    LumenRT Training Needed - Willing to pay.....
    extensions
    35 Posts 5 Posters 4.0k Views 5 Watching
    • soloS Offline
      Got them, so how can I help?
      • soloS Offline
        Jay
        Lets do the yard first.
        Here is an image for those following of how the model looks.
        For this exercise we are not going into modeling or texturing discussions. however I did remove most vegetation as I'd rather use the LumenRT supplied trees as they are way better and optimized.
        In your email you wanted to know how to add lights, I saw you had string lights and a ton of them on the arbors, I deleted a bunch of them as there were just too many and inserted a point light inside see image. These are found on the LumenRT toolbar.
        I also added 3 point lights in pool
        Then I did a draft export to Lumion, set to night and done, some screen shots.
        And here is the Live cube to play with
        https://www.dropbox.com/s/5yot7t7pdz7lqur/Back%20Yard%2005.exe
        Dropbox link will be removed in 48 hours.
        • soloS Offline
          Using SU scale tool.
          • JAWSnAZJ Offline
            JAWSnAZ
            OK. So added a point light as you said but my point light is much much larger than the one you show. How do I change the size so I can see where I am placing it?
            https://lh3.googleusercontent.com/-dI3U70aCPVk/UrSoDKimI0I/AAAAAAAAA5o/KFGlQL2pk9g/s1280/Back%2520Yard%252005%2520-%2520Point%2520Light.jpg
            Windows 7 Pro 64
            i7-3770 3.4Ghz 32GB RAM
            GeForce GTX 650 Ti
            3dconnexion SpaceNavigator 3D Mouse
            Dual 27" Monitors
            My Site
            • JAWSnAZJ Offline
              JAWSnAZ
              lol... that is the missing link in my head... treat the LumenRT components as any other component. Scale, Copy, etc...
              Windows 7 Pro 64
              GeForce GTX 650 Ti
              Dual 27" Monitors
              My Site
              • soloS Offline
                When you export to live cube you press TAB and it will open up a menu on the left side where you can go into the lights menu and adjust the lights one by one, if you have a ton of lights it becomes a pain in the arse, there is no way to group adjust them.
                • soloS Offline
                  Also notice how I reduced the amount of lights, less is best here, trust me.
                  • JAWSnAZJ Offline
                    JAWSnAZ
                    OK. Cool.
                    Next question is about the glass bulb. Is there a way to make the glass bulb itself glow like it is frosted or translucent vs transparent?
                    https://lh4.googleusercontent.com/-cWz1-HW8Ve8/UrS2P_sQ31I/AAAAAAAAA6E/XMprJ5_mGSI/s1280/Back%2520Yard%252005_001.jpg
                    Windows 7 Pro 64
                    GeForce GTX 650 Ti
                    Dual 27" Monitors
                    My Site
                    • soloS Offline
                      You can make the bulb a luminous material and not use the point lights, but then you do not have intensity control in live cube
                      • JAWSnAZJ Offline
                        JAWSnAZ
                        OK. So here is a test of Luminous Materials vs Point Light in LumenRT.
                        Luminous Materials - Luminous 1000
                        https://lh5.googleusercontent.com/-55_nui7KKKc/UrXxdMh3PuI/AAAAAAAAA6o/XqycM3ZPbMo/s1440/lighting%2520test%2520-%2520Luminous%2520Materials.jpg
                        https://lh4.googleusercontent.com/-L0I9UvA89IA/UrXylFTe5lI/AAAAAAAAA7M/HRexmidAOIw/s1280/Luminous%2520Materials.jpg
                        Point Light - Incandescent - 2500 lumens
                        https://lh5.googleusercontent.com/-5Ypb6sM2fiY/UrXxdEKTssI/AAAAAAAAA6s/r0EWyr8hrmg/s1440/lighting%2520test%2520-%2520Point%2520Light.jpg
                        https://lh3.googleusercontent.com/-w673BqMJ6ko/UrXylED58SI/AAAAAAAAA7I/6nOYzcuIQPo/s1280/Point%2520Light.jpg
                        Point Light - Incandescent - 10,000 lumens
                        https://lh4.googleusercontent.com/-2KACDICtlkU/UrX2Rj_I2iI/AAAAAAAAA7o/7UiWqKKobRA/s1280/Point%2520Light%2520-%2520Incandescent%2520-%252010%252C000%2520Lumens.jpg
                        I have tried to place the point light inside of and also overlap the luminous material to get the luminous material to cast a shadow. No luck either way.
