frosted or translucent vs transparent?
      https://lh4.googleusercontent.com/-cWz1-HW8Ve8/UrS2P_sQ31I/AAAAAAAAA6E/XMprJ5_mGSI/s1280/Back%2520Yard%252005_001.jpg
      Windows 7 Pro 64
      i7-3770 3.4Ghz 32GB RAM
      GeForce GTX 650 Ti
      3dconnexion SpaceNavigator 3D Mouse
      Dual 27" Monitors
      My Site
      • soloS
        You can make the bulb a luminous material and not use the point lights, but then you do not have intensity control in live cube
        • JAWSnAZJ
          JAWSnAZ
          OK. So here is a test of Luminous Materials vs Point Light in LumenRT.
          Luminous Materials - Luminous 1000
          https://lh5.googleusercontent.com/-55_nui7KKKc/UrXxdMh3PuI/AAAAAAAAA6o/XqycM3ZPbMo/s1440/lighting%2520test%2520-%2520Luminous%2520Materials.jpg
          https://lh4.googleusercontent.com/-L0I9UvA89IA/UrXylFTe5lI/AAAAAAAAA7M/HRexmidAOIw/s1280/Luminous%2520Materials.jpg
          Point Light - Incandescent - 2500 lumens
          https://lh5.googleusercontent.com/-5Ypb6sM2fiY/UrXxdEKTssI/AAAAAAAAA6s/r0EWyr8hrmg/s1440/lighting%2520test%2520-%2520Point%2520Light.jpg
          https://lh3.googleusercontent.com/-w673BqMJ6ko/UrXylED58SI/AAAAAAAAA7I/6nOYzcuIQPo/s1280/Point%2520Light.jpg
          Point Light - Incandescent - 10,000 lumens
          https://lh4.googleusercontent.com/-2KACDICtlkU/UrX2Rj_I2iI/AAAAAAAAA7o/7UiWqKKobRA/s1280/Point%2520Light%2520-%2520Incandescent%2520-%252010%252C000%2520Lumens.jpg
          I have tried to place the point light inside of and also overlap the luminous material to get the luminous material to cast a shadow. No luck either way.
          Windows 7 Pro 64
          GeForce GTX 650 Ti
          Dual 27" Monitors
          My Site
            d12dozr
            What if you put the point light inside the luminous material, so you get shadows and the frosted light bulb effect?
            http://goo.gl/f7ooYh
            • olisheaO
              olishea
              This is a great thread and very generous of Solo to help out. Amazing forum work.
              oli
              • JAWSnAZJ
                JAWSnAZ
                Thanks d12dozr
                I have also tried that. When I scale the point light down small enough and insert it into the luminous material the luminous material blocks the point light from escaping and does not create shadows.
                It seems like the point light treats the luminous material as a solid object.
                Windows 7 Pro 64
                GeForce GTX 650 Ti
                Dual 27" Monitors
                My Site
                • JAWSnAZJ
                  JAWSnAZ
                  I agree olishea.
                  I am very grateful to solo for the help. I also upgraded my membership from free to premium as a way to show thanks to SketcUcation and support these forums.
                  Windows 7 Pro 64
                  GeForce GTX 650 Ti
                  Dual 27" Monitors
                  My Site
                    d12dozr
                    Ok, what if you paint the inside of the luminous material with a transparent material? I don't have LumenRT 4, or I'd try it myself...
                    • JAWSnAZJ
                      JAWSnAZ
                      OK. I tried to paint the inside of the sphere with the luminous material with no change to getting the shadows but that idea worked somewhat. We are getting closer.
                      Here is the sphere with a point light in it.
                      The outside and the inside of the sphere are painted with LumenRT Materials - Translucent / Frosted Grainy Glass with the LumenRT - Point Light / Incandescent / 10,000 lumens scaled down and inserted into the sphere.
                      https://lh5.googleusercontent.com/-ZI237Tvnbes/UrmJJH4GpmI/AAAAAAAAA9I/zpRtuBjNP9Q/w1598-h825-no/lighting+test+-+03.jpg
                      https://lh4.googleusercontent.com/-Mi1a94QZI40/UrmFLRqecOI/AAAAAAAAA8w/jMdWf9fJ7qY/w1280-h720-no/lighting+test+-+03.jpg
                      Windows 7 Pro 64
                      GeForce GTX 650 Ti
                      Dual 27" Monitors
                      My Site
                      • JAWSnAZJ
                        JAWSnAZ
                        OK. So here is my latest go at it.
                        I painted the light bulbs with Luminous material and created a point light just below the light bulb. I get the glow of the luminous material and I get the light pattern I am looking for.
                        What do you guys think?
