    Remove uv mapping coordinates from geometry
    8 Posts 4 Posters 3.2k Views 4 Watching
    • andybotA Offline
      andybot
      So I'm not sure if I have been searching in the right place, but so far I am coming up empty handed. What I am looking for is a way to remove UVW coordinates from a piece of geometry. I thought Thrupaint or UVtools would have a way to do it, but I haven't found that hidden command yet... The issue is that this mesh I am working with has many small faces, all uv mapped, and I am trying to reduce the file size. With so much UVW info, the file size (28mb) is much larger than the geometry would warrant.
      Andy
      • N Offline
        numerobis
        Did you try the material tools?
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=17587
        I think i have a simple "remove all materials" plugin, but i can't find it here with the search. Maybe it has been replaced by the material tools.
        Overwriting doesn't work? Even if you sample a material from another object.
        But i don't think that only UVs can give you such a big file. Is it possible that the textures are still stored within the .skp?
        • massimoM Offline
          massimo Moderator
          File Not Found
          (www.smustard.com)
            Did you try deleting the mapping in Blender and exporting?
            • andybotA Offline
              andybot
              Yes, that works. Though for me, SU is part of my Blender workflow, but Blender is not normally part of my SU workflow... it's usually a one way ticket away from SU πŸ˜†
              @massimo said:
              File Not Found
              (www.smustard.com)
              Thanks, I tried it, but it seems the UV data is still in the file, no change to the filesize whatsoever. I'll see if I can get a good sample file to show what's going on.
              Andy
              • andybotA Offline
                andybot
                Here's a piece of my troublesome wall. There are 2 files in here, one without texture mapping, the second with a texture done with just a plain projected texture. Is there a way to get the 2nd skp back to the same file size as the 1st?
                Group_14_take4_SDS2_tex1.zip
                • N Offline
                  numerobis
                  • remove materials
                  • delete texture from material
                  • purge all
                  • assign material without texture to remove the projection UVs
                  =829KB
                  Group_14_take4_SDS2_tex1_02.zip
                  • andybotA Offline
                    andybot
                    Cheers! 😍
                    assign material without texture using Thrupaint did the trick. (didn't seem to work just assigning with regular SU paint bucket.)