                        Windows 7 Pro 64
                        GeForce GTX 650 Ti
                        Dual 27" Monitors
                        My Site
                          d12dozr
                          What if you put the point light inside the luminous material, so you get shadows and the frosted light bulb effect?
                          http://goo.gl/f7ooYh
                          • olisheaO Offline
                            olishea
                            This is a great thread and very generous of Solo to help out. Amazing forum work.
                            oli
                            • JAWSnAZJ Offline
                              JAWSnAZ
                              Thanks d12dozr
                              I have also tried that. When I scale the point light down small enough and insert it into the luminous material the luminous material blocks the point light from escaping and does not create shadows.
                              It seems like the point light treats the luminous material as a solid object.
                              Windows 7 Pro 64
                              GeForce GTX 650 Ti
                              Dual 27" Monitors
                              My Site
                              • JAWSnAZJ Offline
                                JAWSnAZ
                                I agree olishea.
                                I am very grateful to solo for the help. I also upgraded my membership from free to premium as a way to show thanks to SketcUcation and support these forums.
                                Windows 7 Pro 64
                                GeForce GTX 650 Ti
                                Dual 27" Monitors
                                My Site
                                  d12dozr
                                  Ok, what if you paint the inside of the luminous material with a transparent material? I don't have LumenRT 4, or I'd try it myself...
                                  • JAWSnAZJ Offline
                                    JAWSnAZ
                                    OK. I tried to paint the inside of the sphere with the luminous material with no change to getting the shadows but that idea worked somewhat. We are getting closer.
                                    Here is the sphere with a point light in it.
                                    The outside and the inside of the sphere are painted with LumenRT Materials - Translucent / Frosted Grainy Glass with the LumenRT - Point Light / Incandescent / 10,000 lumens scaled down and inserted into the sphere.
                                    https://lh5.googleusercontent.com/-ZI237Tvnbes/UrmJJH4GpmI/AAAAAAAAA9I/zpRtuBjNP9Q/w1598-h825-no/lighting+test+-+03.jpg
                                    https://lh4.googleusercontent.com/-Mi1a94QZI40/UrmFLRqecOI/AAAAAAAAA8w/jMdWf9fJ7qY/w1280-h720-no/lighting+test+-+03.jpg
                                    Windows 7 Pro 64
                                    GeForce GTX 650 Ti
                                    Dual 27" Monitors
                                    My Site
                                    • JAWSnAZJ Offline
                                      JAWSnAZ
                                      OK. So here is my latest go at it.
                                      I painted the light bulbs with Luminous material and created a point light just below the light bulb. I get the glow of the luminous material and I get the light pattern I am looking for.
                                      What do you guys think?
                                      https://lh5.googleusercontent.com/-QyQtTiW14iU/UrnX_0W3LhI/AAAAAAAAA9k/8QOISVRMIV8/w1598-h825-no/Back+Yard+05+-+LumenRT+Test+02.jpg
                                      https://lh3.googleusercontent.com/-GZExOjqu5Q4/UrnYJuBxKJI/AAAAAAAAA9s/gErXCTtJB-E/w1598-h899-no/Back+Yard+05+-+LumenRT+Test.jpg
                                      Windows 7 Pro 64
                                      GeForce GTX 650 Ti
                                      Dual 27" Monitors
                                      My Site
                                      • soloS Offline
                                        That works.
                                        The question I have is are you having fun?
                                        If yes, then you are doing it right.
                                        So what else can I help with, I am around but distracted due to the silly season, so ask away and I'll jump in as I can.
                                        • JAWSnAZJ Offline
                                          JAWSnAZ
                                          @solo said:
                                          :thumb:
                                          That works.
                                          Answer is yes. I am loving it! It is much easier to learn with your help. At least you can point me in the right direction so I am not floundering around aimlessly. Thank you!
                                          Next would be general ambient light. Is there a setting to bring up the general brightness so that it isn't pitch black in the areas that are not being illuminated by light sources?
                                          Windows 7 Pro 64
                                          GeForce GTX 650 Ti
                                          Dual 27" Monitors
                                          My Site
                                          • soloS Offline
                                            Do you have a scene in particular? interior or exterior?
