    Get MAC Address
    55 Posts 8 Posters 9.0k Views 8 Watching
    • G
      Garry K
      Is there an OS independent way to get the MAC Address of the client within a sketchup script and without having to install additional software on the client's machine.
      I'd like to tie in some hardware id of some sort to a web site registration for that computer and user.
      • G
        Garry K
        Here is what I can do so far.
        and if windows I can parse the output
        but with osx I don't know what I should expect
        ` platform = RUBY_PLATFORM.downcase
        if ( platform.include?( "win" ))
        windows = true
        cmd = 'ipconfig /all'
        else
        windows = false
        cmd = 'ifconfig'
        then for windows I can redirect the output of ipconfig
        null = test(?e, '/dev/null') ? '/dev/null' : 'NUL'
        lines = IO.popen("#{ cmd } 2> #{ null }"){|fd| fd.readlines}
        puts lines`
        some of the output for windows
        So the Ethernet adapter is usually soldered on the mother board these days and should be reasonably safe.
        parse out Physical Address is the MAC Address for the Ethernet
        ` Ethernet adapter Local Area Connection:
        Media State . . . . . . . . . . . : Media disconnected
        Connection-specific DNS Suffix . :
        Description . . . . . . . . . . . : Atheros L1 Gigabit Ethernet 10/100/1000Base-T Controller
        Physical Address. . . . . . . . . : 00-1D-60-0D-80-87
        DHCP Enabled. . . . . . . . . . . : No
        Autoconfiguration Enabled . . . . : Yes`
        • G
          Garry K
          always something new to learn !!!
          this works in windows. It would be nice if it would run quitetly.
          puts ipconfig /all
          • G
            Garry K
            I'm reading that back ticks ` won't work in OSX and that using back ticks in windows is not as secure as the following
            puts %x[ipconfig /all]
              slbaumgartner
              Where are you reading that? They work fine for me (of course, SU may "beachball" while Ruby blocks waiting for output from a slow command).
              Steve
              • G
                Garry K
                This link makes references to it
                http://stackoverflow.com/questions/690151/getting-output-of-system-calls-in-ruby
                  driven
                  where are you reading that? they are interchangeable on a mac. Both return in Ruby Console.
                  > puts `ifconfig -a | grep "ether"`
                  	ether 00;** ;** ;** ;** ;36
                  	ether 00;** ;** ;** ;** ;ad
                  nil
                  > puts %x(ifconfig -a | grep "ether")
                  nil
                  but ifconfig will give you more that one ether, so...
                   puts (%x(ifconfig -a | grep "ether")).split[1]
                  "00;** ;** ;** ;** ;36"
                  nil
                  or mac only [I think]
                  > > puts (%x(netstat -in | grep "en0")).split[3].inspect
                  nil
                  you'll get what you want...
                    slbaumgartner
                    That link discusses the various ways to capture the output of a system command and security issues that arise from issuing a system command from Ruby. Nowhere does it say that the backtick syntax does not work on Mac OS X!
                    • Dan RathbunD
                      Dan Rathbun
                      Garry.. this is safer and faster to use boolean Constants throughout your module(s) [ie, Strings are slow.]
                      At the top of your module:
                      MAC = OSX = RUBY_PLATFORM !~ /mswin|mingw/ PC = WIN = (not MAC)
                      Then say down further:
                      if WIN
                        # do this
                      else
                        # it's a Mac, do that
                      another example, showing a webdialog:
                      WIN ? @dlg.show() : @dlg.show_modal()
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        Why? The %x or backquoted string method returns it's result.
                        so:
                        ip = %x[ipconfig /all]
                        Then parse the string ip,.. iterate it using each_line or
                        split("\n") it into an array of lines, then use find, etc.
                          driven
                          @dan
                          does reply_from_ifconig.split("\n").grep("Physical Address") or similar work on a PC?
                          EDIT for something as un-changing as ifconfig on a mac you could use
                          (%x(ifconfig -a)).split("\n")[10].split[1]
                          • P
                            pgarmyn
                            @dan rathbun said:
                            similar:
                            ipa = %x[ipconfig /all].split("\n").grep /\A\s*(Physical Address)/....
