    [Plugin] Slicer5
    338 Posts 83 Posters 419.2k Views 82 Watching
      mstsrs
      Thank you sir
        i conclude again that SU is a tool far, far away from being perfect.
        For "perfect result" try maybe Nurbs like the crazzy Moi! πŸ˜‰
          Here's a future-proofed update.
          http://sketchucation.com/forums/viewtopic.php?p=374969#p374969
          • C
            Cubcrafter
            Updated Slicer today thru Plugin store and got this error message.
            No problem updating other TIG plugins.
            Larry
              Investigating...
              πŸ˜•
                The latest update [v5.18] should resolve the issue πŸ˜•
                Works fine for me...
                There was a typo or two [now fixed], but I can't see how you got that error ??
                Try removing the .rb and subfolder... and reinstall from scratch...
                Report back if it then does not work for you...
                • C
                  Cubcrafter
                  Removed folder and .rb file from Plugins Folder and reinstalled from Plugin Store.
                  Loads fine now.
                  Thanks,
                  Larry
                    rod bender
                    I am running( on a Mac) the latest version of Trimble SketchUp Pro, and have just installed the latest version of Slicer 5.19
                    I am having difficulties exporting flattened slices to DXF format. Have done this before with previous versions of Slicer but don't seem to be having any luck with this updated version. Does anyone out there have any suggestions?
                      What's the trouble? Be more specific. Do you get the flattened slices in the SketchUp model space after the plugin runs? Is it just the export to DXF that is causing the problem? Can you export other lines to DXF?
                        rod bender
                        I get the flattened slices ok, select one group to Export. Choose export from Slicer and get the dialog box asking
                        For which format, select, then nothing happens
                          I just tried it on SU2013 with OSX10.8.5 and it worked just fine. What OS are you using? (Please complete your profile). In what location is the SKP file saved?
                            rod bender
                            I am running OS 10.7.5 and the SKP is in Applications folder.
                              You saved the model in the Applications folder? Try saving it in the Documents folder instead and see what happens.
                                rod bender
                                Apologies, I saved the SKP on the desktop, but now have moved to the Document Folder. Alas no better luck with that. But thanks for your assistance.
                                  OK. So, are you still working on this tonight?
                                    A new version is now available.
                                    This should resolve some recently reported issues...
                                    http://sketchucation.com/resources/pluginstore?pln=TIG_Slicer
                                      DXF exporting...
                                      Please get the latest version of the Toolset and retry...
                                      Please remember that you need to preset the DXF export options in SketchUp as these are not scriptable and the current settings are used...
                                      If you export with the Ruby Console open does it show errors ?
                                        rod bender
                                        That all seems to be working well. No error messages with the Ruby Console.
                                        Excellent
                                          So it's working now, Rod? I was going to suggest we try a DXF export last night through File>Export but I got sidetracked. If it works, now, that's excellent.
                                            rod bender
                                            Dave, thanks for your help. Everything seems to be working just fine now.
                                            Cheers
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
