    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
      I get it on PC & MAC v2013...
      Unless I re-jig you code to use the nonexistent foobar.rb and NOT register the extension anyway...
      Then it's all OK.
      • tt_suT
        tt_su
        Does it happen with a clean Plugins folder?
          Error Loading File C:/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb
          uninitialized constant TT::SystemError Loading File TT_Lib2.rb
          With nothing except "TT_Lib2" loading from Plugins [and only the 3 'required' rb's in Tools - sketchup. langhandler and extensions] - error happens in both basic v8 [PC] & v2013 [PC & MAC]...
          But oddly 'another version' doesn't display the issue at all ? 😉
          Incidentally, this one simple change to your script stops these error message...
          **#**Sketchup.register_extension( ex, true )
          There is no need to register the mock-Extension as it is doing nothing, and other tools will load what they need from it anyway... 😕
          • tt_suT
            tt_su
            Thanks for the reports TIG. I'll dig into it. I need to make some emergency patches for that other version anyway as well.
              One odd thing I noticed is a circular 'require' in two of your rb's ?
              In core.rb [which 'loads' first from the extension code load]...
              require 'TT_Lib2/system.rb'
              In system.rb which has been called by core.rb...
              require 'TT_Lib2/core.rb'
              So maybe the TT::System isn't initiated properly and the error occurs [with Ruby 1.8] ?
              The require of the core.rb should skip if the code is already loaded, BUT maybe the extension load doesn't register in the list in the same way, and a second attempt occur with an error message...
              • tt_suT
                tt_su
                Maybe... I thought Ruby was able to deal with circular require, but I've had cases where it seem to cause problems. This might be one of them - I introduced the system.rb require to core.rb recently.
                  There isn't a circular require as such...
                  If the core.rb is loaded/required, then it in turn requires the system.rb...
                  That in turn requires the core.rb BUT it is skipped because the core.rb has already been loaded.
                  BUT your TT_Lib2.rb code doesn't actually 'load or require' the core.rb - but rather it specifies it in an Extension.new(), and then it runs register_extension() that extension [which is where it breaks it]...
                  I suspect that [in versions up to v2013 at least] the extension's rb register_extension() does NOT get listed in the 'loaded' list [I forget its proper name!], although it does 'load' the code in some way, so... then core.rb's code requires system.rb which requires core.rb in the normal way, but at that point it tries to load core.rb thinking it's for the first time when it's the second !
                  So core.rb now skips system.rb's require because it thinks it's been done ???
                  Whatever is happening... just stopping the extension code without doing a register_extension() avoids this issue because it doesn't need loading at all any way...
                  • tt_suT
                    tt_su
                    @tig said:
                    On PC and MAC I now get this issue whenever SketchUp starts
                    Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/TT_Lib2/core.rb
                    One step forward one back.
                    I tried with a fresh install of TT_Lib2 on SU8 and SU2013 - under SU8 I never saw the error. Under SU2013 I saw the error when I had the console open when I installed. However, when I restarted SU there was no errors and everything was working fine... :s
                      To double check... I removed all of your tools and the TT_Lib2 files from my v2013 Plugins folder.
                      I then reinstalled the latest TT_Lib2 version - v2.9.5 [?].
                      After that, whenever I restarted SketchUp it gives the same error-message as previously reported.
                      As before adding a # in front of the line that registers your spurious extension [and thereby tries to load the core.rb] stops the error as SketchUp starts, but it does not affect the Lib at all, since other tt installed tools 'properly' load any code as needed from the Lib, which does NOT need to be an extension at all...
                      • tt_suT
                        tt_su
                        What Windows version are you using?
                        (I want to get to the actual cause of this, fixing the actual problem instead of patching the symptom - which is why I need to reproduce this.)
                        • tt_suT
                          tt_su
                          Ah! Now I reproduce it. If TT_Lib is loading all by itself.
                          I had AutoSmooth installed which loaded the core.rb file - then there was no errors.
                            Pushed a new version 2.9.6 to BitBucket and the PluginStore. Should take care of the Load Errors and compatibility with PluginStore - for realz this time!
                            • C
                              cchere
                              Thank you for the new version file (v2.9.7),it works well at last.No more "core.rb" problem when SU start up(with v2.9.5).
                              • B
                                billiam
                                having trouble installing this, when opening sketchup an error appears that says some of my files are in the windows virtual store. I am the only user on this laptop and have full permissions. I have also been searching for the compatibility button (researched on another thread) and I have been unable to find it/
                                I did not install this as a .rbz but switched the file name to .zip, then copied TT-lib folder and TT-lib.rb into the plugins folder. Am I missing something
                                please help
                                  You need FULL administrative privileges for the Plugins folder. Edit those privileges and you'll be able to either move the files from the Virtual Store or reinstall.
                                  You should just install the .RBZ file instead of converting to ZIP. You should also download and install the Sketchucation Plugin Store.
                                  • tt_suT
                                    tt_su
                                    After that message there should be an Explorer window opening, which is contains the Virtual Store files. Note the full file path in the address bar. Those files should be in the real Plugins folder.
                                      SKPudden
                                      Sorry - new core.rb problem here:
                                      Having 'inherited' some large, complex and badly-built SU models, I need a way to clean them up without resorting to a dozen partial solutions. I've been trying to get TT_cleanup to work, but I'm getting the following error when Sketchup starts:
                                      Error Loading File /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/core.rb
                                      can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb
                                      can't convert nil into StringError Loading File /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb
                                      can't convert nil into StringError Loading File tt_cleanup.rb
                                      I should maybe mention that my Mac is a PPC G4 (there's a lot of us left!) and I'm using the most recent versions of the plugin and library. I'm beginning to wonder if the hardware may be the problem. It is rather old (without being in any sense rickety). This said, I haven't experienced problems with any other plugins (yet).
                                      But I'm sure someone will know better than me...
                                      • tt_suT
                                        tt_su
                                        hm.. missing a stacktrace there.
                                        Can you try these commands in the Ruby Console:
                                        load 'tt_cleanup.rb'
                                        load 'tt_cleanup/core.rb'
                                        See if you get a more detailed error message?
                                        Also, what version of TT_Lib and CleanUp do you have installed?
                                          SKPudden
                                          Hi TT
                                          Thanks for the fast response.
                                          Here's what the Console gives me:
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:20: warning: already initialized constant PLUGIN_ID
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:21: warning: already initialized constant PLUGIN_NAME
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:22: warning: already initialized constant PLUGIN_VERSION
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:25: warning: already initialized constant FILENAMESPACE
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:26: warning: already initialized constant PATH_ROOT
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:27: warning: already initialized constant PATH
                                          true
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
                                          Error: #<TypeError: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:22:in expand_path': can't convert nil into String> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:11 /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:22 /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/core.rb:10:in require'
                                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:10:in require' /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:10 (eval):155:in load'
                                          (eval):155
                                          The versions installed are:
                                          Cleanup 3.2.0
                                          TT Lib 2.9.8
                                            Oh, I forgot to come back to this issue. Is it still an issue or have you found a way to resolve it?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