                        https://lh5.googleusercontent.com/-QyQtTiW14iU/UrnX_0W3LhI/AAAAAAAAA9k/8QOISVRMIV8/w1598-h825-no/Back+Yard+05+-+LumenRT+Test+02.jpg
                        https://lh3.googleusercontent.com/-GZExOjqu5Q4/UrnYJuBxKJI/AAAAAAAAA9s/gErXCTtJB-E/w1598-h899-no/Back+Yard+05+-+LumenRT+Test.jpg
                        Windows 7 Pro 64
                        GeForce GTX 650 Ti
                        Dual 27" Monitors
                        My Site
                        • soloS
                          πŸ‘
                          That works.
                          The question I have is are you having fun?
                          If yes, then you are doing it right.
                          So what else can I help with, I am around but distracted due to the silly season, so ask away and I'll jump in as I can.
                          • JAWSnAZJ
                            JAWSnAZ
                            @solo said:
                            :thumb:
                            That works.
                            Answer is yes. I am loving it! It is much easier to learn with your help. At least you can point me in the right direction so I am not floundering around aimlessly. Thank you!
                            Next would be general ambient light. Is there a setting to bring up the general brightness so that it isn't pitch black in the areas that are not being illuminated by light sources?
                            Windows 7 Pro 64
                            GeForce GTX 650 Ti
                            Dual 27" Monitors
                            My Site
                            • soloS
                              Do you have a scene in particular? interior or exterior?
                              • JAWSnAZJ
                                JAWSnAZ
                                I am still playing around with the lighting but here is a couple of pictures.
                                https://lh4.googleusercontent.com/-TPJjmPu8jmQ/UroHkkyoDRI/AAAAAAAAA-g/TPTV5O6S230/w1280-h720-no/Back+Yard+05+-+LumenRT+Test_004.jpg
                                https://lh6.googleusercontent.com/-9hn639nPouY/UroFPwSVPXI/AAAAAAAAA-I/PnILGiMDt6A/w956-h538-no/Back+Yard+05+-+LumenRT+Test_003.jpg
                                https://lh5.googleusercontent.com/-x8pS93uptAg/UroFPzFoZeI/AAAAAAAAA-M/1dLda2KwiXk/w956-h538-no/Back+Yard+05+-+LumenRT+Test_002.jpg
                                Windows 7 Pro 64
                                GeForce GTX 650 Ti
                                Dual 27" Monitors
                                My Site
                                • soloS
                                  One suggestion would be to use a night time HDR image.
                                  Looking good so far.
                                    d12dozr
                                    Nice solution. Fire looks great too!
                                    • JAWSnAZJ
                                      JAWSnAZ
                                      OK solo. So when you get back from enjoying the "silly season" as you call it lol, maybe you can walk us through using a HDR image.
                                      I am self-taught and have zero computer art schooling so HDR is a new term for me. I looked it up. Thanks for the point in the right direction again.
                                      This is very interesting.
                                      High-dynamic-range rendering (HDRR or HDR rendering), also known as high-dynamic-range lighting, is the rendering of computer graphics scenes by using lighting calculations done in a larger dynamic range. This allows preservation of details that may be lost due to limiting contrast ratios. Video games and computer-generated movies and special effects benefit from this as it creates more realistic scenes than with the more simplistic lighting models used.
                                      http://en.wikipedia.org/wiki/High_dynamic_range_rendering
                                      Windows 7 Pro 64
                                      GeForce GTX 650 Ti
                                      Dual 27" Monitors
                                      My Site
                                      • JAWSnAZJ
                                        JAWSnAZ
                                        Thank you. πŸ˜„
                                        I am starting to understand the concept behind this software and that is helping me anticipate what it will do.
                                        Windows 7 Pro 64
                                        GeForce GTX 650 Ti
                                        Dual 27" Monitors
                                        My Site
                                          sonder
                                          Nice work guys! I love this software. So fast with amazing results. I do all my rendering with it now.
                                          One quick suggestion- add some lights under water in the sidewall of the pool. LumenRT works some magic with water.
                                          • JAWSnAZJ
                                            JAWSnAZ
                                            I have been trying every thing I can think of to get my pool to light up. I have lights in the pool in my render that I posted in this thread earlier but the water looks black. If you look, you will see that the lounge chair sitting in the water is illuminated from under the water. I have placed point lights in multiple locations inside the pool, I have also place directional lights with not much luck. I have sent this backyard model to the guys at LumenRT and with no real response. I have tried creating the water with a flat surface and as a solid block. I have used the LumenRT "pool water" and the standard SU "pool water." I'm sure I am missing something simple along the way.
                                            Do you have any ideas? ❓
                                            Windows 7 Pro 64
                                            GeForce GTX 650 Ti
                                            Dual 27" Monitors
                                            My Site
                                            • 2 / 2