                            Scanning for “Physical Address” only gives a result with an EN/US OS
                            This works also on the old continent :
                            def MyModule.mac_address
                            	iptxt = `#{(platform =~ /win32/) ? 'ipconfig /all' ; 'ifconfig'}`
                            	## delete DHCPv6 ;
                            	iptxt.gsub!(/..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-..\-../,"")
                            	# delete Tunnel ;
                            	iptxt.gsub!("00-00-00-00-","")
                            	## create array with all the physical adresses ;
                            	t_array=iptxt.scan(/..\-..\-..\-..\-..\-../)
                            	#puts t_array.inspect
                            	## returns first physical adresses if one found
                            	return t_array[0] if t_array.length>0
                            	return nil
                              driven
                              There's also this one
                              mac_MAC = %x(ioreg -rd1 -c IOPlatformExpertDevice |  awk "/IOPlatformUUID/ { print $3; }")
                              returns
                              "IOPlatformUUID" = "00000000-0000-1000-8000-00**********" [my address obscured with ***]
                              • P
                                pgarmyn
                                @dan rathbun said:
                                DUh... I just stumbled upon GetMAC.exe on my Win 7 machine....
                                Yes, i have it also on Win8.1 👍
                                For the MAC-world (Apple-users) is there an equivalent ❓
                                  driven
                                  @pgarmyn said:
                                  For the MAC-world (Apple-users) is there an equivalent :?:
                                  I just posted it above?
                                  The command ioreg located in /usr/sbin/ioreg is used to display the I/O Kit registry.
                                  • P
                                    pgarmyn
                                    👍 👍 👍 @driven
                                      driven
                                      @pgarmyn said:
                                      :thumb: :thumb: :thumb: @driven
                                      Well, maybe not three thumbs... it's unclear to me if that's a standard or an xtool instal, so a safer bet would be
                                      getMACADDRESS = %x(/usr/sbin/networksetup -getMACADDRESS en0 | /usr/bin/awk '{print $3}' | /usr/bin/sed s/;//g)
                                      which returns
                                      001ec*******
                                      the mac MAC address using standard instal items...
                                      • Dan RathbunD
                                        Dan Rathbun
                                        There IS a gem that can be used for reference (perhaps it can be made SketchUp friendly.)
                                        macaddr/lib/macaddr.rb at master · ahoward/macaddr
                                        cross platform mac address determination for ruby. Contribute to ahoward/macaddr development by creating an account on GitHub.
                                        GitHub (github.com)
                                        • G
                                          Garry K
                                          I'm back at this MAC address - specifically for first Ethernet device.
                                          This code seems to work fine for Windows 7 - but will it work for OSX ??
                                          Has anyone tried this in a French computer or some other language?
                                          ` def get_mac_address()
                                          return @mac_address if defined?( @mac_address )
                                          @win = ( RUBY_PLATFORM =~ /darwin/i ) == nil
                                          tmp = ""
                                          str = ""
                                          first = true
                                          if ( @win )
                                          # for windows put results in array - splitting on newline
                                          # check begining of string for 'Ethernet' and set flag once found
                                          # then check for 'Physical Address' and look at everything after the ':'
                                          # set mac_address and return
                                          ipa.each {|line|
                                            tmp = line.strip
                                            str = tmp[0..7]
                                            if ( first )
                                              first = false if ( "Ethernet" == str )
                                            elsif ( "Physical" == str )
                                              pos = tmp.rindex( ":" )
                                              @mac_address = tmp[pos+2, tmp.length ]
                                              return @mac_address
                                          else
                                          tmp = %x[ifconfig eth0].strip
                                          pos = tmp.rindex( " " )
                                          @mac_address = tmp[pos+1, tmp.length ]
                                          return @mac_address
                                          return ""
                                          end`
                                          • P
                                            pgarmyn
                                            @Garry
                                            As i said before, this only works for US or EN OS.
                                            The output of ipconfig depends on the OS language.
                                            In French you will have to scan for "adresse physique" and for the other languages....
                                            • 1 / 3
