    Creating a new texture
    5 Posts 2 Posters 200 Views 2 Watching
    • E Offline
      erzane
      how to create a new texture pls ?
      A striped one for the example, which I could put on an edge with curves (like on attached pic bellow), without puting black color, and after yellow, and black and yellow, etc.. by normal way.
      perhaps this new colors could be called a ''non flat color'' or ''texture'' ?
      ot perhaps, need I export it from photoshop ?
      I hope my explanation is understadable 😆
      thanks
      • TIGT Online
        You can easily make a striped .png file image in Gimp or Photoshop - it needs to 'tile' - top edge joins onto bottom edge and right edge onto left edge etc.
        Use that image as a texture in a custom material.
        Now apply the material it to your surface[s].
        It might work as a projected-texture, otherwise use one of the freely available UV mapping tools and 'map' it onto your surfaces so it 'flows' across its facets...
        • E Offline
          erzane
          Hi TIG
          when you say ''Use that image as a texture in a custom material.''
          what is the proceed for add it in my colors ?
          I found this tuto, is it good ? or are they somethings I dont need inside ?
          http://www.youtube.com/watch?v=A5m_PngBZTo
          • TIGT Online
            It's not so hard... 😕
            Make a new material.
            Edit it and there are options to add a texture.
            Find the image and use it.
            Adjust its size etc as desire...
            Then you can export that Material as a SKM file for reuse from a 'material collection' in any SKP later on...
            • E Offline
              erzane
              ok, will try it
