    [Plugin] Slicer5
    338 Posts 83 Posters 408.0k Views 82 Watching
      rod bender
      I get the flattened slices ok, select one group to Export. Choose export from Slicer and get the dialog box asking
      For which format, select, then nothing happens
        I just tried it on SU2013 with OSX10.8.5 and it worked just fine. What OS are you using? (Please complete your profile). In what location is the SKP file saved?
          rod bender
          I am running OS 10.7.5 and the SKP is in Applications folder.
            You saved the model in the Applications folder? Try saving it in the Documents folder instead and see what happens.
              rod bender
              Apologies, I saved the SKP on the desktop, but now have moved to the Document Folder. Alas no better luck with that. But thanks for your assistance.
                OK. So, are you still working on this tonight?
                  A new version is now available.
                  This should resolve some recently reported issues...
                  http://sketchucation.com/resources/pluginstore?pln=TIG_Slicer
                    DXF exporting...
                    Please get the latest version of the Toolset and retry...
                    Please remember that you need to preset the DXF export options in SketchUp as these are not scriptable and the current settings are used...
                    If you export with the Ruby Console open does it show errors ?
                      rod bender
                      That all seems to be working well. No error messages with the Ruby Console.
                      Excellent
                        So it's working now, Rod? I was going to suggest we try a DXF export last night through File>Export but I got sidetracked. If it works, now, that's excellent.
                          rod bender
                          Dave, thanks for your help. Everything seems to be working just fine now.
                          Cheers
                            There's a new version available - v5.22...
                            See its 'Documentation' tab - the main change is an additional option added to the dialogs - 'Centralization' - the default is 'Slice' - as before, the fixed-spacing slices are set-off from the object's center - giving an 'odd' number of slices [3, 5, 7 etc]: the new alternative is 'Gap', this shunts the initial slicing, so that then the gap between the slices is centered - giving an 'even' number of slices [4, 6, 8 etc]. It keeps the fixed-spacing entered.
                            This new option could be used instead of entering Spacing = 0 - which would have then called an additional dialog to get a fixed number of 'Spaces' [ignoring 'centralization'], and then rather than using a fixed-spacing it would have generated an adjusted-spacing to suit the number of 'spaces' specified [i.e. the 'gaps'] - thus allowing odd & even slice counts].
                            The two methods should provide flexibility of slicing formats to cover most of your needs...
                            http://sketchucation.com/plugin/781-tig_slicer
                              jkasten
                              Hello! I just installed Slicer v5.22 and I get the following error:
                              Error; #<TypeError; reference to deleted DrawingElement>
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;1829;in `bounds'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;1829;in `block in ref'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;1813;in `each'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;1813;in `ref'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;1115;in `run'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;279;in `initialize'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;134;in `new'
                              /Users/jkasten/Library/Application Support/SketchUp 2014/SketchUp/Plugins/TIG-Slicer/TIG-Slicer.rb;134;in `block in <module;TIG>'
                              I have tried running the plugin on various simple solid components or groups, and it fails every time.
                              Any suggestions?
                                You are on MAC. πŸ˜’
                                If you have NOT downloaded and installed the ttf Font 'txt' then your MAC crash will out...
                                Whereas a PC will use a fall-back font...
                                Please get that Font from the link on the Plugin's Documentation, or its thread's first page.
                                UnZIP it and make sure it is installed in your Fonts...
                                Please read the Plugin's notes before trying to use it... πŸ˜‰
                                I might add a trap for it in an update, along the lines of: "MAC users MUST have txt.ttf installed !"
                                  jkasten
                                  Thanks TIG
                                  I had actually downloaded the font, but it turns out that it was incorrectly installed.
                                  Everything seems to work correctly now.
                                  Cheers!
                                    Here's v5.23 http://sketchucation.com/pluginstore?pln=TIG_Slicer in the PluginStore...
                                    If a MAC user has not downloaded and installed the txt.ttf Font... then instead of a crash, the Slices are now completed but without Refs and there is an error-dialog telling the User that the Font is probably not installed etc and how to get its ZIP archive from the Plugin's thread first-page or the link in the Documents page...
                                    PC users also need this Font but if it missing Windows substitutes an alternative, so a crash is avoided...
                                    There is also a behind the scenes tweak to try and overcome a rare v2013 OpenGl, fast-feedback graphics-card glitch - where on a first run of Slicer as the processing completes the slices' faces are not displayed [but they are properly made - SketchUp just does not display them], but they will appear if the SKP is reopened or the slice edited...
                                    If this occurs it may be due to have OpenGL fast-feedback set 'on' in v2014 πŸ˜•
                                      rv1974
                                      TIG,
                                      Could you (in one of the future updates) enable slicing from the bottom upward (so upper face of the entrance 'floor' will stay at z=0.00?
                                      In this mode it'd be easy to create 'floors' from initial mass object.
                                      Thank you.
                                      • alexandre skA
                                        alexandre sk
                                        fantastic plugin TIG! really helpful thx
                                        but sometimes it crashed. everything disappears until a crtl+z.
                                        excellent anyway.
                                        • BoxB
                                          I've had that happen too occasionally but found that it has worked but not displayed properly. As soon as you find the invisible slices and go to edit them they appear. Or save after slicing, close the file and reopen and it should all be there.
                                          I can reproduce it with a random sized block and the default settings.
                                          The block and settings
                                          After slicing it's invisible but in outliner
                                          Save, close reopen and it is all there.
                                            I too have had this "invisible but there" issue [with other Plugins too].
                                            I did try to add something to edit/explode etc to overcome it, without success.
                                            But then I found that adjusting my OpenGL settings stopped it recurring... πŸ˜•
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
